Question about HP Photosmart C6180 All-In-One InkJet Printer
HP Photosmart C6180 Moire lines
HP Photosmart C6180 All-in-One printer will make clean copies of photos internally, but scanning to the computer results in moire lines, especially in the dark tones. The source image is a film photograph - not inkjet. Installed current "full" software version 13.1.0. Never saw this problem before I upgraded to Windows 7 Home Premium (with a different driver, of course.) Full uninstall-reinstall didn't help.
3 Suggested Answers
Riztech
  • 731 Answers
SOURCE: My scanner always scans with blurry lines across scanned images from it
I believe that you are trying to scan via HP solution center.
Did u tried scanning from Scanners and Cameras in control panel, and did u notice any lines?
If u get the same lines, we have to remove the USB Composite device and imaging device drivers.
1.Right click on MY computer ->Properties->Hardware->Device manager.
2.You will get Device manager window popping out.
3.Check for Imaging Devices, click on + sign, then u will see "hp photosmart c3100" right click on it and click Uninstall. Then, Scroll down to "Universal Serial BUS controllers".Click on the (+) sign.
4.Check for the "USB Composite Device" and right click on it, click Uninstall.(IMPORTANT NOTE:wE HAVE TO UNINSTALL THE PRINTER'S USB COMPOSITE DEVICE, TO KNOW WHETHER IS THE PRINTER'S USB COMPOSITE DEVICE, RIGHT CLICK ON USB COMPOSITE DEVICE AND PROPERTIES,look for wat location says, Eg -LOCATION : HO DESKJET F300)
5.Disconnect the USB and reboot the PC.
6.Connect the USB after reboot, you will get popup "Found new hardware".Then the Drivers will be installed Automatically.
7.Try scanning.Please let me know after following the steps!
Posted on Feb 09, 2008
  • 100 Answers
SOURCE: printer keep restarting. c6180 hp photosmart
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This also fixed the ink system failures the printer was having. A similar fix may apply to other printers produced by HP around this time. acca299.jpg
Posted on Oct 03, 2010
Unable to scan, copy or fax message on HP C6180
Please follow the steps and then let me know the results:Click Here
May 23, 2010 | HP Photosmart C6180 All-In-One InkJet...
I get a line through my scan with my hp photosmart C6180, What can I do?
If it is a vertical line, you could review the HP support documentation for your Photosmart C6180 here:
HP Vertical Lines Bands Streaks
For horizontal lines, try using the HP "toolbox" to clean the print heads. You may need to repeat this process until you achieve a satisfactory result.
Dec 27, 2009 | HP Photosmart C6180 All-In-One InkJet...
Hp photosmart c6180 all in one printer will not scan or copy
The scanner bulbs ahve gone bad.U need to get it them replaced.Before that try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Mar 25, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer will only print, not copy fax or scan
It is possiblethat the all in one solution software you used in XP doesn't work with Vista, after some update or other. You did the right thing by uninstalling and reinstalling. Make sure you have the correct driver from the HP site..
But you can still scan and copy by using Windows Photo Gallery.
1. Click on files tab at the top in Window Photo Gallery.
2. Click on import from camera or scanner.
3. Highlight your scanner icon (ie HP C6180) then click import.
4. New scan window will popup, now you can preview or scan using this basic looking Vista utility.
Hope that helps.
Chris (ziraffa)
Jan 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 ''Unable to scan, copy or send a fax''
Check the following steps:
Connect the printer directly to the wall outlet and
1. Verify that the unit is switched on. Unplug the all-in-one from power and disconnect the connection port.
2. Wait 30 seconds.
3. Plug in the power only.
4. Repeat steps 2-4 two more times.
5. On the third time after plugging the unit into power, reconnect the connection port from the all-in-one to your computer.
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold # and 6 while plugging in the power cord
Try to check the result.
Regards,
Sagarjd
Nov 20, 2008 | HP Photosmart C6180 All-In-One InkJet...
How do I scan a 35mm film negative with my HP PhotoSmart C6180?
I regret to inform that hp Photosmart C6180 does not support scanning negatives.
Regards,
Sagarjd
Nov 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
Black Line
what printer? c6180? press setup button - tools - clean printhead
Apr 15, 2008 | HP Photosmart C6180 All-In-One InkJet...
Black line when scanning though auto feeder
pls clean the side glas of scnner with tissue paper ther is two type of glass is there one is a4 size and second is normal slim one so pls clean the slim one with wet tissue paper and see is ti clean .
bye
Nov 05, 2007 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 All-In-One InkJet Printer Logo
81 people viewed this question
Seeker5211
Seeker5211
