Question about Kenmore HE3T Washer
Kenmore HE3 washer water flows out of bottom
I have a Kenmore HE3 frot load washer. When I start it, water gushes out of the bottom.
  • mwinks26 May 07, 2010
    Thanks,
    It is the door seal. When I took the kick panel off, the door metal seal ring fell out. Now I just need to figure out how to re-install the ring.
  • 530 Answers
Check your door seal first.,
take your kick panel off
3..... 7 millimeter screws or t15 torques
check your hoses
check your drain
more than likley it's your door seal
you can also take the lid off same way you took the kick panel off
let me know what you find
Posted on May 04, 2010
Testimonial: "Thank you, It is the door seal. When I took the kick panel off, the doors metal seal ring fell out. Now I just need to figure out how to re-install the ring."
My kenmore elite quite pak 2, HE3 shows F then H and quits the cycle.
The FH error code mean that no water was detected entering the machine.The things to check are,a pinched or kinked water hose into the washer, the faucets off or if faucets on make sure that something has not restricted the water flow through the hoses..this will be possible espically if they washer is connected using "AQUA FLOW FLOOD STOP" ..the internal flood stopper will cause water flow to be cutoff for no reason. Also check the filter screens on the back of the washer where the fill hoses connect to,for debris in the screens.
If all above checks ok i would suspect the part called the FLOWMETER was defective in the washing machine.
GENE
Aug 28, 2011 | Kenmore 42822 Front Load Washer
I have a Kenmore Elite Quiet Pack 2, HE3, model number 110.45872 400 front loading washing machine. When I start a cycle it stops and letters H and F alternately show on the screen. What does this mean?
i just had this problem... i did the following (should only take 30 minutes) take the panel off, that is located below the front door,, there are 3 small srews located at the bottom that hold this... then you will see the water pump, the water pump has a access srew plug, when you unscrew this, its like a filter, you may see stuff, like coins, socks, etc, remove and clean it, then put everything back... this should fix the issue.
Oct 11, 2010 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Water leaks from bottom.
This model is OLD , time to get a new one
May 22, 2009 | Kenmore 42822 Front Load Washer
Kenmore HE3 washer
The water valve is not closing fully. You will need to replace the water valve.
Mar 31, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3 will not hold water leaks into the pedestal
run you fingers into the door boot and inspect for holes ,, that probably what it is ,,,,,,big tear
Dec 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore HE3 will not HOLD water, drips out into the pedestal
check to see if there are any rips in the door seal,then take the bottom of the washer off you will see 3 screws holding it on. see if the water is coming out of the pump that is right behind the panel that you took off.
SHOWS F02 ERROR CODE
your drain pump is clogged. you must take the bottom panel off to acess. there is a draincock that you will unscrew but be advised that there will be a gush of water and then you will discover the small items blocking your drainflow.
Nov 11, 2008 | Kenmore Elite 45986 Front Load Washer
Error Code for Kenmore HE3
The "F" variables (F4-F16) are for electrical problems. You should select Pause/Cancel twice then select Drain/Spin if there is excessive water in the washer. Re-select cycle and press start. According to the manual, if the problem remains, call for service.
Dec 27, 2006 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore HE3T Washer Logo
141 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
