Question about Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594
What is the oil to gas mixture ratio on 1995 Toro Snowblower model 38170
  • 308 Answers
The proper mix is 50:1. The link to the manual is
http://ourfamilys.deandrea.net/BobKitty/User%20Guides/tosnowss.pdf
The fuel mixtures can be found on page 11. Hope this helps.
Posted on May 04, 2010
I put a mixture of oil gas in my 621 R/621 toro snowblower?
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
Jan 18, 2016 | Toro Power Clear 621 R Snowblower - 38451
What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Nov 12, 2015 | Toro Garden
Need gas and oil mixture ratio
The gas oil ratio on all Poulan models is 40:1.
First, I recommend a synthetic oil mix if you can find it and also recommend running a 93 octane gasoline.
Second, I would mix no more than 1 gallon at a time, unless you are doing a lot of cutting.
Gas/Oil mixtures do not last that long. I don't give them more than a month, and generally try to run any mixture within 2 weeks.
Think about it, gas cam gum up on it's own when let sitting for too long. Imagine what it can do with oil mixed in it.
Good luck with your saw, and be careful when cutting.
Jul 07, 2014 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Snowblower smokes
Try running it for a while, also check the oil level and make sure it is not overfilled. If it is a 2 cycle make sure the oil and gas mixture is correct, most are 50/1 ratio. That is to say 50 parts gas and one part oil.
Jan 15, 2012 | Garden
Tune up of Toro 38170
You will have to be more specific. What are you looking for?
Dec 28, 2011 | Toro Garden
What is the ratio of gas to oil for a toro powerlite 98 cc Engine model # 38172
The manual can be downloaded from this webpage, you need the serial number to do this.
https://lookup3.toro.com/request/request.cfm?lang=uk_en
Two stroke engines usually use a 1:50 oil/gas mixture but it would be wise to consult the manual.
Hope this helps !
Feb 20, 2011 | Garden
Gas/oil ratio mixture; chain oil lubricant
Call their customer service at 1-800-242-4672 there are options to choose for gas/oil ratio mixtures info.
May 26, 2010 | Homelite Consumer Products 9.0 Amp, 14 In....
Rebuilt Carb #632641 on Toro model 38170 snowblower. Upon replaceing the small gasket in the fuel inlet port how deep should the gasket be set for the needle valve on the float to properly close. I may...
Is your rubber seat possibly sideways?
Also take the float back out and see if has fuel in it.
sometimes the foat has gas in it and it drops down and the gas keeps coming in the carb.
Oct 26, 2009 | Garden
Smoke from snowblower muffler
Your gas to oil ratio is 32 to 1. Should cut down on smoke. replace sparkplug at same time.
Please rate this response and Good luck
Dec 29, 2008 | Toro Blowers Rake and Vac - Electric...
Mowtownusa Snow Thrower Starter Switch for Toro S-200 and S-620 units # 29-5560 40-594 Logo
631 people viewed this question
Top Mowtownusa Electrical Supplies Experts
Steve
Gene Haynes
Are you a Mowtownusa Electrical Supply Expert? Answer questions, earn points and help others
