Question about Minka Aire Ceiling Fan
Minka aire ceiling fan won't go to high speed. Tested the wall switch. Changed the relay. Fan won't go to high speed.
SOURCE: light dims up and down repeatedly
PROBABLY THE WALL CONTROL SWITCH IS BAD.
ASK YOUR LOCAL DEALER TO BORROW ONE HE HAS IN STOCK. AND OR BUY BOTH THE RECEIVER AND THE SENDER. MY WALL SWITCH MALFUNCTIONED.
Posted on Feb 18, 2009
SOURCE: minka aire concept II ceiling fan bulb replacement
I found that the minka website has the installation manuals online.
www.minkagroup.net/http://www.minkagroup.net/minkaairemanuals.asp The glass cover on a Concept I fans turns counterclockwise. I had to use rubber gloves to get a good grip on the light cover.
Posted on May 03, 2008
SOURCE: Minka Aire remote controlled ceiling fan
I have the same problem, except I live in a multi unit condo where many of the occupants own the same fan! You can imagine how  frustrating this is when your fan or light comes on or you can't  agree on a fan speed. Anyway, I spoke to a MinkaAire customer service guy and he tells me that the switches in the receiver are located under the mounting ring. You need to unscrew the ring and it should be located in there. I haven't tried this myself as my fan has a mind of its own as I type and everytime I turn it off to unscrew the mounting ring, the damn thing turns on again.
Posted on Sep 04, 2008
I have a newer Minka w/ wall controller. The books says to make sure both the wall control and the receiver(up in the fan) are both programmed the same. My receiver has no little switches but has a sticker stating that you need to hold the 'fan off' button down for 3 seconds after turning on the power so the receiver can memorize the program in the wall switch. You have 60 sec to do this after power is turned on. Good luck !
Posted on Feb 25, 2009
SOURCE: Hamilton Bay Remote Control Ceiling Fan
Rempte light comes on but does not activate fan or light?? thanks
Posted on Apr 22, 2009
Minka Aire model f603 reverse switch?
Not sure what model of fan or manufacture you have. Says Hunter 52" & Minka aire F603. If it's the Minka , Then push the button on the lower part of the remote (6 o'clock). If that doesn't work then you might need a new receiver.
Jul 23, 2014 | Hunter 52" Ceiling Fan With Light And...
Minka Aire Ceiling Fan light wont come on
Probably needs a new remote receiver.Contact Minka Aire @ 1-800-307-3267
Apr 30, 2013 | Minka Aire Ceiling Fan
Some functions of switch stopped working
Sounds like you need a NEW RECEIVER. Call 1-800-307-3267(Minka Aire)
Feb 13, 2013 | Minka Aire Ceiling Fan
I currently have 2 switches on the wall for a ceiling fan(this was pre-installed when I bought my new home, but my Minka
The red and white should be hot all the time for the fan to run even when the light is not in use. The black and white wires are used for the switch on the wall to turn the light on. Hope this helps.
Apr 25, 2009 | Minka -Aire Brushed Nickel Remote Control...
Mika aire remote fan
Not sure if this addresses your problem or not, but with my Minka Aire ceiling fans, the fan has to be moving in order to change the fan direction. Turn the fan on (any speed works), then push the reverse button. The fan will speed up to max, then you'll hear the gears switching. The fan will slow to a stop, change directions and get back up to speed in the new direction.
Oct 03, 2008 | Fanimation Bon Aire White Remote Control -...
Light dims up and down repeatedly
Apr 05, 2008 | Minka Aire Ceiling Fan
Minka Aire Ceiling Fan Logo
427 people viewed this question
Top Minka Dryers Experts
Joseph Coppeto
Joseph Coppeto
Are you a Minka Dryer Expert? Answer questions, earn points and help others
