Buffalo Technology WHR-G54S Wireless Router (WHR2G54S) Logo
Posted on May 04, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need to connect with new modem
I have a new Motorola SB6120 modem. I have upgraded to Comcast cable service, but can't get the Buffalo WHR-G54S to work. My MacBook won't prompt me for the update. Is it still looking for the ATT DSL arrangement I had??
Mehandi Husain Suleman
Level 3:
  • Master 1,654 Answers
  • Posted on May 04, 2010
Master
Level 3:
Answers
1654
Questions
Helped
576344
Points
4530
How to configure
The WHR-G54S has a default LAN IP address of 192.168.11.1
and Subnet Mask of 255.255.255.0.
Make sure your computer has an IP address in this range 192.168.11. x
Open your browser
type http://192.168.11.1
you will enter the web interface of the router
root is the username and no password is needed.
Configure your router.
http://cdn.cloudfiles.mosso.com/c85091/WHR-G54S-Manual-v1.9-web.pdf
I cant connect i-pad2 to buffalo
Buffalo Technology WHR-G54S Wireless Default IP, Default Username, Default Password
Reset WHR-G54S by holding RESET down while powering it on. Hold 30 seconds, then remove power
Can you portforward to host online games'? Using BUFFALO WHR-G54s
Although the specific ports may be different depending on your console )or PC) and game, the following example shows step-by-step how to enabl eport forwarding to open your NAT for game hosting, etc.
http://portforward.com/english/routers/port_forwarding/Buffalo/WHR-G54S/Echolink.htm
Cannot open web page through router
Try opening network connections TCP/IPv4 on your pc and add ip address manualy to be in the same number match the same as your router ie default gateway and preferred DNS Server eg 192.168.1.1 or 10.1.1.1 depending on what default the router is set on the ip address should be the same apart from the last no. eg 192.168.1.8 or 10.1.1.8 subnet mask will default to the right setting if you push the tab key after entering the ip address
Hope this helps
Trying to connect buffalo router to comcast modem for wireless internet
You will need to use the MAC address of your PC. Do an IPConfig/all while connected with a ethernet cable. That's whatg you need to put in under Wan--> WAN MAC address
WHR-G54S
problem is resolved many thanks i found my cd's and restarted the whole loading process from the beginning
Buffalo WHR-G54S & Virgin Media
Just to let you know if you havent solved it yet, i had this same problem today and i fixed it by pressing the reset butoon on the modem, this was after hours of trying to reset the router
Top Buffalo Technology Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Sean Wright
Sean Wright
ADMIN Andrew
ADMIN Andrew
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
