Question about Ryobi Factory-Reconditioned 26cc 22" Gas Hedge Trimmer ZRRY39500
How to install ryobi pull cord on hedge trimmers
boscia
  • 163 Answers
SOURCE: add on hedge trimmer ryobi weed eater
I use a dremel with a sharpening stone, if u don't have one you can also use a power drill with a small sanding disk (1 inch) and course sand paper (30 or 40 grit). or you can use a bastard file. its too tight to use any kind of angle guide so just take your time and do it by eye. it shouldn't take much to get them sharp enough to do the job, over-sharpening is unnecessary and dangerous, and will make the blades dull faster. sharpen all the free blades, top and bottom, then start the trimmers to advance the blades to free up the sides you couldn't get. i use a light penetrating oil to clean the blades first, then lithium grease spray to lubricate.
Posted on Nov 28, 2008
boscia
  • 163 Answers
SOURCE: Ryobi 18V Hedge Trimmer Blade Question
  • 3 Answers
SOURCE: what is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
If it is a 2 stroke engine, a 50:1 ratio should work. That's 50 parts gas to 1 part oil.
Posted on Dec 14, 2008
Just buy a file and push 3 or 4 down strokes down the same slope of the cutter toward the sharp edge. Never file on the flat top of the cutter, only on the slope. Support the frame using a saw horse or pick-up bed. The support makes the file cut the metal better. You can do the same thing with chain saws. You just need the file that fits the cutter. You just hold a consistant angle and count out the same number of strokes. Also, clean out junk between the moving parts, tighten any loose screws, and drop a few drops of 3 in 1 oil between the moving parts. Having things sharpened at a shop is inconvenient and expensive.
Posted on May 24, 2009
SOURCE: Hedge trimmer starts fine then stops after 5 minutes
Carburetor high speed adjustment ( screw nearest the filter ) open ( counterclockwise ) 1/2 turn.
Adjust again as needed to run when hot.
make sure the gas mixture ratio is as required.
Henry
Posted on Sep 22, 2009
I have a ryobi hedge trimmer RHT 2660 DA why wont the pull cord wont return ?
If you can try and tap by the starter housing with a small hammer and then you need to get some lubricant spray injected in to the spring. If it wont go back in there is a chance the spring has either broke or become unseated.
Jul 28, 2014 | Ryobi Garden
Starting up Ryobi Petrol Strimmer
full choke on , push petrol bubble 5 times then pull starter cord., with luck it will kick in to life after a 20/30 secs put on half choke , run again for 30 secs the no ckoke.
The main problem with Ryobi products is that they flood very very easly. So the more time you try and pump petrol into the carb the more it will flood . If that happenes then choke off and switch off and then just pull starter cord for about 30 secs then switch on and it could start if not prime it again as above good luck
Dec 24, 2011 | Ryobi Garden
Hi i wonder if you can help my Ryobi hedge trimmer has a problem with the pull cord it works goes in and out but it does not turn the engine over is there maybe a key way or something that maybe broken...
Hello Nick,
Inside the cord attaches to a plastic wheel which cranks the engine. This cord can become loose or can break after some use. Try opening the plastic casing where the cord is to see if this is the problem.
Thanks
Jul 25, 2011 | Ryobi ZRRY30550 Factory-Reconditioned 30cc...
I have a ryobi hedge trimmer p2601 and the plastic handle broke. Is there a way to get a stronger handle or just a replacement?
May 29, 2010 | Ryobi 18V Hedge Trimmer
Cant start ryobi 890r brushcutter
My Ryobi 890r brush cutter will start and then die
May 16, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Pull cord wont retract
you need to get a new recoil spring, most small eng. shops will have it or can get it. they can be hard @ times to install if you do not know what you are doing.
Oct 05, 2009 | Ryobi Garden
How do fit a hedge trimmer attachment to a rbc 40 sb brushcutter ? thanks
This unit was not made to have interchangeable heads. Ryobi makes a hedge trimmer attachment for some of its units that are quick connect.
Otherwise, you may buy this attachment and see if you can interchange the head from the brushcutter to the hedge trimmer. You may find it more work than you want to tackle.
Sep 26, 2009 | Ryobi Garden
What is the gas & oil mixture for ryobi 26cc 22in hedge trimmer
Dec 10, 2008 | Ryobi 26CC, 22 In. Hedge Trimmer
Ryobi Factory-Reconditioned  26cc 22" Gas Hedge Trimmer ZRRY39500 Logo
110 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
