Question about Schwinn 820 P Treadmill Silver Service Delivery
How do you adjust the slack on the belt? This is for a 815 model.
    President:
  • Schwinn Master
  • 832 Answers
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
Posted on May 06, 2010
Belt is to long, is there a deck adjustment?
Jim, Double check to make sure you have correct belt for the deck and are installing it in the correct configuration as per manual or drawing on deck. Very few lawn tractors have deck belt adjustment, most do not, most deck belts have a spring loaded tensioner to take up the slack.
This could be some of your problem, the tensioner/idler pulley sometimes seize up and must be lubed up till they move freely, or your belt could be loose. Look in your manual or try google searching your make, model #, deck belt adjustment.
How to Change Riding Lawn Mower Deck Belt
Mower belt tensioner repair question to the Garage Gang
lawn mower deck belt routing Google Search
May 20, 2016 | Garden
How to replace drive belt
Unplug it from the electrical outlet.
Remove the back panel.
Look for the "idler-wheel" -- it takes-up the "slack" between the drive-motor and the rotating tumbler.
Loosen it, to put enough "slack" in the drive-belt that the drive-belt can be removed.
Take the belt to a dryer-service store, and get them to match it.
Connect the new belt to the drive-motor and the tumbler.
Adjust the "idler-wheel" to take-up the slack.
Replace the back-panel.
Add power.
May 31, 2015 | Asko T712C Dryer
Process for changing 2001 Chevrolet Suburban surpentine belt
See diagram posted on radiator housing or download picture from internet site.
Use wrench, or hand, to pull/push slack adjuster away from old belt.
Place new belt around all pulleys except the slack adjuster
Pull slack adjuster to slack position and place belt onto it.
Mine is so easy to move that I can move it w/o any tools just with my hand.
May 12, 2014 | 2001 Chevrolet Suburban
Need belt routing diagram for 2001 chrysler sebring lxi
Thanks for using FixYa.
Fig. Accessory drive belt routing-2.7L engine
Chrysler Cirrus & Sebring Convertible; Dodge Stratus; Plymouth Breeze
Fig. Accessory drive belt routing-Chrysler 2.7L engine
2.7L Engine
A/C & Alternator Belt
  1. Raise and safely support the vehicle.
  2. Remove the right front wheel and belt splash shield.
  3. Loosen tensioner locking bolt and pivot bolt.
  4. Rotate tensioner clockwise to allow enough slack to remove belt
To install:
  1. Install the air conditioning compressor/alternator belt on pulleys, tensioner in slack position, slip belt over idler last.
  2. Adjust drive belt tension.
  3. Install the belt splash shield and right front wheel.
  4. Lower vehicle.
    Fig. Installing A/C & alternator belt-2.7L engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Raise and safely support the vehicle.
  3. Remove the right front wheel and belt splash shield.
  4. Loosen the tensioner locking bolt and pivot bolt.
  5. Rotate tensioner clockwise to allow enough slack to remove the belt
To install:
  1. With the tensioner in a slack position, install the Air Conditioning (A/C) compressor/alternator belt on the pulleys. Slip the belt over the idler last.
  2. Adjust the drive belt tension.
  3. Install the belt splash shield and right front wheel. Tighten the wheel lug nuts to 100 ft. lbs. (136 Nm).
  4. Lower the vehicle.
Power Steering Belt
  3. Remove the air conditioning compressor/alternator belt.
  4. Loosen belt adjusting bolt. It is not necessary to loosen the pivot bolt on the power steering pump. There is a bushing incorporated into the power steering pump/bracket that allows it to pivot.
  5. Remove the power steering belt.
To install:
  1. Install the power steering belt on pulleys.
  3. Install the air conditioning compressor/alternator belt.
  4. Install the belt splash shield and right front wheel.
  5. Lower vehicle.
Oct 27, 2011 | Cars & Trucks
97 nissan maxima replace power steering belt
Easy to do, but also easy to do wrong.
1. Find the belt.
2. Find the belt tensioner.
3. Find the belt tensioner adjuster screw.
4. Loosen the adjustment screw, and slack the belt.
5. Remove the belt.
6. Replace the belt.
7. Tension the belt using the adjustment on the belt tension adjuster.
8. Drive around and steer, easily.
Enjoy.
-Jackson
http://urbanscooters.com/
Oct 11, 2010 | 1997 Nissan Maxima
Engine runs well but put in gear at any of 6 speeds and it does not go. Notice that there is slack in belt and wonder if this is related to my problem.
Without the model number it is hard to be sure, but yes if the drive belt is slack, then that's a problem. If you have your manual it should indicate how to tension the drive belt (adjust clutch) You can look and be sure the belt is on all pullys.
Aug 24, 2010 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Beater bar does not turn. Belt is not broken but is so slack that it won't turn the bar. Do I need a new belt or is there a way to adjust the tension?
No, once the belt is stretched and worn there is nothing you can do, you have to replace them. Here is the belts you need for your model:
Hoover U6476-900 Belts
Apr 08, 2010 | Hoover U6476-900 WindTunnel Vacuum
Where do I loosen my belt that is runs A/C on 2000 Toyota Sienna?
One of those "wheels" or TENSIONER PULLYS on your vehicle is the tensioner for the a/c compressor. You will need to look at it and see if there is an adjustment bolt behind pully. If there is, loosen center pully nut, then run adjustment bolt out to slack out the belt. Replace belt and reverse prosedure. DO NOT OVERTIGHTEN BELT,as you can damage pullys and or belt. Tighten to factory specs. Rule of thumb is pulling the belt out and check for slack. No more/less than one inch slack.
Jul 23, 2009 | 2000 Toyota Sienna
Belt adjusting of wore out motor pulley
the motor does not come with the pulley you have to order it seperatly
May 24, 2009 | Washing Machines
How do you adjust the belt for a Weslo Cadence 815 treadmill?
Hi, I don't have a manual on your particular treadmill but most all treadmills use the same type of belt tension and tracking, which is an allen screw adjustment on the rear tension bar. One on either side. You should have been provided an allen wrench with your treadmill, if not then use one of your own the proper size. Make the adjustment with the unit running at its slowest speed. Clockwise tightens the tension and will draw the belt. Good Luck, this should Fixya!
Mar 14, 2009 | Cadence Weslo 825 Treadmill Walking Belt
Schwinn 820 P Treadmill  Silver Service Delivery Logo
344 people viewed this question
Top Schwinn Exercise & Fitness Experts
David Payne
David Payne
Matt Olenzek
Matt Olenzek
Bill Boyd
Are you a Schwinn Exercise and Fitnes Expert? Answer questions, earn points and help others
