Question about Acer Aspire 5610-4648 Notebook
Display is black, power button is lit. - Acer Aspire 5610-4648 Notebook
    Problem Solver:
  • 6 Answers
I would try to shine a flashlight on the display first, if i could see anything then i know the backlight is bad. otherwise , the lid switch may be stuck. I dont know how comfortable with pcs you are but if you like you can replace the backlight/inverter yourself. parts are cheap-the internet is your friend!!
Good Luck!!!
Posted on May 04, 2010
I have a display light lit up & I would like it off on my panansonic KX-DT343
Have you had a look in the menu and look for display backlight and set it to off that should solve that little problem.
Aug 27, 2014 | Panasonic KX DT343-B Digital phone - Black
I have a Meridian Phone (Norstar System). How do I set the number of rings?
Feature 985 write down number displayed
Feature **266344 then 266344
displays Terminals and sets
press top left lit button displays show set
enter extension number
press top left lit button again
press bottom left lit button one time or until you see capabilities
press bottom left lit button until you see fwd to
press change
enter number you wrote down in the first step
press rls
Jan 11, 2011 | NorStar M7310 Corded Phone
After shutting down display buttons remain lit
are you shutting down using the power button? It may be programmed to do another action ( standby or hibernate ).
start menu > control panel > performance/maintenance > power options > advanced tab .
Oct 14, 2009 | Toshiba Satellite Pro M300-S1002X Notebook
HP 7410 - No display and orange exclamation point is lit
Unplug your power supply and leave it off for like ten minutes, then replug it and see if it will initiate itself, if not it sounds like serious malfunction.
Aug 25, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Monitor displays properly then screen goes blank
it seems tht the monitor has gone bad & needs to be replaced....try running a monitor self test by unplugging the monitor cable frm the back of the cmputer & make sure the monitor is receving power frm the wall outlet....chk if the monitor displays anything......let me knw if it wrks
Jul 11, 2008 | Dell 1703FPs 17" TFT LCD Flat Panel...
Screen went black
plz try by resiting the ram, if the problem persist then you have problem in display adapter,send it to the vendor from whom you have bought
May 16, 2008 | Compaq Presario 700 470024-192 Notebook
Black out
blown capacitors on the inverter board inside it is fixable if you can solder
Apr 09, 2008 | Proview PL576Ws 15.4" Widescreen LCD...
My monitor will remain black when notebook is powered up
Black uses much less power. It's a device for automation, so you really should not lavish the watts and attention on it unless it has to perform something truly novel.
If you really want to use the monitor though, you can use the function-key combination used to switch the display between internal and external displays.
Feb 22, 2008 | Acer TravelMate 529ATX Notebook
On button
Look at the power indicator. If it is not lit, no power is being supplied to the computer. Check the following:
  1. If you are using on the battery, it may be low and unable to power the computer. Connect the AC adaptor to recharge the battery pack.
  2. Make sure that the AC adaptor is properly plugged into the computer and to the power outlet.
If it is lit, check the following:
  1. Is a non-bootable (non-system) disk in the external USB floppy drive?
  2. Remove or replace it with a system disk and press <Ctrl> + <Alt> +<Del> to restart the system.
The computer's power management system automatically blanks the screen to save power. Press any key to turn the display back on. If pressing a key does not turn the display back on, three things might be the cause:
  1. The brightness level might be too low. Press <Fn> + <→> (increase) to adjust the brightness level.
  2. The display device might be set to an external monitor. Press the display toggle hot key <Fn> + <F5> to toggle the display back to the computer.
  3. If the Sleep indicator is lit, the computer is in Sleep mode. Press and release the power button to resume.
Dec 17, 2007 | Acer Aspire 3000 Notebook
Acer Aspire 5610-4648 Notebook Logo
101 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
