Question about Cell Phones
My lg300 phone doesn't charge anymore.
My lg300 phone charger used to charge, then it went to charging when the cord was in a certain position, now it doesn't charge at all
  • 36 Answers
The connector of the charger to your phone, or the connection part of your phone is spoilt, you'll have to get either of them fix.
Posted on May 04, 2010
M886 won't charge battery. replaced battery still no charge. charger is good.
Hi Jane, I'm Peter. I have had the same problem and discovered that on certain phones the port where you plug the charger cord into may have a little finger of metal that has been bent down some so it can't connect the charger connector . On mine I had to remove the back of my phone to get a little better view then got a toothpick ( don't use any metal ) and gently pried the metal finger back straight so it could slide properly into position to charge. I hope this helps .
Jan 01, 2015 | Cell Phones
On ultra jet 3 there is a 3 prong outlet below the seat on the right & has cord that goes to normal outlet is that how to charge it
Jet 3 Ultra www.pridemobility.com 33
VI. BATTERIES AND CHARGING
To charge the batteries using the off-board charger:
1. Position the front of your power chair next to a standard
electrical outlet.
2. Be certain the controller power is turned off and the
freewheel levers are in the engaged position. See III.
"Your Power Chair."
3. Plug the off-board charger into the off-board charger/
programming socket on the controller.
See figure 25.
4. Plug the off-board charger into the electrical outlet
You should use the charger supplied with the power chair. It is
the safest, most efficient tool to charge the batter-ies. We do not recommend using other types of
chargers (e.g., an automotive battery charger).
Sep 07, 2014 | Health & Beauty
My phone will no charge while it is on the charger
Sometimes the block transformers on phone chargers go bad. I'm assuming it uses a micro usb plug like most phones do now. The easiest way to check is to borrow a charger from someone else or if you have a kindle charger use it to see if the phone will charge. If it does don't go back to the phone store to get another one because they charge an arm and a leg. You can order the chargers for most phones online for half of what you pay at a phone store.
Feb 02, 2014 | Cell Phones
How do I charge the Hoveround mpv 4? I plugged the charger into the chair and plugged the cord into the wall using an extension cord. The red light on the box turns red when in the "on" position but the...
Firstly, it is bad news to use an extension cord with the charger as it can get very hot. It will sometimes take 8-12 hours to get a full charge on the batteries. If the light does not go to green on the charger, the batteries may be damaged and not able to take a charge. This is especially true if the Power chair was stored after your father in law died; the gel in the batteries may have gone solid. The lights on the controller will go left to right then back if the charger is connected properly.
The brake release knobs both need to be in the UP/DRIVE position for the motors to engage.
Jun 22, 2010 | NRS Hoveround MPV 4 - Hovaround Used...
My env2 wont charge. whenever i plug it in, the battery stays the same. what do i do?
This seems to be a common problem for the env2. If you hold your charger a certain way in the phone does it charger? Is the charger port broken or damaged?
If so the easiest workaround is to get an external battery charger and extra battery to charge the phone.
Check out the following link for information on the battery charger and other options for the env2 charge issue.
Lg Env2 External Battery Charger Fix
Jul 17, 2009 | Verizon Communications enV2 Cellular Phone
LG Venus Charging Problems
try borrowing another charger that fits your phone, If it works change the charger as the cord might be broken//
Oct 03, 2017 | LG Venus VX8800 Cellular Phone
Charging my mac laptop
hi if it's a ibook or powerbook g4, you certainly have a broken part of your charger that stayed inside your mac... then you have to change the port and the charger
May 20, 2009 | Computers & Internet
My sidekick 2 won't charge
mine stop charging sometime ago, and I switched to a nokia 3310 charger and its been working fine since. might be a little tight going in at first. good luck.
Aug 10, 2008 | T-Mobile Sidekick II
Why won't it charge??
I had a similar problem. I found that the charging port gets a little "stretched" after a while and the plug doesn't make contact the way it should when you insert it. I went and bout one of those universal chargers with the many different connectors and used one that is slightly larger in overall diameter with a slightly smaller hole. It worked fine after that. You can try wrapping the charger cord around the phone after you plug it in to see if it helps. It worked for me for a while but the charger plug eventually broke from fatigue. Hope this helps.
Nov 12, 2007 | T-Mobile Sidekick II
My phone wont charge
I have the same phone and bought a new charger and it still wont work, it's the phone
Sep 13, 2007 | Samsung SPH-M500 Cellular Phone
Cell Phones Logo
52 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
