Question about Amana ABB1927DE Bottom Freezer Refrigerator
Top part not cooling
Does the fan in the freezer also push the cold air into the ref section or does it have a seperate fan. The fan in the freezer is blowing cold air is it possiable the defrost element has let frost build up in the duct to the ref section?
  • James Coley May 04, 2010
    There is no air exiting from the vent in the top section repeat no air
    So I dont have to do trial and error are the small numbers colder or warmer in the freezer? In the ref section do lower or hgher numbers lower the temp?
  • 6,826 Answers
This is most likely what has happened,yes the freezer pushes the air into the fridge compartment,if the freezer control is up to a cold setting,this could be the problem,turn the freezer compartment down to a warmer setting,this will not effect the temp in the freezer,but it will deflect the cold air to the fridge compartment,then adjust the thermostat in the fridge compartment to a colder point,this is the true thermostat for the unit.
Posted on May 04, 2010
  • 1 more comment
  • Ronny Bennett Sr.
    Ronny Bennett Sr. May 04, 2010
    You have ice blocking it,so the coils are iced over,I would unplug it,and deice it,if you can take apart the inside of the freeing unit,you will be able to tell,most likely the drain under the coils has iced over,they clogged up with debris,and then the ice can not drain after being melted,then it builds up and this happens,clean the ice out of the drain with hot water,there will be a mess,then blow threw the drain with air pressure,then reassemble and adjust everything like I mentioned,and see what happens.
  • Ronny Bennett Sr.
    The freezer does not adjust temp,it just deflects the air to the fridge,the lower,or warmer setting means that the colder air will be deverted to the fridge,but the freezer will not be affected,but it will make the fridge colder,then the adjustment to the temp thermostat will keep the compressor on longer making the whole unit colder.
  • Ronny Bennett Sr.
    I would go in and fix the problem,then set the settings after you put it back together,with no air flow,the coils are froze over.
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
Maytag refrigerator not cold.
do you have a full frost pattern (coating) on freezer coils or see a ice ball, if ice ball Leak in system or bad valve in compressor. not worth fixing. go on (repair clinic .com).
you have a dampener and a fan to let the cold air go to all the areas check to make sure fan is running push in light switch in freezer and llisten for fan could be problem or no power to fan from main control board.
Dampener is flapper door that lets cold air from freezer go into ref. section
are your doors sealed, gaskets, frapper between door on ref section closing.
also your return air ducts need to be clear of ice, is your ice maker working that means that it is below 10 degees and repairable.
May 03, 2014 | Maytag (MFI2568AEW) Bottom Freezer French...
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
I have a 23' free standimg dispensing side by side ref. my ref is not cooling but the freeze part is working
when you open the freezer door do you hear the fan blowing?all that happens is the evaporator coil in the freezer gets cold,the evap fan blows the cold air from the freezer and into the fridge side,there are ducts on the bottom left side where the air return sto the freezer,if that's blocked the fridge will get warm,also if the fan is blowing depending on your model you could have a damper,it's in the fridge section up top where the cold air blows into,all it is is a door that opens and closes to let the air in when the fridge section gets warm and then it closes when it's cold enough,if the damper is bad it won't open and let the air in,sometimes it gets stuck in the open position and things start to freeze in the fridge section.if you can't figure it out send the model number and i can see what model you have,open the fridge door,look up on the right side near the ceiling and you should see a tag with the model number.good luck and have a great weekend.also from the bottom up in the freezer,remove the second bin of food and touch the back inside wall of the freezer,if there's frost or like snow on the back inside wall of the freezer you have a defrost problem,let me know what you find.
Aug 07, 2012 | Kenmore Refrigerators
Refigerator is blowing warm air
EITHER THE FLAP THAT SEPERATES COLD AIR FROM FRIDGE TO FREEZER IS CLOSED
OR
COILS ARE CAKED WITH DUST
OR
FREON IS WORN OUT
Mar 31, 2009 | Refrigerators
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Refrigerator not cooling.
Hi and welcome to FixYa,
Almost always, your described problem could be either:
  • evaporator fan/blower is faulty; or
  • air passgaeway blocked or vent is blocked or closed.
The refrigerator section gets its cold air from the freezer. If the freezer is working then the frozen air would have to be drawn to the refrigerator side by the fan. If the fan is not working or the air passage way is blocked, then no frozen air would be moving towards the refrigerator side. result would be as you described.
In some instances, it could be the thermostat of the refrigerator but this would be least likely.
Good luck and thank you for using FixYa.
Feb 22, 2009 | LG LRTBC1825T Top Freezer Refrigerator
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Ge profile buttom freezer cold refrigerator hot
Dec 17, 2008 | GE Profile Arctica Stainless Steel Top...
Refrigerator/freezer not staying cool
If there is no frost on the freezer side it may be low on coolant.
Dec 03, 2008 | Admiral 26 cu. ft. Side-By-Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
91 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
