Question about Proform Crosswalk 500 Treadmill
It keeps shuting down
The treadmill turns off about every 15 mintues by it self
    President:
  • Proform Master
  • 832 Answers
If your on it and the duration is every 15 min then the unit needs to have lubrication applied between the belt and deck with a silicon base lubricant. If that does not fix the problem then you may have damage the belt and deck and they need to be replaced. Since not knowing the manufacturer' name refer to your owners manual for contact info
Posted on May 06, 2010
2 Suggested Answers
maxtreadmill
  • 832 Answers
SOURCE: it keeps shuting down
The deck needs to be lubricated. The lubricant can be purchase @ gympart.com. LUBRICATION PROCEDURE: 1. Turn off and unplug treadmill. 2. Cut off the end of the tube of lubricant. 3. Holding the tube in one hand, insert the tube underneath the treadbelt halfway between front and back and halfway between right and left. 4. Squeeze the full contents of the tube onto the deck in a circular pattern in the center 1/3 of the deck. 5. Plug in and turn on treadmill, then walk normally on treadmill at 0.5 mph for five minutes.
Posted on May 16, 2010
Keeps asking me select user, then it restarts again
Reset it. and follow this steps and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill. ·2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
·3
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset
Dec 09, 2013 | Horizon T203 Treadmill
Precor 927 stuck in incline position
How long have you let it run for after turning it back on ? Some treadmills have a re calibration test built in and will incline to the max and work its way down. During this time you should simply walk away and not touch anything as it trys to calibrate its self. If not i will need more information on it
Oct 10, 2012 | Precor 927 Treadmill
My receiver keeps shuting down when i turn it on
Denon receiver has a common problem, keep shuting down after power button press, then red light blind. mostly, if none of amplifier output transistors blown, it must be IC7815 or IC7915 mulfunction, find it, replace it. then job down
Mar 16, 2011 | Denon AVR-1601 Receiver
I have acer PD726W projector and keep shuting down every 15 minute
SOME ONE HAS SET THE TIME IF THERE IS NO SIIGNAL PROJECTOR WILL SHUTDOWN PL SET TO 0
Sep 09, 2010 | Acer PD726W Projector
May 10, 2010 | Proform Crosswalk 500 Treadmill
Hi iam josh i have a sony tv model no. KF-50WE610 serial no. 9137805 my tv is in good condition the only thing it keeps shuting off by it self and the red light on the power butten starts blinking i have...
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast. It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator.But if you don't hear any strange noises,tv is around 6000 hrs,2-4 yrs,It's major symptoms are clicking,electrical sounds,shuts off and on and get the lamp indicator, it could be time to replace the lamp.The lamp you need is XL2100 you can find it here: http://www.discount-merchant.com/Sony-XL-2100U-TV-Lamp-p/sony_xl-2100u_replacement_lamp.htm?Click=48173.Have a blessed one!
Apr 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
The system is turning it`s self off, the red power
it must be Bricked then,try to unbrick it using the pandora battery
Apr 14, 2010 | Sony Playstation 3 (PS3) Console
I have a Hp laptop bt it is now not shuting down ie all its light on keep on glowing even on shutting down and also it makes a noise while shuting down or turning it on
remove charger first and remove battery second to try which one causing problem.
if any power source cause the problem that is mean the mainboard or power board inside failed.
good luck.
Nov 21, 2009 | Computers & Internet
Keep shuting down.
reinstall the oerating system...................this will help.......................Sameeraryan
Jan 13, 2009 | HP Pavilion dv1000 Notebook
Proform Crosswalk 500 Treadmill Logo
122 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
Electro Med Services...
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
