Question about Sharp AF-S120FX Air Conditioner
My ac throws water back into the house when running to long, water builds and does not leak out of unit,do i need to drill a hole on the bottom of unit and if so where is compressor so i dont puncture it.
    Novelist:
    Champion:
  • 246 Answers
Sounds like your condensate drain is stopping up or not draining properly. I would check and make sure the unit's drain is open and water is draining.
Also it's possible that the AC itself needs to be tilted (just slightly back in order for the water to drain better. Sometimes people will make sure the unit is installed perfectly level for cosmetic purposes not realizing that the water needs to drain out the back of the AC.
good luck!
Posted on May 04, 2010
    Guru:
  • 1,524 Answers
DO NOT I REPEAT DO NOT drill any holes in the unit as you stand a good chance of puncturing the coil.
WATER IS LEAKING FROM BOTTOM OF AIR CONDITIONER
That is normal... if it is a window mount check to see if the drain at the bk is clear... if you need to drill a couple of small holes near the bk using a bit about the size of this O..make sure not to drill too deep, just enough to go past the casting as you don't want to hit the internals. Make sure it is tilted bk slightly so that the water runs towards the out side and not into the house..ps. Refer if the ac all of a sudden stops blowing cold air it is an ice build up from that same water and will have to be unplugged for a few hours to allow that ice to melt
Jul 02, 2015 | Heating & Cooling
I have a frigidarie window air conditioner with drain hole in the bottom that leaks is there a drain hose and hose adaptor that can be purchased if so where
If you cant do any better, cut a piece of plastic or flashing material and insert it under the ac so that the dripping water will fall on it and away from the building. If you make it long enough you can insert it under the unit in such a manner as to pinch it and hold it in place. You can bend it to suit. I have a number of houses with window units. The first thing I do when I get a replacement unit is pull the cover and drill a hole or two, 3/8 to 1/2. The largest I can drill and not touch the coils.
May 06, 2012 | Heating & Cooling
Portable haier air conditioner drainage. Cannot find drain hole and unable to tilt ac. Water is building up in the bottom of unit.
Here is a thought, received by me from a AC mechanic recently. Window ACs no longer actually drain concensate. Rather, the water is caught in a pan with the idea it will evaporate back into the outside air. The reason for this is the dripping water frequently resulted in the growth of algae below the unit resulting is unsightly stains and sometimes, slippery conditions. Evidently, there were a lot of complaints about being 'dripped on' also. So, AC manufacturers don't put drain holes in the bottom any more. If the pan over fills, it will spill out of many makes. If you want yours to drain, put a hole in the bottom.
Like I said, just a thought.
Thanks for your question @ FixYa.com
Aug 08, 2011 | Haier hwr10xc6 Air Conditioner
There is no drain hole for water to drip outside.
These are designed to retain some water in the pan. This is for the slinger fan to throw water through the condensing coil. This helps the refrigerant cool and is important to the efficiency of the unit. I would certainly not recommend drilling a hole in the bottom. The hole may cause the water to roll somewhere where damage could occur. Try instead tipping the unit Backwards before bringing it in the house.
Jul 14, 2010 | Frigidaire FAC126P1 wall/window Air...
Water accumulation and ice buildup
There is already a hole just remove the ac unit from the window,and it`s shell,take it outside and use a water hose to clean it out,and remove anything on the inside that may stop up the drain hole.This needs to be done every year before spring or summer.If this was at all helpful,please rate,thank you.
Jul 12, 2010 | Samsung AW0891M Air Conditioner
Water leaking from Maytag M6T12F2A is this expensive to repair
The drain hole is likely clogged with lent and trash. Make sure it is level or leaning dow a bit on the back side. I had to drill five holes in the bottom rear of my old window unit to stop water draining down the insdie wall. Make sure you dont drill into a usefull component of the AC or kiss it goodbye.
Aug 21, 2009 | Maytag M6Q10F2A Air Conditioner
Condensation leaks out front of unit into the house.
Hi, no don't drill holes in bottom tray, to make drain, that's design, you need to keep water there, the fan usually pick up water(moisture) and add to your air inside your home, otherwise the air in your home will become to dry, dry air will create static electricity all over your home, from your carpet to your clothes, you need to level your unit horizontally, put a spirit level, and you should have a slight pitch, from front to back, good luck.
Aug 03, 2009 | Maytag M6Q10F2A Air Conditioner
Water on the floor
I've ran into this problem before with another jeep. What happens is the condensation drain line from the evaporator housing gets plugged with the material that insulates the housing and the water can't drain and seeps through the seems and drips on the passenger side floor. Chrysler did at one time sale a plug kit for this. What you would do is drill a 1/4" hole in the side of the housing on the left hand side near the bottom and put a stiff piece of wire in it to unplug the drain line and then plug the hole with the plug kit from chrysler. just when your drilling the hole make sure you don't drill into the evaporator core or your freeon will leak out as well. I'm not exactly sure how far from the bottom to drill the hole if I remember right it is 2 inches just about center. Chrysler did have a service bulletin on this you may want to ask them when you see bout the plug kit.
Jul 27, 2009 | 1998 Jeep Grand Cherokee
AC accumulating water, not draining properly????
For some reason, newer AC window units no longer are made with a fluid drain. I think the intent is for the unit to be mounted at a sufficient angle (it MUST be angled back so the fluid drains toward the back of the unit) that the rear (outside) fan kicks the water over the condenser coil and gets rid of it that way, it also increases cooling ability slightly in this manner by misting the condenser coil. I would suggest increasing the angle of the back tilt by adding a 2x4 maybe under the unit to allow it to tilt? Alternately, you can drill a hole in the rear corner of the unit to drain fluid, but this is not recommended for several reasons...
1) It will usually cause rust to start at the drill hole.
2) you could accidentally puncture the coil system while drilling
3) the manufacturer did not make a hole, because one was not intended.
Jun 17, 2009 | Heating & Cooling
Sharp AF-S120FX Air Conditioner Logo
547 people viewed this question
Top Sharp Heating & Cooling Experts
AJMAL KHAN
Tim Whalen
Brandon Berry
Brandon Berry
Are you a Sharp Heating and Cooling Expert? Answer questions, earn points and help others
