Question about LG Flatron F700P 17" CRT Monitor
I have to push the power bottom all the time. If i don't, it turns off and the light indicator goes off not amber or any other color. Now that i'm typing i'm pushing the bottom... Last night it was working well but today!? Thanks in advance
  • atieh Mar 29, 2008
    Hi tantong, I don't think that any lamp is broken becuase while i'm pushin the power bottom every thing are displayed well as they were displayed before this problem arose.
    If I don't push the bottom it is completely off and i can't see anything.
    What is inverter board?
    Thanks a lot
    Novelist:
  • 138 Answers
Hi this is the way how to examine what's wrong with your LCD monitors. After you turned it on and the screen blacked out, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Posted on Mar 26, 2008
Hi atieh, How long does your monitor stay on after you push the screen-power button? And after it turned off by itself, you go check the image on screen without pushing any button by using my method above (USING FLASHLIGHT). The inverter board is the circuit board inside the monitor. This board controls monitor power, signal input and output from VGA card. If there is something wrong with CCFL lamps, it will shut down by itself because of circuit safety. As I mentioned last time, it is not too difficult to change the lamps. Could you tell me the specification or data sheet of your monitor?
Thank you,
Tantong
Posted on Mar 29, 2008
SOURCE:
Aux power led light is amber on dimension E521
I think your problem is your memory or video card.
Below are some steps that I recommend.
When you plug in the power cord is there any lights whatsoever on the computer?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the laptop is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the computer and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe your power cord is bad if you don't get anything to happen whatsoever when you press the power button.
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Maybe your power supply is bad. Sometimes there is enough power to make the power light or some other lights come on but not enough power to make the fan turn on or hard drive spin.
Below are links and info I found from Dell's Website based on your model.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/specs.htm
Controls and Lights Front of computer:
Power button - push button
Power light
green light - Blinking green in sleep state; solid green for power-on state.
amber light - Blinking amber indicates a problem with the power supply inside the computer. If the system cannot boot and there is a solid amber light, this indicates a problem with the system board (see "Power Problems" in your Owner's Manual).
Diagnostic lights
four lights on the front panel (see Diagnostic Lights.)
Standby power light
AUX_PWR_LED on the system board
Hard-drive activity light
green light - When the computer is reading data from or writing data to the hard drive.
LAN indicator light
green light - Solid green indicates that a LAN (local area network) connection is established.
http://support.dell.com/support/edocs/systems/dime521/en/SM_EN/adtshoot.htm#wp1056411
Jun 03, 2012 | Dell Dimension E521 (D10E16) PC Desktop
Dell 1209S Projector, tries to turn on, and the fan comes on for 30 seconds and then goes off again. It tries this several times and then the light bulb icon comes off and it doesn't do antything else
Lamp is burned out or makes a popping sound.
When the lamp reaches its end of life, it may burn out and may make a loud popping sound.
If this occurs, the projector does not turn back on. To replace the lamp, see on page 38.
LAMP light is solid amber If the LAMP light is solid amber, replace the lamp.
LAMP light is blinking amber If the LAMP light and the Power light are blinking amber, the lamp driver has failed and the projector will automatically shut down.
If the LAMP light is blinking amber and Power light is solid blue, the color wheel has
Unplug the power cord after 3minutes then turn the display on again. If this problem
persists, contact Dell™.
TEMP light is solid amber The projector has overheated. The display automatically shuts down. Turn the display on again after the projector cools down. If the problem persists, contact Dell™.
TEMP light is blinking amber A projector fan has failed and the projector will automatically shut down. If the problem persists, contact Dell™.
Oct 23, 2011 | Dell 1209S DLP Projector
Dell 4500 won't turn on,power light amber/green
Is the light more amber or more green? If you push the button and it goes amber, then you probably have a bad power supply. Try getting another power supply to test. If that doesn't solve the problem, then you probably have a bad motherboard.
Oct 22, 2009 | Dell Dimension 4500 PC Desktop
Its not booting and the Leds VRM and NMI are with amber color
VRM and NMI lights lit usually indicate an issue with CPU #2's VRM which can be replaced. Also check 5 lights on back middle of system. If VRM light is lit here remove CPU 2 and VRM and reboot system. If system boots, this was the issue...
Apr 25, 2009 | IBM eServer xSeries 346 8840 (884022U)
Wireless/LAN indicator on pc stays amber
best advice is as long as it's working don't try to fix it. you may cause more problems than you solve. as long as you get the internet ok, do you really care what color the light is?
Mar 07, 2009 | HP Pavilion G60-120US NoteBook
Amber Light blinking on power switch
27 mgz oscillator on the back of the main board. Try resoldering it, or replace it.
Dec 10, 2008 | Dell W2607C Television
Computer Won't Power Up
If the blinking amber LED is on the computer itself and not the monitor, this is most likely a power supply issue. First thing to try would be replace the power supply. If the blinking led is on the monitor, it probably has bad capacitors and needs to be replaced. (or repaired)
Jul 15, 2008 | Dell Dimension 8400 power supply ** FREE...
Black screen on start up
yep
unplug the system
open the case
look for a battery and take it out
take out the memory (rams)
wait ten minutes
press power button 5 times
put everything back in
and boot it
Jan 12, 2008 | Dell OptiPlex GX270 PC Desktop
Stuck in power saver
Try the unlock procedure: With the monitor on press and hold the "MENU button for abot five seconds and see if it resets. If that doesn't work tell me a bit more about the screen - is there any OSD (on screen display) or error messages? Is the power indicator light on? If so, what color is it? Blue indicates that that you may need to turn the brightness and contrast up...\ If it is actually in power save the indicator light will be amber. What color is it? If the light is amber and all the connections to the computer are correct and it still won't come-up then it's an internal problem and the protect circuit may be keeping the screen from lighting. Good luck... And let me know. Bill
Jun 07, 2007 | LG L1722P 19" LCD Monitor
LG Flatron F700P 17" CRT Monitor Logo
Top LG Computers & Internet Experts
Ekse
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
