Question about Whirlpool WTW6400SW Cabrio Washer
Drain pump leaks after quarter removed - Whirlpool WTW6400SW Cabrio Washer
  • 555 Answers
Just put the quarter back into the pump!
Just kidding.
Sounds like a seal was damaged. Did you find the quarter at the pump? close to it? Perhaps it didn't damage a seal but the pump itself. You may need to find exactly where the water is coming from so you can determine what part needs to be replaced.
Posted on May 04, 2010
How do i drain the water from my bosch nexxt front loading washing machine to remove the pump filter
I believe if you can get to it, put the hose end lower than your tub and it should drain. My front loader quit pumping and it was two quarters stuck in the pump.
Jan 02, 2013 | Bosch Nexxt 100 Series WFMC1001UC Front...
Tip
JSROCK ROCKS!! had a prob w/ top loader elite not draining n spinning. Thanks to...
This advice is for Kenmore Elite, Whirlpool Duet and Maytag Epic model FRONT LOADING washing machines. If you experience a problem where the washer does not drain properly or the drain pump makes excessive noise, here’s the information you need to check the drain pump:
  1. Unplug the washer while servicing inside the unit.
  2. Remove the lower kick panel under the door by removing the three 7mm screws under the bottom edge of the panel. HINT: Use a couple of blocks of wood to prop up the front feet of the washer to gain better access to the screws. Once the screws are removed the panel should drop down, and then pull off. If the panel becomes stuck, a slight tap on either side will dislodge it.
  3. Locate the drain pump. It will be located directly under the wash tub (it is the only pump this washer has).
  4. There is an access removal cover on the pump that can be removed to clean out the trap. BEFORE doing this, it is strongly recommended that you remove all residual water from the wash tub & drain line or you will have about a gallon or so inside your washer and on the floor to clean up.
  5. Here’s a helpful way of quickly removing the residual water. If you own a wet/dry shop vac, remove the drain hose from the standpipe at the wall and pull a vacuum with the shop vac. This will empty the wash tub, pump and drain lines. If you don’t own a shop vac, grab a bunch of old towels and open the access on the pump slowly so that it comes out at a trickle. Allow the towels to soak up the majority of the water. Close the access and stop the water if you need to get additional towels.
  6. Open the pump access and remove once you have all the water drained. Check the drain pump for foreign objects and debris. Check the pump impeller and make sure there’s nothing caught in it. Items as small as toothpicks or cotton swabs have been known to stop this pump from working.
  7. Clean out the pump thoroughly and reinstall the access cover. Make sure the cover is snug, but do not over tighten.
  8. Place the drain hose back in the standpipe (IMPORTANT – DO NOT FORGET!).
  9. With the bottom panel still off, plug the washer back in and select the following on the operator console – DRAIN SPIN, NO SPIN, and then press any button under OPTIONS 4 times (it must be the same button). “C00” will show on the console display as the washer begins diagnostics mode.
  10. Check the drain pump for leaks as the washer fills. The pump is gravity filled and will hold water even it is not pumping. Allow washer to run through diagnostics until it begins the wash tub tumble cycle.
  11. At this point, you can stop the diagnostics procedure by pressing PAUSE/CANCEL 2 times. The drain pump energizes and the washer will begin to drain.
  12. If the drain pump works normal and there are no leaks detected, reinstall the bottom panel and tighten screws.
NOTE: It is normal to have residual water left inside the wash tub under the wash basket. This is why it is important to leave the door ajar when not in use so this water does not become sour.
on Jan 19, 2010 | Washing Machines
I have a quarter stuck in drain pump on armana front load washer. what do i do?
undo the hoses to the pump two wires and two securing srews remove the pump and try to shake coin out.If this does not work you can strip down the pump to remove it...
Nov 21, 2009 | Dryers
Dodge 2000 minivan,water pump leaking
Make sure it's cool, pop the radiator cap, Remove the shield on the passenger side between the tire and front of engine. Relieve the tension on the serp belt,draw yourself a diagram of the pulleys and belt routing in case the sticker is gone on the strut tower, remove the serp belt. Take the bolts out of the pulley on the front of the water pump (3). Remove the lower radiator hose at the front cover to drain the coolant. Remove the 6 mm bolts holding the water pump to the front cover housing. tap on the pump with a rubber hammer. Install a new gasket on the new pump, and a weap hole diverter in the pump (round black about hte size of a quarter), use old one if there's no new one. Install pupm and tighten bolts snug with a 1/4" ratchet. Install pulley and 3 bolts. Install belt, top off radiator with 50/50 mix green coolant. start engine and run to operating temperature,make sure the belt is seated in all of the pulleys and is running true, radiator fans should come on. Shut engine down and let cool overnight. Check level in radiator and overflow bottle, top off as necessary.
Aug 26, 2009 | 2000 Dodge Caravan
Sunroof leak
there are drain hoses on all all four corners of the sunroof. to access the front ones, remove the front inner fender liners. you'll probably see a plastic grommet/spout that the drain hose attaches to. in the rear, remove the trunk liners on the side. you should see the drain hoses running down the inside of the quarter panel.
May 24, 2009 | 2005 Buick Park Avenue
GE Mod WDSR2080D5WW won't drain
The last one I repaired had a 2 quarters in the pump.
Remove the hoses and inspect the pump for coinage.
Feb 03, 2009 | GE WDSR2080D Top Load Washer
I have a quarter stuck in drain pipe before the removeable filter i can see it on a lgwasher model wm2277h
You'll need to lay out a towel and remove the drain hoses from the pump.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 27, 2008 | Washing Machines
Whirlpool duet washer
"F21" is a Long Drain error. If the drain time exceeds 8 minutes this error code will be displayed. In addition, a "SUDS" error may also be displayed. This may be an indication of a drain pump problem and/or clog in the drain line. You will need to check the following:
1.First, attempt to unplug the washer for at LEAST 30 minutes to reset the Central Control Unit (CCU). Sometimes this is all that is required to correct momentary glitches with the unit. If the error code returns, proceed to step 2.
2.Check the drain hose to make sure it is not kinked or clogged.
3.Check the electrical connections to the pump and ensure the pump is running.
4.Remove the drain pump filter and check for foreign objects and/or debris.
If the above procedures do not correct the problem, it is recommended by the manufacturer to replace the drain pump.
Aug 13, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Front Load Washer...F02 and SUD not draining!!!!
Probably something caught in pump. Remove lower panel if this one has it and you will see the pump. Loosen the round cover in middle to access clean-out.
Nov 08, 2007 | Kenmore 46462 Front Load Washer
Whirlpool WTW6400SW Cabrio Washer Logo
42 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
