Question about Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654
POWER TRAIN Tractor runs fine on level ground but a little slow but going up a slope the wheels stop turning with the hydrostatic pedal pushed all the way forward with deck running or not it does not make a difference, is there a adjustment for the pedal or is this a internal drive problem
  • 2,100 Answers
No, It sounds like you are low on oil. there is a fill cap on there somewhere, might be a bolt, plug, but you can check it and fill it hyd oil. I had an old Wheelhorse, never had a problem with the hydrostat, worked great. Check it out, hope this helps.
Posted on May 04, 2010
  • Ned  White
    Ned White May 04, 2010
    For got to mention that there is a belt driving the pump, it can get stretched out and slip. Check that out too.
If brakes are not locked together on steep ground the John Deere tractor will kick out of 4wheel drive and run away.
Operating - Operator's Manual - John Deere
manuals.deere.com/cceomview/...A9/Output/OMM139226_A95.html
Slow down before you make a sharp turn or operate on a slope. ... Before starting engine to drive tractor, adjust operator seat to desirable position. ..... If lock does notdisengage, depress one turn brake pedal, and then the other. ... The 2-wheel drive (2WD) / 4-wheel drive lever (A) enables the tractor to be operated in two or ...
A Guide To Safe Farm Tractor Operation - National Ag ...
Nov 23, 2015 | John Deere Garden
Mower quits running when going at a incline or uphill.
Check the gas level.
ride on stalls on incline - GardenWeb
forums2.gardenweb.com > Garden Forums > Tractors
Jun 16, 2009 - When its at a certain angle the engine will stall -or- run terribly ... a little water in ..... I am still perplexed by the uphill/slope mower going down. Craftsman Lawn Tractor Stalls Going Downhill
Apr 4, 2010
Old Wheel Horse Problems
May 21, 2008
Hydrostatic Drive Problems??
May 30, 2006
Problem with garden tractor fuel filter
Jul 2, 2005
More results from forums2.gardenweb.com
Sep 25, 2015 | Garden
Has very little power in reverse.
sounds normal to me none of that type run fast backward
Apr 22, 2015 | Husqvarna 25HP Hydrostatic 54"Cut Garden...
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
Cub cadet i1042 zero turn doesnt seem to want to go forward when turning or even going strait sit moves very slow and when i go up a little hill it stops half way and then creeps up the hill it use to
If it's a hydrostatic transmission, I would have the transmission looked at. You may need to "purge" the system and check the fluid level.
The ones I've done called for the drive disconnects (the rod or lever which allows you to roll the tractor when the engine is shut down) to be in the flow bypass position. They also wanted the wheels off the floor, then the engine to be started, & the direction control to be worked SLOWLY to the front & rear positions 10-12 times. Then put the bypass valve back in its 'drive' position, fire the engine again & repeat the slow cycle of the direction control. The unit SHOULD be quieter now & perform better, but double check the oil level because expelling the air may have dropped it too low.
Jul 22, 2014 | Cub Cadet I1042 42" 18HP Zero Turn Tractor...
What's your problem? wont move forward or back
Go to youtube . Type in your make and model/ forward and reverse will not engage. Should be helpful.
Dec 14, 2017 | John Deere 22HP Hydrostatic 42" Riding...
Gt 245 lawn tractor won't go forward or backward
Check the drive belts first. and make sure the hydro release lever is in the correct position. If it is not- you can push the lawn tractor and have the rear wheels turn. It sometimes doubles as a "Forward" "Neutral" "Reverse" lever on other brands of lawn tractor.
The belts should be in their guides and pulley grooves- check to make sure it does not have a hidden break by having the engine off, and pulling on the belt.
Lastly, check to make sure the hydro itself is not out of oil or low on oil. It uses low viscosity "HyGard" oil. Capacity if you drain the old oil out and refill is 4.6 quarts. Look for a leak if the level is low.
If it still does not move, make sure the levers are set so you are in forward motion positions, and push- if the rear wheels move there is a problem in the hydro unit.
Apr 07, 2012 | Garden
I have a John Deere LT155. When you let off of either the forward or reverse pedal the tractor comes to an abrupt stop. It will actually lock the wheels.
Hi, most likely the brakes are hanging up. Follow the brake pedal path to the rear of the mower, it is attached to a small arm on the side of the diff that is probably locked forward. This lever and the pins behind it need to be freed up so the lever operates forward and backward freely when the brakes are applied and released. Hope this helps, regards Phil.
Jun 01, 2011 | John Deere 22HP VTwin Hydrostatic 42"...
John Deere L120 transmission high pitch noise and no forward move
Try jacking the unit up. Start it up and try moving pushing the forward and reverse back and forth and see if it does it then. It sounds like an oil way in the hydrostatic unit has a check valve stuck. Of course make sure that the fluid lever is up. Hope this will help you. donnyb60
Mar 23, 2009 | Garden
Husqvarna Lawn Tractor - 54in. Deck, 26 HP, Model# LGT2654 Logo
328 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
