Question about Kenmore 3.8 cu. ft. HE4t Front Load Washer
Washer showing error code SUD - Kenmore 3.8 cu. ft. HE4t Front Load Washer
  • 530 Answers
Any f35? or is it just sud?
is it green?
if it is just sud and happens towards the end of the cycle take your kick panel off....3...7 millimeter screws or t15 torques whatever you have will work.
twist off the pump catch see what's inside...if there is socks and debrie you fixed your problem.
if it happens at the beginning you have a bad pressure switch usually happens on the steam washers....what color is it?
Posted on May 04, 2010
Testimonial: "thanx"
I have a maytag 5000 series washer. We are getting an f21 error code. I unscrewed the white drain filter and cleared it. There was little in it. I keep getting the f21 error though. Can you help?
Search Results
    whirpool f21 error code - YouTube
    ? 3:04
    https://www.youtube.com/watch?v=b24PVv-ORqg
    Jul 1, 2012 - Uploaded by davidmontabon
    whirpool f21 error code. ... Maytag , Whirlpool Washer Repair - Drain pump error, no drain - F9E1- MHWE201YW00 - Duration: 4:29.
    My maytag 5000 series steam washer stopped and said Sud ...
    www.fixya.com/support/t8682656-maytag_5000_series_steam
    Mar 17, 2011 - my maytag 5000 series steam washer stopped and said Sud and now says ... Clicking this will make more experts see the question and we will .... I bought aMaytag 3000 seris in 2008 and I am getting these messages: F21 ... Maytag 5000 Series washer F21 error code was flashing and door will not open.
    Whirlpool/Kenmore/Maytag & more-F02/F21 & Sd error codes
    fixedappliance.blogspot.com/.../whirlpoolkenmoremaytag-more-f02f21-...
Feb 09, 2016 | Maytag Washing Machines
Sud error code
I found that mine was having a sud error. I removed the lower front panel and removed the filter. It was full of lint and loose change. I reinstalled the filter and haven't had a problem since. On a side note I found something interesting laying inside. A service tech guide wich stated to do exactly what I had done.
Nov 27, 2012 | Maytag EPIC MFW9700S Front Load Washer
I have a Kenmore Elite Washer for over a year and is getting a F35 error code, then the SuD flashing. Cleaned out the soap container & inspected the inside (as stated on page 21 of "Washer...
F35 is a water level error.
The water level switch (pressure switch) has malfunctioned.
If you remove the top panel, three screws in the back, you will have access to the pressure switch.
With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions.
If the fault codes return after doing this, you will likely need to replace the pressure switch.
Also - please be sure to use He soap.
Thanks for using FixYa!!
Nov 12, 2010 | Kenmore Elite 45986 Front Load Washer
How do I fix my washer that only says 'sud' constantly and won't work at all? Whenever I try to start a cycle nothing happens. Whenever I push a button nothing happens. Please Help.
http://whirlpool.custhelp.com/app/answers/detail/a_id/2948
Hi please go to this above link, it is all explained at length what is going on and what to do.
This error code indicates that excessive detergent suds occurred during the cycle.
If a "Sud" or "Sd" error code is displayed, or if you can see excessive suds in the window:
There are too many suds in the washing machine. The washer will not be able to spin out water with the excess suds. When "Sud" or "Sd" is displayed, the washer automatically extends the rinse time to remove the excess suds. During this time, the washer pauses the tumbling and adds water for additional rinsing. This pause allows the bubbles in the suds to break. This pause and rinsing are necessary and may occur several times to eliminate the suds. See the animation below for more information.
  • If you see "Sud" or "Sd" with the Rinse status light on, the washer is in the process of removing suds. Let the cycle continue.
  • If you see "Sud" or "Sd" and the Cycle Complete light is on, the washer detected too many suds during the cycle and your load may not be fully rinsed or water may not be fully removed. You may want to select a Rinse/Spin cycle for further rinsing.
Aug 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore washer showes sud code
If it is similar to the Whirlpool duet,
Try using less soap (hi eff machine)
try using more fabric softner
to clear the occasional Sud warning, I run the machine on "quick wash" with no detergent/additive. gives it two more quick spin cycles in 30-35 minutes, usually clears it.
Jul 14, 2010 | Kenmore Elite 45986 Front Load Washer
Error code "SUD"
SUD error means there is to much soap being added, the washer will shut down, if it cents to much soap
Jan 12, 2010 | Kenmore Elite 45986 Front Load Washer
F02 Error Code & SUD message
Knowing from our washer, the SUD code is too much foam from the detergent. Since most soaps today are highly concentrated, or High Efficiency soap, try using less soap as a starter. :)
Nov 17, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Whirlpool Duet Washer-error code "sud"
Just take off the bottom kickplate (3 screws on the bottom). You'll see the pump front and center. Twist the front face of the pum slowly to the left. All the trapped water will flow right out towards you. There could be a sock or some other debris there. Unclog, screw that faceplate back in and start it up.
Sep 06, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore 3.8 cu. ft. HE4t Front Load Washer Logo
191 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
