Question about Troy-Bilt Pony Garden Tiller
Leaky tine seal - Troy-Bilt Pony Garden Tiller
  • onekawrider May 05, 2010
    I have the parts I need ordered but I can not get the tines off on the right side I have hammered, used a slide hammer and it is just stuck, any suggestions
  • Kelly
    Kelly May 11, 2010
    I take it the tine drive shaft is leaking where the shaft passes through the lower part of the transmission case. IF you provide a model and serial number I can point you to the source for your parts. The tines will have to be removed and the shaft cleaned up to remove and install the new parts. Kelly
  • 3,740 Answers
Hi, On the stubborn ones I use large wood screws in as many places as possible to lift it out. (some times as many as 6 screws.) You put them through the center part of the facing. You may have to use a smaller screw to make a hole for the bigger screws. Then screw them all evenly to lift it out.
If that does not work I drill holes in it until I can break the old seal into pieces and then pry it out with a screwdriver. Some of them can really be stubborn. The key is to be careful if you use a drill because if you don't get all of the drill shavings out it will cut the new seal you installed.
Hopefully you do not have the kind of seal that is installed on the inside of the gear case where the case has to be separated to remove the seal. I have not seen one of those since the old Wheel Horse Tillers. Sorry to hear of the struggle your having but I think with persistence you will get it out.
Kelly
Posted on May 05, 2010
  • 4 more comments
  • Kelly
    Kelly May 05, 2010
    I am just doing a follow up. Were you able to pry the old oil seal free per instructions?
    Kelly
  • Kelly
    Kelly May 06, 2010
    Seems that your still having no luck in removing the seal and took that frustration out in the form of a lousy rating. I just passed on about 35 years of experience and got rewarded with a 1 thumb rating. It does at times make us wonder why we spend so many hours a day for free attemting to help people.
    Last and worst case scenario is that you take a mini-chisel or make one out of a screw driver and hammer through the face of the seal and pry it out with what ever it takes. Needle nose, vise grips,
    scredriver or more chiseling. etc.
    If there is anything I can possibly pass along to help you that I can think of I will pass it along. At the moment you already have what I would attempt and do in a place of business for a customer in order to try and free the pesky oil seal.
    Again thanks for giving FiXya the opportunity to try and assist you.
    Kelly
  • Kelly
    Kelly May 06, 2010
    In my first "clarification response" I asked for a make and model number. I did say that with that info I could point you to a parts source. I also need that information so I can look up exactly what your working on. If you want me to help you I need that information.
    Thanks,
    Kelly
  • Kelly
    Kelly May 06, 2010
    I must apologize for not seeing that you were having problems with the tines on the RH side not wanting to move.
    If you have the mounting bolt out take either a tow strap or a chain and connect the chain 90 deg from where your going to pry with a long bar being very carfeul not to bend the tines and then change directions in trying to rotate the tines with the chain / tow strap and bar. You can also use a large puller with u-bolts and the chain or tow strap. The U bolts have to cross / oppose the pulling force of the puller by laying them over opposite sides of the puller so that they do not jump off when tension is applied.
    After that..... well... you probably do not want to hear this but it is going to take a torch to heat the tines mounting area to free it. I am not sure if a hanld held propane torch will get hot enough.
    Kelly
  • Kelly
    Kelly May 06, 2010
    If you have not already used a "penetrating oil" to try and losen the tines from the shaft you should do so. Liquid wrench is one of many brands. Spray it on and let it sit for at least an hour then spray it again and attermpt tine removal. WD 40 will not losen it but will lube the shaft for tine removal.
    Kelly
  • Kelly
    Kelly May 06, 2010
    Kelly
  • 8,404 Answers
Replace it ... complete instructions in your owners manual.
Posted on May 04, 2010
  • A Miller May 05, 2010
    Tines or holder? The tiles will come off if you remove all the bolts ... Remove the cover if you have not.
    Keep a nut loosly on the shaft to protect them. Tap the holder side to side, up and down and laterally again and again ... it will come off but it will require some work.
Best way to fix the problem
look on the shafts the tines ride on and see if the bolts broke off
Mar 28, 2012 | Garden
Purchased hahn tiller 5hp briggs stratton with broken tines and bearing and seal leaks. where can i get parts
Parts for the engine can be purchased from briggs and stratton
The bearings and seal can be purchased from Napa. Dimensions are required for the bearing inner and outer diameters. (Caliper time)
The tines.... I don't know. My experience on the tines is you either find an old Hahn Eclipse Tiller for parts or you find a good craftsman that can make one. I had to make a LH tine using the broken parts, some forge hardened bar stock and a welder. The tine manufacture took much longer than expected...!
Kelly
Apr 23, 2011 | Garden
The oil seal where the tiller attachment fastens to the tiller is leaking how do i remove the seal
IF THIS IS A WALK BEHIND TILLER OR FRONT TINE TILLER. THERE SHOULD BE PINS OR BOLTS HOLDING THE TINES ON THE DRIVE SHAFT REMOVE THESE AND PULL THE TINES OFF THE TILLER. THEY MAY GIVE YOU A HARD TIME GETTING THEM OFF SO DON'T GIVE UP. ONCE YOU GET THE TINES OFF YOU SHOULD SEE THE SEALS YOU CAN POP THE OLD ONES OUT WITH A SCREW DRIVER CLEAN OUT THE SOCKETS WHERE THE NEW SEALS WILL GO REPLACE THE NEW SEALS GENTLY WITH A SMALL HAMMER TAPPING THEM IN EVENLY AND TRY NOT TO BEND THE SEAL
Feb 05, 2011 | Garden
I cannot get my oil seals of my rear tine tiller It is a Troy Bilt 5.5 hp and I got the left side off but the right side tine attachment will not budge any suggestions please
Have you tried soaking the shaft area with either PB Blaster or Deep Creep penetrating oil. Try this for a few days before trying to tackle getting the tine attachment off.
Jan 26, 2010 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
I need to replace the seals on my Troy-Built Pony tiller. 6 hp, ser.# 121811201149. I can not seem to remove the tine shafts. I have pulled the bolt thru the shaft but cannot budge it. Does anyone know...
I presume you opened the port and removed the grade 8 placement bolt? If you have then you need to polish the shafts with 400 then 800 sandpaper, clean then lube them before trying to slide thru the support bearings. If your tine shaft is bent? your screwed, or just remove the shaft seals with a screwdriver and replacing them without removing the shaft. REmember to put a thin coat od RTV arround the outer lip to help make a better seal
Nov 15, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Replace tine shaft oil seals - Junior model
on my pony the disc came off when i removed all of my tine shafts. then i pulled the old seals out an drove the new ones in
Apr 27, 2009 | Troy Bilt, Tuffy, Rear - Tine Tiller, 4.0...
Leaking gasket of tining belt
do you have a 3.1L V6? The timing cover gasket seals the timing components, it is located behind the belt drive system (alt, a/c, p/s etc.) all of these components must be removed to change this gasket, also the oil pan lower seal gets changed at the same time. The oil pan gasket includes the rear pan seal and the side seals and on for the rear of the pan, the engine must be lifted out of it mounts to change this gasket. It takes time to do these repairs and each shop has an hourly rate per hour on labor. The cost of the parts will be relatively the same at any shop, labor will differ. I hope this helps to answer your questions.
Mar 26, 2009 | 1989 Buick Regal
How to remove rear tines to replace seals ?
The tines sometimes get frozen to the shaft. You might try penatrating oil and use a heat gun or hair dryer to heat to loosen.
Also tap wiht a hammer around shaft.
Mar 19, 2009 | Troy-Bilt Garden
Oil seal for rear tine shaft
The serial number is located on a flat spot just above the right wheel shaft where the gear housing and the top gear cover meet. It will be a six digit number stamped in the metal.
Frank
Mar 11, 2009 | Troy Bilt Pony 6.5 Hp Rear Tine Tiller
Troy-Bilt Pony Garden Tiller Logo
235 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Jim Parker
Jim Parker
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
