Question about LG WM0642H Front Load
Our washer has error code LE
The washer turns on fills with water, and that is it.
  • 555 Answers
It means: Latch Error. It doesn't detect the door latch as closed. Latch may need to be replaced.
Posted on May 04, 2010
LE error code on my WM1814CW,it fills with water and drains but doesn't turn.
The LE code indicates a motor overload. The washer will not spin to avoid damaging the unit. First unplug the washer and let the motor cool for 30 minutes. When you plug in the washer, check if the unit has been reset.
The error often occurs if you use a non-HE detergent or too much detergent. In that case, do a Rinse and drain steps. Set the Spin Speed to No Spin by pressing that key several times. When that finishes, open the door and remove all of the clothes in the tub. Close the door and set the washer to Rinse and Spin. Run this program several times until you see no suds in the wash tub. If the LE code returns when the washer is empty, check the drain pump and filter for foreign objects. The error can also occur if you wash too many items at once or too heavy a set of items. Try doing a smaller load in the future.
If the error persists, then the tub motor, bearings, motor shaft or wiring may be damaged. Here is the parts diagram and one vendor's list of the replacement parts: http://www.searspartsdirect.com/lg-washer-parts/model-WM1814CW/3204/0153200/K0810333/00002.html . If your washer is under warranty, contact LG.
I hope this helps.
May 25, 2015 | LG Washing Machines
Le error code
The error code "LE" appears after an unsuccessful attempt to fill the drum with water that results in the water level being too low to safely begin cleaning. The product manual suggests calling for service, but there are several steps you can take to try to resolve the issue at home.
Read more: http://www.ehow.com/info_8696564_maytag-washer-repair-code-le.html#ixzz2zXrmqUO5
Apr 21, 2014 | Maytag Neptune MAH5500B Front Load Washer
Error code LE
The "LE" error occurs when a Samsung washer is in the process of filling but cannot reach the required water level. In most cases, there is an issue with the washer's water inlet hoses. Check that they are installed properly and there are no kinks in the hoses.
Nov 25, 2012 | Samsung WF337AA Front Load Washer
Lg washer wm2077cw had le error and did not work, blew in to tubing connecting tub to a sensor at top and now my reading went from 230 to 256. washer wont stop filling , leaks out front door. what is wrong...
When you blew into the tubing, you destroyed the water level sensor. You will need to change the water level sensor to stop the unit from over filling. That part number is 6601ER1006E. As for the LE error code, you one of 2 things go bad. Either the motor sensor has failed or the control board has failed. Chances are the motor sensor has failed and is the cheaper part to replace. The part number for that is 6501KW2002A
Good luck
Aug 03, 2011 | LG WM-2277HW Front Load Washer
ERROR CODE LE ON LG FRONT LOAD WASHER
LE is a locked motor error. Not to worry as 95% of the time it is just a bad hall sensor (the motor position sensor). For your model the part number is 6501KW2002A.
May 28, 2010 | Washing Machines
Error code is LE. Washer fills up with water and
If water runs in when the machine is OFF but stops when the tap is turned off it means a faulty watervalve.replace water valve. Probably a double valve. Dont mix up the hoses or the wires........Nomess
Apr 18, 2010 | LG WM1812C Front Load Washer
Error code LE Front load washer about 4 years old. This is the first time we had an issue with it. My wife called me and said the water filled but that was it and the error code said LE. This was after she...
That error is a Lock Motor Error. First thing I would do is to replace the hall sensor and check for loose connections going into the hall sensor as well as the main board.
Dec 05, 2009 | LG Washing Machines
Displaying LE
Lg has a water pulsator which rotates while filling up with water. If pulsator is faulty, you will get this LE indication. Pulsator is found on bottom left hand side of unit when cover is removed. 2 clear water pipes are connected to it and there is a small plug in that has 2 wires. Remove plug in first then remove from the pipes.
Sep 21, 2009 | LG Washing Machines
LE error code on LG WM0642 FL washer
LE is a locked motor error code.
It is usually associated with a loose motor connector wire or a defective Hall Sensor.
Mar 08, 2009 | LG WM-2277HW Front Load Washer
Error code LE on LG Wm1815cs
The motor sensor has failed and needs to be replaced.  You will need to call a qualified LG technician to repair this problem.
Sep 14, 2008 | LG WM1815CS Front Load Washer
LG WM0642H Front Load Logo
156 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
