Question about LG 42LC2D 42 in. LCD HDTV
Television will go blank after a few minutes. if i turn the tv off and turn it back on it will be fine for a few minutes. the tv is 4-5 years old
  • LG Master
  • 3,866 Answers
Sounds like you got a bad back light or invertert, Take a flash light to the screen and see if you see a faded or distorted picture if so replace the back light and or
inverter. A local tv repair shop would be ideal if you do not know how to test these things.
Thanks hope this was very helpful to you when you cast your ratings and feedback today.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Posted on May 04, 2010
    Problem Solver:
  • 19 Answers
The most common cause of Failure in this unit is power supply failure caused by failed capacitors. A visual inspection is The easiest way to identify and confirm bad capicitors on the power supply. Such a capacitor will show one or more of these symptoms: 1) Bulging of the vent on the top of the capacitor. (The 'vent' is the impression stamped in the top of the can. The impression forms the seams of the vent. It is designed so that if the capacitor becomes pressurized it will split at the seams relieving the pressure rather than making it explode.) 2) Sitting crooked on the circuit board as the bottom rubber plug is pushed out. 3) Electrolyte (a crusty brown substance) leaked onto the board from the base of the capacitor 4) Venting from the top of the capacitor, visible as rust-like brown deposits, or a visible hole in the vent Once the power supply is repaired or replaced your tv should work normally
Posted on Jun 10, 2010
I have the exact same issue as the unsolved problem below on this page: I have a LG 42LC7D that is about 3 years old. A Problem with the LG 42LC7D-UB Television I have a LG 42LC7D that is about 3 years...
The power on problem is a cap in the power on circuit. The loss of signal for an areal is delayed. Nothing you can for DIY.It needs repair shop visit.
Feb 12, 2011 | LG 42LC7D-UB Television
TV goes to blank screen after turning it on (about 3 to 4 minutes) but I can still hear it fine. I turn it off and wait a few minutes(5) then turn it back on everything is normal then it goes back to blank...
This tv the LCD inverter board is dead,that why is not sustanning backlight for the LCD screen light to have the picture.Call Polaroid for warrenty repair,this tv under a year old.
Jun 07, 2010 | Polaroid TLA-01511C 15 in. LCD Television
No video but there is audio after replacing bulb
NAKE SURE YOUR FRONT COVER THAT GOES OVER THE LIGHT IS'NT ON TO TIGHT ALSO CHECK THE 2 SCREWS THAT MOUNT THE LAMP COVER MAKE SURE THERE NOT TO TIGHT AND THAT THERE BOTH SCREWED IN THE SAME AMOUNT AND ALSO CHECK THE FAN ON THE BACK OF YOUR T.V. AND CLEAN IT IF NEEDED
Mar 07, 2009 | Sony Grand WEGA KDF-55XS955 55" Rear...
TV screen goes blank but power stays on
Sounds like the CRTs are going into protective blanking due to the vertical output ic needing to be resolderd. Try resoldering the vertical IC that may possibly fix the issue.
Jun 15, 2008 | Mitsubishi WS-73713 73" Rear Projection...
I have only the top line of a multi-screen picture (4 small boxes, all the same), below which are some colourful flashing very small boxes, and the rest of the screen is blank except for a big black box. ...
First turn off the closed caption (CC on remote) then make sure the picture in picture is not activated. turn it off.( PIP button on remote). If that don't help un plug the tv and then plug it back in after a few minutes.
May 06, 2008 | Televison & Video
TruTech 19" LCD TV+DVD
I have a sansui 19" LCD TV+DVD
I had to attempt multiple times turning the TV on to get a picture. The sound was fine. This kept happening when I would go to turn on the set the TV kept playing fine with picture & sound but after the 2nd attemts I turned it off & then tried to turn it back on which took multiple attempts, it kept playing for a few minutes then the picture went out but the sound was still there.
The set is not yet 2 years old.
Mar 13, 2008 | TruTech PLV1615T 15 in. LCD Television
TV shuts off after few minutes
tap it on its side then try to turn it on and see if it stays on if it does bad solder connections
Aug 11, 2006 | Sanyo DS31520 31" TV
LG 42LC2D 42 in. LCD HDTV Logo
212 people viewed this question
