Question about GE DRSR483EGWW Dryer
Dryer squeaks when drying clothes.How do I fix this problem
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote to help people figure out why the dryer is making squeaking. bangin, or clunking nioses...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Posted on May 04, 2010
  • GE Master
  • 8,220 Answers
The squeak is a simple cheap plastic bearing (we3x75)To replace it you must remove the drum. dryer squeaks when drying clothes - 42386bd.jpgTake the screws out and then get the front off, yank out the drum and replace the bearing. Give everything a good hoovering to remove lint and look for bad glides6f59c8d.jpg
  • Dan Webster
    Dan Webster May 04, 2010
    New style glides won't scrub but they can destroy clothes and do a lot of damage
4 Suggested Answers
Illeagle
  • 525 Answers
SOURCE: GE Dryer makes an intermittent noise when drum is turning with clothes
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Below is a link to common solutions that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information.
It provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Once you access the site you will be able to navigate numerous pages of information on your product. You will need to enter your model number to access your product information.
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint. I will post the most common solutions to your complaint. For more specific information please refer to the tip and/or link provided. Here are some things to look for:
If your dryer is noisy, check these:
Rollers
Idler pulley
Glides
Rear drum bearing
Blower wheel
Rollers Many dryers use rollers or wheels to support the clothes drum. When these rollers are worn, they can be noisy. You should replace the whole set of rollers at the same time.
Idler pulley Dryers have a tension or idler pulley that keeps tension on the main drive belt. When it's worn, it can be noisy. When that happens, don't lubricate it. Just replace it.
Glides Many dryers use nylon or plastic glides at the front of the clothes drum for support. When these are worn, they can be noisy. When that happens, replace them.
Rear drum bearing Some dryers support the clothes drum in the rear with a center spindle instead of rollers. The spindle may be a ball-and-socket type support or a shaft through a sleeve. When the components are worn, they may squeak, squeal, or rub. You can't repair them. Just replace them when they're worn.
Blower wheel Your dryer's blower wheel pulls air over the heat source, through the clothes drum, and past the thermostats, then pushes it out the exhaust duct. The blower wheel, which is usually plastic, may wear out over time. But if it's noisy, it may simply be clogged with lint. Clean the blower and test to see if the dryer is still noisy. If it is, you probably need to replace it.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 09, 2008
  • 479 Answers
SOURCE: Loud Squeaking noise when drying clothes
Might be the issue with the rotor bearings.
2.Might be there is some dust or other thing in rotor drum so please check and clean.
Posted on Aug 11, 2009
heatman101
  • 43501 Answers
SOURCE: whirlpool duet GEW9250PW1 electric dryer squeals
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
heatman101
Posted on Apr 06, 2010
Testimonial: "Thanks, so now how do I get the extended warranty plan to pay for it. They will not send someone out for squeaks and squeals. "
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
My dryer GE Electric dryer model DBSR453EBOWW squeaks !!
It could be the drum bearing.You prob need to re-grease it.but it could be a devil to get at.
Jun 22, 2012 | GE DBSR453EBWW Electric Dryer
Our clothes dryer squeaks when it is drying clothes. How can it be fixed or what is the problem?
Most time them squeak is like bad brake pads on a car. The plastic bearing is gone and now the drum is riding on the metal bracket. The front of the drum rides on slides and when they wear out you get a scrubbing sound and not so much a squeak. So i would say you have a GE/Hotpoint type dryer with a rear bearing that looks like this:
WE3X75
My Dryer problems and solutions blog page
How it works: GE clothes dryer
Mar 31, 2011 | Dryers
Dryer about 5-6 years old and does about 5-6 loads per week. last 2 months, with medium to heavy loads, has developed a loud squeak that coincides with drum rotation. light loads cause a lesser squeak, and...
drum rollers/glides, may be that the motor needs to be oiled, in which case you will need to unplug dryer and drill a hole in the casing not to deep just to where it goes through the casing, then moisten the cotton fabric. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-tears-clothes+repair.htm
Feb 26, 2011 | GE Profile DPSR475GW Dryer
My dryer is squealing and have to run it twice to get my clothes dry
the squealing/squeaking noise is more then likely your drum rollers:
the drying twice is a venting issue:
http://www.partselect.com/dryer+wont-dry-clothes+repair.htm
Feb 16, 2011 | Whirlpool LEW0050P Electric Dryer
Dryer squeaks when clothes are drying
Squeaking can mean bearings going bad or the pulleys needing some oil on them. The pulleys can usually be accessed from the rear of the dryer. The bearings are a different story, you would need to remove outer casing of the dryer to remove the drum to get the bearings behind the drum. I would recommend trying to oil the motor and idler pulleys and if that doesn't fix the problem if your handy you can try to replace the bearings. Its a big job, the bearings are behind the drum and are screwed in from the inside of the drum. In order to remove the drum the casing of the dryer had to be removed, usually the front and the top (the top will sometimes tip back on hinges). After that the drum should slide out with the bearing assembly attached. Installation is the same as removal. {Note: If you find it to be too much trouble, I would just leave it squeak, other than being annoying it won't hurt anything. Also, some dryers have a compartment in the back where you can see the bearing assembly, maybe you can spray some WD-40 in there and see if it stops squeaking. The time you really need to replace the bearings is if your drum is loose, as the bearings have gone bad, not just squeaky}
May 12, 2010 | Dryers
Aug 11, 2009 | GE DBSR453EBWW Electric Dryer
GE Clothes dryer squeaks
My ge electricryer sqeaks very loud and makes a thumping noise. it just started a cuouple of weeks ago.
Jun 19, 2009 | GE DWXR483EBCC Electric Dryer
Frigidaire electric dryer catches clothes at the edge of the drum
If the clothes catch on the drum edge the felt seal is worn out , and the squeak could be the bearing the drum rest on or the belt tentioner , it may need oiled , you can buy the felt seal replacement kits online and they are not hard to install.
Hope this helps.
Phil
Apr 10, 2009 | Frigidaire FDE436RE Dryer
Irregular squeaking from stackable dryer
Post your make and model please. Sounds like the rear drum bearing is dried up
Feb 20, 2009 | Frigidaire FEQ332E Electric Dryer
GE DRSR483EGWW Dryer Logo
922 people viewed this question
Top GE Dryers Experts
Dave Harrison
John Tripp
John Tripp
vince
Are you a GE Dryer Expert? Answer questions, earn points and help others
