Question about Dryers
No heat only cold air - Dryers
  • 784 Answers
Heater element burnt out. Need to replace the heater element. If heater element is not on, the blower only blow cold air.
Posted on May 04, 2010
Blows cold air turn heat on
Search Results
    07 Tucson heater blowing cold air - Hyundai Forum - Hyundai ...
    www.hyundaiforum.com > ... > Vehicle Line Up > Hyundai Tucson
    Dec 16, 2009 - I have a 2007 Tucson, when you turn on the heater it only blows hot air... Join Date: May 2005 ... a low coolant level will exhibit the first stated symptoms of no heat/low heat at idle and increased heat at cruise due to an air ...
    Denlors Auto Blog » Blog Archive » Car Heater Blows Cold ...
    www.denlorstools.com/autoblog/.../car-heater-blows-cold-auto-service-ti...
    Oct 10, 2009 - When a car heater blows cold air, there are several possibilities that should ...... On my Dodge Neon when I turn on the heat it blows out cold air.
    Heater blows only cool air...even w/ defroster on : Buick ...
    repairpal.com > Problems > Buick > LeSabre
    ... Cadillac, Chevrolet, Chrysler, Dodge, FIAT, Ford, Geo, GMC, Honda, Hummer,Hyundai, Infiniti, Isuzu, Jaguar ... I'll turn up the temp on the dual control to get heat,
Jan 28, 2016 | 2005 Hyundai Tucson
I have a 2008 Toyota Corolla and heat on the left side and the right side is cold, what to do?
Heat is blowing on passenger side, but cold air ... - RepairPal
repairpal.com > Questions > Dodge > Ram 1500 > 2002 Dodge Ram 1500
Dec 7, 2009 - When I turn on the heat, the passenger side is receiving warm/hot air but ... blow hot air on the drivers side and it would get cold right away. about a week ago... I have a 2008 Dodge Ram 2500 SLT. ... Regardless of the settings cold air blows from the left vent and on the floor on driver and passenger sides.
Temperature Blend/Recirculation Doors May Fail and ...
repairpal.com > Problems > Jeep > Grand Cherokee
2008 Jeep Grand Cherokee143,000Visitor. I get cold air on driver side and warm air on the passenger side. Upvote (29) ... right side air is always at the coldest. no heat on the right side and air temp will not change, left side works good. .... Models: · Honda Accord; ·; Toyota Camry; ·; Honda Civic; ·; Acura TL; ·; Toyota Corolla ...
Heating and AC Temperature and Air Delivery Mode Do
Jan 16, 2016 | Toyota Cars & Trucks
HI-i have a coleman heat pump- on defrost it gives cold air- not normal. thanks
Do you have electric heat strips for auxillary or backup heat? When the heatpump goes into defrost, the electric heat strips or whatever your source of auxillary heat is, should come on to keep you from feeling the cold air. When the heat pump is in defrost it is essentially operating in the A/C mode, that is why you will feel cold air if the auxillary heat isn't working. You need find out why the auxillary heat isn't coming on if it isn't. It could be do to a bad seqencer or a burnt out element.
Mar 11, 2011 | Heating & Cooling
Heat not rising above 62
It sounds like you have a 'heat pump'?-- and you are trying to heat in these cold snaps-- when the outside temperature is down near freezing?
If so-- Heat pumps do not work well that cold!-- so if your system was marginal at heating, when the outside air is 40 or 50 degrees F-- you quickly run out of 'heat' in the cold outside air, to move the refrigerant in the heat pump with any heat wrung out of the COLD-- to bring heat into your house!
Make sense?
Please tell us more-- like how your heat pump worked last year, etc.
Mack B
Jan 08, 2011 | Heating & Cooling
REPLACED BOTH ELEMENTS GOT HOT WATER FOR 1 SHOW THEN IT GOT COOLER AND COOLER AND NOW ITS COLD ONLY?
Find a reputable HVAC contractor to do a room by room analysis with heat and cooling loads calculated and units sized and duct requirements and compare to what you have.
The air not being cold is not necessarily an indicator of anything malfunctioning. High efficiency units for instance don't produce cold air.
Since you have had someone look at it, the duct work may be collapsed which restricts air flow or uninsulated which warms up the supply air. Either one is a possibility. Any Cox Cable guys been stompin' around your attic lately? Wouldn't be the first time.
Usually, when the air coming out of the vents is not cold enuf it's because your freon level is low. Probably leaking, but they can usually recharge the freon and it will work for a while. Try another repair company and see if they can recheck the freon level.
We have a high efficiency unit and it produces cold air, so I don't know what previous poster is referring to. Air conditioners are supposed to blow cold air.
Sorry, to tell ya but it is normal if the outdoor temperatures are much below 45 degrees. Below 45 degrees there is little heat outdoors for the heat pump to grab to heat the home so it will run 24/7 and blow cool or cold air. Below 45 the temp of the air coming out the vent will decline and you will get no heat from the heat pump itself as you near freezing.
Your emergency heat or auxiliary heat is electric strip heat. But it only kicks in during normal operation if the temp in the house drops 3 degrees below the setting. (some tstats if can be 5 deg.) Otherwise the heat pump will blow cool or cold air the rest of the time if it is too cold out.
To prevent it from running all the time and blowing cold it is recommended if the temp outside is falling below 45 degrees you should just switch to the emergency heat setting, which shuts the pump outdoors off, and just heat with the electric.
But if there is no heat outside the heat pumps will blow cold. They are the cheapest and most efficient forms of heat but only as long as the outdoor temp is above that 45 deg..
I'm guessing that if you haven't experienced this you live in some place with moderate winter temperatures like in Northern Florida and rarely get very cold winter temps like the freezing you have seen there recently.
It will likely blow much warmer when the outdoor temp rises.
Aug 02, 2010 | Heating & Cooling
Is it normal operation for these units to EVER blow out cold air or "nonheated" air when unit is in heat mode?
Yes. Heat pumps have to go into defrost just like a freezer when the temp gets too cold outside. The heat pump will temper the indoor air electric heat.
Apr 12, 2010 | Amana PTH123B25AJ Heat Pump Air...
Ford Windstar SE, 3.8L V6, 1999, front seat heat/defrost is cold
the blendor actuators strip out the gear inside the actuator cases on these all the time. replace the actuator.
Mar 10, 2009 | 1997 Ford Windstar
Cold air
is it a heat pump or straight electric heat??
Sep 30, 2007 | Amana AAC051FRB Air Conditioner
Dryers Logo
76 people viewed this question
Top Dryers Experts
