Question about Targus (AKP02US) Keyboard
Laptop letter keys are typing numbers.
Even after pressing Fn key and numbers lock I still cannot convert the letter keys back to letters...they only type numbers.
  • 416 Answers
Try holding shift - Fn - Num Lock
Posted on May 04, 2010
How to turn on numlk for gateway NE56R31u
You may have hit a certain combination of keys on your Gateway laptop and turned on the NumLock function accidentally. The result is that the rectangle of keys from the 7 key down to the question mark key have become a number-entry keypad. Worse, Gateway manuals don't discuss this function.
Hold down the "Fn" key on the bottom row of the keyboard, and press the "NumLk" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F11" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the F11 key and "Scroll Lk" key simultaneously. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "F9" key. Type the letters UIO. If they come out as numbers, move on to the next step. Hold down the "Fn" key and press the "Scroll Lk" key. Type the letters UIO. They should come up as letters. If none of these help, then it's probably a keyboard malfunction and you'll need to get it repaired.
Feb 17, 2013 | Computers & Internet
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
My grand daughter has some how turned on the FN key so when she is typing numbers come on the screen instead of the letters. How do we stop this ?
The NumLkkey has been pressed andthe letters on the righr hand side on the keyboard has been converted to a number pad.
The NumLk key also doubles up as the ScrLk key, this is located near the F12 function key. Whenyou press this key to turn on the Numlk a LED will light up to indicate that the Number Lock has been pressed, press this key again to turn off the Number Lock and the NumLk LED will switch off and you will be able to type letters again.
Aug 29, 2011 | Fujitsu Computers & Internet
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
My laptop is only typing the numbers that appear on the letter keys. For example when I hit the letter J, it types a number 1. When I hit the letter k key, it types a 2, etc. How do I get it to go back...
Usually you have to hold the "Fn" key to get to these. Look for a "NumLock" key to turn this off. You may need to use the "Fn" key to select numlock.
Mar 10, 2011 | Computers & Internet
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
Letters are num locked. pushing num lock key does not resolve
Number lock, a situation where numbers instead of letters are typed is as a result of the digital lock being active. to deactivate pressing the Fn+Numlk or Fn + Shift +Numlk key combinatioins
Jun 18, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
Simply change my keyboard from typing numbers instead of letters..I.e. I'm trying to type yonkers and it gives me y6...I know it is a simple F6 or F2 function but I forget. Its been a while since I u
You need to press the NUM Lock key.
The NUM lock key is usually the same key as the ScrLk key but to select the NUM lock you need to press and hold down the Shift key and then press the NumLk/ScrLk key. A LED light will light up to indicate the number keypad is on.
Apr 26, 2009 | IBM ThinkPad T30 2366 Notebook
Ibm thinkpad keyboard. i type letters, numbers show up. fix?
With my IBM Thinkpad, I had to hold Shift+ScrLk to turn off Number Lock.
Mar 27, 2009 | IBM Thinkpad 560 Series Laptop 20h4241...
My laptop keeps typeing numbers for the follwoing letters uiopjklm. How do I get it back to typeing letters?
Switch NumLk off
Usually this is done by pressing Fn & F11 keys together
Or just look for the key that has NumLk on it and press it together with Fn
Aug 12, 2008 | Computers & Internet
Targus (AKP02US) Keyboard Logo
415 people viewed this question
Top Targus Computers & Internet Experts
J John
Laxman Bisht
Laxman Bisht
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
