Question about Toys
I HAVE A MEGA TRENZ YAMAHA 4 WHEELER N IT DON'T INSTRUCTION.I DON'T KNOW HOW TO MAKE THE HANDLE BAR MOVE THE WHEELS
4 Suggested Answers
SOURCE: power wheels 4 wheeler problem
pontiac powerwheel stuck in reverse
Posted on Apr 27, 2010
SOURCE: 4 wheeler 250cc no compression
i have a yamaha wolverine quad(50km on it) suddenly started to sputter and die. will run with choke on somewhat but as soon as throttle is on it sputters and dies. changed fuel and plug and it didnt help. can anyone help me please.
Posted on Apr 25, 2010
adamfjeld
  • 1508 Answers
SOURCE: I have a power wheels
you still need help with this?
Posted on Jun 19, 2012
WHERE DO I FIND THE SERIAL NUMBER ON A 2005 YAMAHA BRAUN 4 WHEELER
Yamaha ATV VIN plates, mounted on the frame, may be positioned behind the left wheel well, on the front of the ATV or on the left side beneath the shifter pedal, depending on the model
Apr 18, 2017 | Yamaha Motorcycles
2-wheel ATV 4-wheeler won't go forwards but will go in reverse
If this is an automatic 4-wheeler, the shifting fork will bend when shifting from fwd to rev. or vis-versa. because your not completely stopped when you change directions. (kids do this to mine so many times I am tired of changing the darn thing) The part costs appx $50. Looking at the old part you can't tell it's bent.... If it's a manual tranny then your linkage is worn and needs adjusted.
Jan 05, 2014 | Atv Cover Quad 4 Wheeler Yamaha Yfz450x...
Yamaha neos 50 remove the head stock bearings got handle bars off and front wheel out how does the spindele come out got the nut off but still not moving
Remove thee clamp bolts(4) that pinch the down tube at the top and bottom of the triple tree.
Then slide the down tubes out one at a time. This means the front axle,fender cables must
be addressed.
Jan 26, 2011 | Yamaha XS1 Motorcycles
Gap for spark plug on a 1985 200e yamaha 3 wheeler 4 stroke
.035" works well for most bikes etc.
See the www.ngksparkplugs.com site and enter your model info and the info is there.
Hope this helps.
Bob
Nov 06, 2009 | 2003 Yamaha YZ 125
Yamaha Vmax 1998
A skakey front end can usually be attributed to one of four issues. Wheel bearings, warped rotor(s), bent rim, or bad tire.
To check for bearing wear, put the bike on it's center stand, or a bike jack, and have someone hold the handle bars while you try to move the wheel side to side. If you can feel excess movement, replace the wheel bearings.
Next spin the wheel and watch the rim, tire, and rotors for uneven rotation or wobbling.
Hope this helps
Apr 14, 2009 | 2000 Yamaha V-Max
Handle over the big wheels
To move the handle bar (either for folding or to change into the off-road mode) push the small white button in (located on the inside of the handle bar) and pull both triggers toward you (also located on the inside of the handle bar - on either side) This will enable the handle bar to move.
I hope this helps.
Feb 24, 2009 | Bugaboo Gecko - Green Standard Stroller
Can you straighten torqued front forks on a 2002 Yamaha TTR 125 L
you should be able to saporrt bike so front wheel is off the ground   then take a marker and put lines around where the forks meet the triple trees that hold them in place their should be some allen head bolts that u can loosen on front of the triple clamps  once these are loose you should be able  to move the forks back to strait again in line with the handle bars just line the lines up that u put on them earlier and tighten the allen bolts back up    also  when making the lines  make them from left  to right so marker is touching both fork tube and triple clamp   this is only so you get can keep them the same ride hight as before
Feb 15, 2009 | 2002 Yamaha TT-R 125 L
Tools needed?
flywheel puller?
Jan 19, 2009 | 2001 Yamaha TW 200
Toys Logo
220 people viewed this question
Top Toys Experts
ray gallant
Are you a Toy Expert? Answer questions, earn points and help others
