Question about Canon PowerShot SD400 / IXUS 50 Digital Camera
My cannon sd400 will not connect to my computer to down load images. The camera is NOT reconised by the computer as even being there.
    Brigadier General:
  • 11,967 Answers
Do what the pros do...use a card reader.
Posted on May 04, 2010
CANON POWERSHOT SD400 5.0 MEGAPIXEL DIGITAL CAMERA. CAMERA POWERS ON BUT THE LCD SCREEN REMAINS BLACK
if there is image formation u will find image on the lcd,defect with the formation,so CCD and shutter must be chaqued.
Mar 06, 2010 | Canon PowerShot SD400 / IXUS 50 Digital...
MacBook Pro won't recognize canon powershot SD400
Hello. You need to probably reinstall the drivers. but first you have to remove the drivers that are all ready installed. first unplug your usb cord. then to remove the drivers allready installed,, on your computer, press start, then when the box open's up, then right click on computer. another box will open up. then left click at the bottom of that box on properties. another box will open up, then click on device manager. after you click on device manager another box will open up with all your devices. look for the previous camera you had installed. it might be under imaging devices. once you locate that, then right click on it. then choose uninstall. Make sure you have your new software loaded in your cd/dvd rom drive. after it is done uninstalling, just restart your computer. at the bottom right of your screen, it should say, found new device, it will ask you from where do you want to load the new drivers for it. click on the drive that contains the software. it then will load your new drivers up. It then should communicate with your camera. Hope this helps. Ron
Sep 08, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Hello, All of sudden my comuter does not want to reconise my cannon g9 camera and I am unadble to download my pictures. Our camera is only one and a half years old and we have down loaded pictures many...
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jul 07, 2009 | Canon PowerShot G9 Digital Camera
How to down load the pictures from camera with microsft 2003
It's quite simple .Just connect your canon camera to your computer .when it's connected open the folder and simpley copy all jpeg images and past it where every you want
Jun 23, 2009 | Canon PowerShot A85 Digital Camera
USB connection with the camera causes computer to crash.
Try using a different USB cable. The connections between cameras and computers usually are problematic. A card reader will allow you to download the pictures from the SD card, without problems and saving your camera's battery power supply
May 04, 2009 | Canon PowerShot A560 Digital Camera
Dropped my canon powershot sd400, now it won't work fine
Hi there, there is two possibilities. The first one is to check the lens barrier covers at the front of the lens are opening correctly. If the front cap is dented in any way it may prevent them from opening fully when switching the camera on. If this is the case, you may be able to manually assist the cover by gently pushing them open with something soft like a cotton tip. This wont fix the problem but may temporarily allow you to use the camera. The other possibility, is that the shutter assembly inside of the lens has been damaged. If you gently shake the camera you may be able to see something shifting across the image on the screen or even when looking through the front of the lens itself. If this is the case you would need to have a service centre replace the lens for you. The same applies for the front barrier however that repair would be much cheaper. Best of luck!
Apr 14, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon Powershot SD400 won't upload pics to computer
Mar 30, 2009 | Canon PowerShot SD400 / IXUS 50 Digital...
Camera turns on but shutter does not open. green light comes on then it beeps twice and shuts down. You can view pictures fine though
You mean SD400 camera doesn't show any error sign and it just doesn't have live view to shoot picture?
If yes, its problem of bad CCD imager and Canon will provide free of cost repair facility for SD400 camera.
Click Canon CCD Advisory for details.
Oct 24, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Cannon sd400 power shot
Sounds to me like you have a broken LCD screen. This is unfortunately very common in the SD200, SD300, and SD400 cameras. Because an LCD display is made up of a few sheets of very thin glass, they tend to break rather easil and then the "dye" leaks out, hence your feather pattern.
If you feel up to taking your camera apart, you can purchase a replacement screen on eBay for around $60-$80. If you don't feel up to trying to replace it yourself there are people on eBay who offer repair services for broken LCDs and they typically charge between $80-$100.
Apr 10, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Canon PowerShot SD400 / IXUS 50 Digital Camera Logo
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
