Channel no showing on tv
Since my boys have had their x box on the tv there is a large green "9 AV1 and a symbol showing underneath (like a square with an arrow pointing into it) in green taking up a lot of space on the left hand side - how do I get rid of it?
  • xxjanexx Mar 26, 2008
    I didnt know what a PIP was so I thought I would press every single button on the remote, I was guessing thats possibly all the boys did anyway. There was a button with i and a + on it and it did the trick! Whats a PIP then?!
    Cheers
    Great site I'm a right techophobe!
    Brigadier General:
  • 6,966 Answers
Without knowing the brand and model of the TV, I can only venture that somehow the PIP feature has been engaged. Disable the PIP (using the remote).
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on Mar 26, 2008
  • Louie  Role
    Louie Role Mar 26, 2008
    Hi again xxjanexx,
    Thank you for your postback and additional information.
    PIP stands for Picture in Picture that is you have the standard display then a smaller display superimposed on the larger one. This could be another channel while mainly watching another channel or could be your video/DVD/game input while watching regular TV programs. Additionally, the smaller display/box could just be basic information.
    Sorry but without knowing your TV's specific brand and model, I would not even venture a guess on the i and a +.
    Am glad that your concern is gone.
SOURCE:
AV1 input question
The TV probably defaults to the RF channels. If it is an analogue only tuner model then it will go to the last used/programmed RF channel.
Sep 04, 2014 | Televison & Video
How to change the channel my Sony Trinitron TV turns on to?
hit menu button on your remote, navigate to channel setup menu. on the sub-menu, set channel fix to your channel that you require. now when your tv powers up this will be the default channel. if this doesn't fix your issue then try cycling through video inputs tv/video button on your remote.
Nov 10, 2013 | Sony FD Trinitron WEGA KV-24FS120 24" TV
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
The VCR won't record from a digital terminal.Connection Made according to instructions.Both VCR &digital terminal on channel 03.If the digital terminal is by-passed the recorder works fine.
use scart lead put one end into the digital ( BOX or TV ) out put ( AV1 or AV2) and the other into (AV1) on vcr then change the mode so AV1 shows on vcr display
you can do this by pressing button on remote marked with ( input / source or a picture with a arrow pointing into a tv
you can only record the station that the digital box or tv is on if you turn over vcr will record that station
Dec 16, 2009 | Hitachi VTFX6510A VCR
How do i connect dvd recorder to tv only receiving sky channels through skybox
If you have two scart sockets on your tv,then connect a scart from av1 on the dvd into the tv,then connect a scart from the sky box into av2 on the dvd,your recording channel on the dvd will be av2.
If you only have on socket on the tv,then connect a scart from av1 on the dvd into the sky box,your recording channel will be av1,connected like this you may have to turn off the sky to watch dvd`s.
Oct 30, 2009 | Televison & Video
I have an external DVD Recorder / Player attached at my TV via AV1 and an external DVB digital TV box linked to AV2. Both external units are linked togerther to enable direct recording from the external...
I have a LG tv set. When i press the tv/av button on the remote my tv shows av1, av2 earlier but now it is showing only av. So i am unable to watch my dvd player. Need help.
Jul 04, 2009 | LG 37LG30 37 in. LCD HDTV
I have a Direct TV box and just bought a Direct TV remote with RF antenna. I have attempted to program the remote to work in RF mode, but for some reason it's not accepting the programming. The remote...
Connect the supplied anttena on the reciever. Once you have done that, then:
1. dtv symbol device
2. press and hold MUTE & SELECT for two blinks
3. enter 9 6 1
4. press CH UP
5. enter the last 6 digits of the Receiver ID #, found on a sticker in the access card compartment
6. press SELECT
Now the receiver will accept both IR and RF, but the directv device on the RC32RF remote will only emit RF signals. The av1, av2, and tv are all still IR only.
Jun 22, 2009 | Televison & Video
To suppress the AV1 symbol on screen
on original sony remote press the DISPLAY button once
Mar 26, 2008 | Sony FD Trinitron WEGA KD-32FS130 32" TV
Black Square Covers 80% of screen on most channels on TV
have your tv checked by a tech.probably your chip the eprom needs to be reset by lifting it up from the board and resolder back.some one could have put in a code for those channel.good luck.
Dec 27, 2006 | Toshiba CF35E50 35" TV
Televison & Video Logo
138 people viewed this question
Top Televison & Video Experts
Ekse
