Question about Canon PowerShot A720 IS Digital Camera
My a720 is on auto but won't take a pic everytime just the bright orange light on the front and nothing happens
  • Canon Master
  • 3,866 Answers
Soundsl ike you got a autofocus issue and this needs to be taken care of by a camera shop. The issue here is the auto focus sensor the normally causes the camera to not turn on or to turn on and the breif off again. I would have it looked at by a camera shop,
thanks and please do leave positive ratings and feedback for your free answer today.
Posted on May 04, 2010
Had a serpteen belt replaced . when picked up auto air bag light was on . where is mogual or switch located????
A serpentine belt being replaced should have nothing to do with the Airbag. Unless there was a careless animal working on it.
There would be one or two sensors up front. On the radiator support or the frame rails where the bumper bolts to.
There will also be a module/sensor inside the car in a central location like under the dash or center console.
But even an airbag that has been unplugged will trigger the light.
If you go to check all the airbag items just look for the stuff with the bright yellow (or orange sometimes) wire loom or tape. That bright loom (or tape) is used to identify wiring for the airbag system.
Aug 24, 2011 | 1997 Buick LeSabre
Hi i have a hpg62 and everytime i use it the curser always freezes i have tried re installing. i have tried to go onto change the properies on the synaptics but it still happening because i dont know why...
Look at the touchpad, in the upper left corner. Is there an orange light on? If there is, double tap that light and it will turn off, and re-enable the touchpad. If it isn't, try double-tapping twice to turn the orange light on and off. When the light is on, it means that it won't use the touchpad, that way you don't bump it and move the mouse on accident.
Aug 19, 2011 | Computers & Internet
Poweredge SC 1420 won't come on, it keeps blinking an orange light on the power button and the lights below the power button the first 3 indicator lights are orange. I tried unplugging and plugging it...
hi,
I have several of these and most often there power supplies blow. since they come by default with only one powser supply. the system won't start
I would start there as most other problems will generate beeps.
GL
hope this helps
Don't forget to vote for me
Thank You
Jammer
Aug 17, 2011 | Dell PowerEdge SC1420 (SC1420MIN) Server
It wont turn on, everytime i stepped on foot padle, i hear click,but nothing happen, when i press on GFCI test switch,the orange light come on, i don't know what's wrong?
The orange light on the GFCI is telling you there is a low-grade short from HOT to ground. There's a loose or frayed wire hitting metal somewhere!
The foot pedal is MY suspect.
Jan 29, 2011 | General Wire MR Mini-Rooter Basic Unit
I have a cannon powershot a720is and will not take pictures in low light conditions, when i press the button to take picture the orange light comes on, but it does not take picture. When in a bright light...
This sounds like a flash issue.
From page 64 of the user manual, make sure that you have the flash enabled on the camera. Page 64 shows you how to enable and disable the flash. Most likely, the flash was turned-off by mistake and is causing your issue.
If the flash is enabled and you're still having a problem, then there's a good chance that the flash feature has failed on your camera and will need to be repaired.
Dec 29, 2010 | Canon PowerShot A720 IS Digital Camera
Lower light blinks on everytime I try to print anything and nothing prints
Check for any paper jams, I think the orange light mean that there is a error and therefore cant print, check incartriges and other areas inside
Apr 13, 2009 | HP DeskJet 845c Printer
Printer won,t work
I can't get my 1210 hp printer to turn on
May 01, 2008 | HP PSC 1210 All-In-One InkJet Printer
Canon A720 IS
This is normal and not a malfunction.
It is caused by the bright light and will only be recorded in video mode.
Try to keep your camera aimed away from bright spots. There is nothing you can do to completely avoid the pink lines, but just be reassured that there is nothing wrong with your camera.
Hope this helps!
Mar 22, 2008 | Canon PowerShot A720 IS Digital Camera
Indicator ight
If it turns orange, it only means that the flash will be used. Green is when the flash will not be used.
Do you get an orange light?
Hope this helps!
Mar 04, 2008 | Canon PowerShot A720 IS Digital Camera
Help with red flash?????
Do you mean, the AF Illuminator (the bright orange/red light that appears before the picture is taken)?? If so, all have to do is click on menu, scroll all the way to the right (into the setup menu) and go to the camera icon. From there, go down to the AF Illuminator and switch it from "Auto" to "Off".
Hope that resolves your problem!!
Nov 29, 2007 | Sony Cyber-shot DSC-W35 Digital Camera
Canon PowerShot A720 IS Digital Camera Logo
488 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
