Question about Roper REX4634KQ Electric Dryer
New Dryer and there is no heat and the timer is not moving !
I just bought a brand new dryer, and when I plugged it in, it was turning, but there was no heat and the timer wasn't moving after letting it run for about a hour ! I haven't had the dryer 24 hours yet ! What should I do ?
  • 530 Answers
You need to first check your power do you have 240 nstraight across your receptical? i would flip breaker on and off. see what happens...what was wrong with your other dryer?
Posted on May 04, 2010
Dryer works but timer doesn't move. I just replaced it and still having the same problem.
Kenmore 400 6942 Dryer Heat timer - Questions - Fixya
www.fixya.com > Forum > Dryers > Kenmore > Kenmore 400 6942 Dryer
Kenmore 400 6942 Dryer, heat timer related issues. ... The timer doesn't work. ... the heat turns back on the timer stops,heat shuts off the timer will move again,if the ... not heating/timer knob not turning . the dryer works but is not heating and i ...
kenmore 400 doesn't heat, and timer doesn't move, but dryer ...
www.shopyourway.com > Manage My Life > Questions
I understand your Kenmore 400 Dryer doesn't heat up or the timer doesn't move, butit tumbles sometimes. I found the manual for your Kenmore Dryer in ...
Fixing an Electric Dryer that Doesn't Heat and the Timer ...
? 5:51
https://www.youtube.com/watch?v=0mo_gw0p2CI
Jun 29, 2013 - Uploaded by SamuraiRepairman
Although electric dryers are the simplest appliance to work on, ....and now the dryer won't heat and the timer doesn't advance, butthe motor still runs? .... Diagose a Whirlpool or Kenmore Dryerthat Keeps Running, Wont Shut ...
Dec 21, 2015 | Kenmore 400 6942 Dryer
Brand new Lg dryer 2501, error code ''nP''
I had the same issue with two new dryers. The rep on the phone said nP can also indicate a power issue. It turned out one of the wires in the outlet had broken off. Rewiring the outlet solved the problem.
Mar 05, 2010 | LG Dryers
Replaced timer, new one stops turning and doesn't turn dryer off.
Some dryers have a "press guard" setting. This willkeep the dryer tumbling with no heat at the end of the cycle. Usually you can select it on or off and in some cases can set the time. see if you have this feature.
Apr 07, 2009 | Dryers
Whirlpool Estate Dryer barely heating
Four wires on the new cord.
Red and Black go to outside screws on the terminal.
White goes to the middle terminal.
Green goes to the cabinet ground screw near the terminal plate cover.
Mar 11, 2009 | Whirlpool GEW9250 Electric Dryer
Dryer just spins and spins and does not stop at the end of the cycle. I have to manually turn it off, on any setting. Also - there is no heat.
need new timer. unless you plan on buying a brand new dryer do not buy a timer cheaper to buy another used 1
Dec 02, 2008 | Dryers
Brand new dryer timer does not move dryer wont heat
be sure wired correctly and has 240 volts between outer lugs and 120 between outer lug to middle lug (or burnt wire from not being properly tightened when installed)also try resetting breaker
Jun 20, 2008 | Amana Dryers
Roper REX4634KQ Electric Dryer Logo
69 people viewed this question
Top Roper Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Roper Dryer Expert? Answer questions, earn points and help others
