Question about GE Security Simon 3 Wireless Home Security System
Simon3 module okay how do you shut this off
Simon3 module okay keeps repeating every hour or so at night. Don't know what module is okay and how to shut off annocement. thanks
    New Friend:
  • 74 Answers
You have a bad battery and the module runs directly off the battery. Replace the 6VDC 1.2AH battery and your problems will be over.
AlarmProfessor.net
Posted on Aug 23, 2010
Zune 120GB Battery(?) Issue
Send it in to Microsoft and they will be able to fix it for you. Otherwise, I'm sure there are online kits on how to replace the battery (but I fear they can probably get pretty messy just like phone repairs and such). Microsoft should be able to whip a new battery in there quickly.
Feb 16, 2013 | Microsoft Zune 120 Gb Video Mp3 Player,...
Engine shuts down
The only way to know for sure is to hook a gauge to the rail and check the fuel pressure when it won't start.
Sitting for a few minutes and restarting is normally a sign of a relay or coil cooling off.
There should be a EEC relay that powers the dist module and ECM.
I know you said you have spark, but it could be something else
related.
Also, if you have spark at the right time and no fuel pressure, you should be able to use starting fluid to substitute.
I don't suppose you have dual tanks and the switching valve is the problem ?
Jul 05, 2012 | Ford Cars & Trucks
2008 Night Rod Special Engine running really bad when engine gets hot. Please Help any ideas?
Hi Kelly, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals especially the negative cable at "BOTH" ends, ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor or intake seals.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust valve.
For a prime suspect please visit website below.
Good luck and have nice day.
Harley Davidson Sportster error codes and how to access them
May 08, 2012 | 2008 Harley Davidson VRSCDX Night Rod...
2002 V70 Battery keeps going dead, tests after charge okay (540cca on a 600cca battery). The AC comes on hours after the engine has been shut off and key removed. I know this is supposed to happen after...
How old is your battery and if it's over 2 yrs old get a new one also when u get out of the car make sure u turn the fan all the way off then it won't try to turn on
Mar 23, 2017 | Volvo V70 Cars & Trucks
I have a91 f150 nite no spark replaced distributer and coil got power to coil but no spark can someone help I don't get online alot so out would be greatly appriceated if you could txt me 248 974 0281 plz...
Sorry I don't do text, because I don't want spam either... The most likely cause of your problem is a bad TFI (ignition) module. All of the engines used in Ford trucks in 1991 used the TFI modules. Some were distributor-mounted modules and some were fender-mounted modules. I cannot tell you where yours is actually located, because you did not bother to mention engine size. (Nice-to-know information - it helps a little if we know what we are working on) Anyway, That is the most likely cause of a no-spark condition. In fact, It has been so common with the Ford engines that Ford ended up settling in a class-action law suit due to the TFI modules repeatedly leaving people stranded. I personally had a Ford Ranger - replaced the TFI module about 6 times in the 7 years that I owned it...used to keep a spare in the glove box.
Apr 20, 2011 | 1991 Ford F150
My blackberry stopped working after i put a micro sd card in
did you format the card first... this might help. It could be too much memory. I put an old SD card in from a former phone and it was doing the same thing...powering on and off repeatedly.
Apr 12, 2009 | RIM BlackBerry Pearl 8100
Extension simon3
Wireless reciever built in, do you mean repeater? If so, yes.
Mar 25, 2009 | GE Security Simon 3 Wireless Home Security...
Failure to shut down when playing one cd.
Try checking the control and try pressing repeat. Maybe its in repeat mode. Oh...fast forward and you won't need to wait to Check it out. Let me know...
pita3obn
Jan 06, 2009 | Bose Wave music system Multi-CD Changer...
Okay let me know what you think
the flyback transformer is the large black component simalar looking to a disrtibitor of a car it has a large red wire coming out of top and a black wire. On the bottom of the board it has about 10 pins arranged in a circle. this is flyback is located adjacent to the fuse.
Dec 07, 2008 | RCA HD52W59 HDTV Projection Television
GE Security Simon 3 Wireless Home Security System Logo
482 people viewed this question
Top GE Home Security Experts
Sean
Jim Goldsmith
Jim Goldsmith
Grantec 2000
Level 1 Expert
Are you a GE Home Security Expert? Answer questions, earn points and help others
