Question about Garmin StreetPilot c340 GPS Receiver
Garmin Street pilot C340 has always worked. This morning it did not turn on. I relpaced the fuse in cord. Any other ideas?
    President:
  • 1,851 Answers
Try charging it from the WALL charger. The battery inside the unit may not be too great. Try it - over night from the WALL charge -not the PC charger. Garmin Street pilot C340 has always worked. This - 8de415c.jpg
Posted on May 08, 2010
Garmin c340 Street Pilot. When I plug it into car lighter it used to go on automatically. Now I have to push the start button. It comes on briefly, then gets lines on it and blacks out. I have tried it in...
Check to see if your cord has a fuse in it and replace it if it has blown. Sounds like it's not charging and the GPS is automatically shutting off because of a dead battery. You may have to purchase a new cord. Perhaps you can try a cord from one a friend has first? Or maybe carry your GPS into a store that sells them and has demo units you can unplug and plug your in to see if it stays on.
Feb 11, 2010 | Garmin StreetPilot c340 GPS Receiver
Garmin C340 Street Pilot
I had the same problem. Found out that the fuse had blown in the power cord. I bought a new fuse from radio shack and have not had the low battery since.
Mar 25, 2009 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c330
You have to pry off the silver-colored faceplate from the unit and you will find a reset button on the right side of the screen. Push this and everything will back to normal.
Oct 24, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin Street Pilot c340 won't come on
We followed the advice of another FixYa blogger in pressing the reset button that is under the screen frame. It worked! The Garmin magically came on! You have a great site that we will visit again if we have other techno problems!
Oct 04, 2008 | Garmin StreetPilot c340 GPS Receiver
Garmin street pilot c340 battery appeared low, used USB cable to hook up pilot with my computer but device doesn't appear to turn on, computer cannot locate device on Drivers, can I rechare steet pilot...
I followed the instructions of the Online manual for the Garmin Street Pilot c-340, I removed the faceplate of the Street Pilot and then using my thumb pressed down on the reset button. I then pressed the power on button on the side of the device- the screen lit up, I then plugged one end of the USB cable into my computer and the other end into the device. The information on the screen of the device indicated the Lithium Battery was charging properly.
Jul 14, 2008 | Garmin GPS
Have you tried a hardware RESET? The button is hidden behind the front panel, which snaps off by a fingernail slot located directly under the GARMIN logo on the front panel.
* Use caution removing and reinstalling the front panel... it's somewhat fragile... wiggle it a little to get it off.
Press where it says "Press to Reset", hold for a second or two. Charge the unit with the car cord or USB cable, then try to turn it on again.
Once you can get teh unit to (hopefully) turn ON, you should run all updates (there may be several!) using Garmin's Webupdater. (Connect to computer with USB cable first.)
Hope this helps!!
Jul 12, 2008 | Garmin StreetPilot c340 GPS Receiver
My garmin street pilot 330 will not power on
I've had a couple of Garmin C330 units and a C340. They're good quality except for the flimsy power plugs. My first one out of the box had a defective plug which made intermittent contact when I plugged it into the lighter. Tightening the knurled nut on the tip of the plug helped somewhat, but didn't fix it completely. It became a non-issue after I bought a friction mount which came with a better cord and plug. The friction mount also stopped the problem of the suction cup constantly falling off the windshield.
Lee
Jul 08, 2008 | Garmin StreetPilot C330 GPS Receiver
Garmin 340 streetpilot won't even turn on?
I had the same issue with mine during a trip. Probably needs to be reset. See page 31 of the users manual on Resetting your c340. Once I did this it worked fine.
http://www8.garmin.com/manuals/StreetPilotc340_OwnersManual.pdf
Nov 28, 2007 | Garmin StreetPilot c340 GPS Receiver
Garmin StreetPilot c340 GPS Receiver Logo
321 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
