Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
"error" displayed after defragmenting the "pininfarina".
After defragmenting the hardware, the connection is confirmed but an "error" sign is displayed when trying to access the files.
  • 3 Answers
Follow the rules while formatting. This issue is mainly because ur hard disk is either not fragmented fully or sum system files are corrupted.
Posted on May 04, 2010
Testimonial: "Thanks. The hardware works well after I have re-formating the system, but all files are gone. How to prevent it from happening again?"
Cue cs4 /Client /4.0.0/VersionCue.framework
Posted on May 05, 2010
How to defrag on acer extensa 5620
You can use the built-in Disk Defragmenter to Defragment your system.
To defragment your hard disk
  1. Open Disk Defragmenter by clicking the Start button. In the search box, type Disk Defragmenter, and then, in the list of results, click Disk Defragmenter.
  2. Under Current status, select the disk you want to defragment.
  3. To determine if the disk needs to be defragmented or not, click Analyze disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
Once Windows has finished analyzing the disk, you can check the percentage of fragmentation on the disk in the Last Run column. If the number is above 10%, you should defragment the disk.
4. Click Defragment disk. If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
GuruAid
May 05, 2014 | Acer Extensa Computers & Internet
I get this error message.. an error occurred communicating with the scanning device. Please ensure that the scanning device is connected properly and try again. Nothing seems to work,, this message...
#Click Start , select Settings , and then click Control Panel .
#Double-click System . The System Properties dialog box displays.
#Click the Hardware tab.
#Click Device Manager . The Device Manager dialog box displays.
#Click the plus sign (+ ) next to Universal Serial Bus Controllers .
#Click the USB Composite Device entry, and then click Remove .
#Disconnect the USB cable from the All-in-One, wait for few seconds, and then reconnect the cable. The New Hardware found dialog box displays.
#Click Next through all of the screens that display while the Wizard installs the USB composite device, and then click Finish .
Regards
Riztech
Oct 24, 2010 | HP Officejet 7310 All-In-One Printer
My laptop is very slow and it delays my work and connection.what can be done
It could be a hardware error either memory or disk. Go to control panel, admistrative tools, events and look at system for disk errors. If you find any, that is a bad sign. Your disk is going bad. Make sure you have all your data backed up as the disk probably needs replaced.
If you didn't find any errors, it could be viruses. Go to TrendMicro.com and run their free virus scan.
Other things that slow down a system is temporary files. Download Ccleaner and delete all temporary files it finds. Also, let it clean the registry.
A badly fragmented disk can also slow down your system. Download Defraggler and defrag the system.
Let us know what you find so we can be of further help.
Sep 10, 2010 | Compaq Computers & Internet
It doesnt restore in my iTunes. It says error 23. And its not fully charged but when i connect it to my computer the screen only displays the connect to itunes thing. It is recognised by my itunes. I'd...
Error 23, 28, 29, 1011, 1012, 1611: These errors may indicate a hardware issue with your device. Follow the steps in this article and also attempt to restore while connected to a known-good computer and network to isolate this issue to the device. If the IMEI or MAC address is missing or is a default value, this can also confirm a hardware issue.
Feb 26, 2010 | Apple iPhone Smartphone
When put on the pc, tik tik sound coming from hard disk
Hello my friend.
This is indicates that you have hardware problem on your disk or is very dirty.
The only think you can try before buy new one is to scan it for errors and and do a defrag.
You go to MY COMPUTER
You select your hardrive LOCAL DISK C: etc
Right click-Properties-Tools Check now(Check for errors) Probaply will ask for a restart to scan it,so do a restart do start scanning your disk
For a defrag you do the same but in Tools you choose Defragment now(defrag now)
Jan 15, 2010 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Are there any quick fixes for a computer that has started running slowly?
go to start /run type msconfig/open startup tap on top un check all mark /restart
Dec 31, 2009 | Dell Dimension 8400 PC Desktop
Blue screen on main display
Hi. this reoccurring error is due to programing and hardware failure. you will need to remove the battery for 5 minute. if the error continues after you re insert the battery, this will confirm this fault in the hardware. your phone will require repair in this case.
May 22, 2009 | Nokia 6085 Cellular Phone
S. It displays an error code of U00.
I use window xp.
I cannot send design to machine .
I open white program but it show " an unnamed file contains an
invalid path"
My computer can connect machine. but not send design to machine
Jan 01, 2009 | White Sewing White 4400 Computerized...
Unable to defragement the system
xp will not allow defrag on disk requiring error checking. run error checking utility first.
Sep 03, 2007 | Intel Thread Checker 2.1 (ITC021WSGB001)...
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
114 people viewed this question
Top SimpleTech Computers & Internet Experts
Lyle Siemens
Lyle Siemens
Arora Singh
Arora Singh
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
