Question about GoVideo VR3840 DVD Recorder/VCR
Connecting it to a tv through a stereo with a cable box
I am getting sound through the stereo but no picture through the tv
  • cleodog Feb 09, 2009
    I have a KLH 11111 DVD Player Model # DAV 5022 - I can not connect it to the tv or cable, I get sound but no picture on my tv
    Scholar:
  • 74 Answers
Hiya ... you have a simple lead or set up problem .. ensure that the lead is a good quality one .... and also that the correct leads are atttached where they should be on the tv & stereo... select AV....( this is also dependant on the number of peripheral attachments and their set up to the T.V... ie Digital box.. dvd player... scart or aerial connection)... after checking these... use your T.V controls.. select menu... sounds...external sounds... or digital sounds... something similar....select external devices.... ensure that you have the "phono" selected on your hi-fi.. this should sort your problem.
You should remember also that once you use your Hi-fi to listen to your t.v.... some tv sound systems will.. not allow any of the additional speakers attached to the tv to work ..... you should however be able to manipulate bass/treble settings in certain sound modes via your tv remote.
Alternatively if you have the ROCK/POP/CINEMA...etc selection modes on your hi-fi these can also be used for a satisfactory sound...
Have I understood your problem correctly? and has it helped?
Regards Faggly
Posted on Mar 26, 2008
How do I hook up my 55 inch led tv to a stereo for better sound
In many cases newer tv's do not have an audio out, some have a headphone jack on the side (Small usually blue)
Otherwise if you are wanting to get better sound from a DVD / Blueray / Satellite / Cable box, You can put the audio from these devices into your sound system, then plug your sound systems audio out into the tv.
The video out from your devices will need to connect directly into the tv.
If using HDMI or S-Video that carries both audio and video, slitter / separation boxes are available, but usually degrade sound and audio quality.
The above would look something like
Cable box audio out (red / white) to Stereo audio IN. >> Stereo Audio OUT to TV audio in.
Yellow (Video) Cable from cable box then goes directly to the TV Video IN. Just make sure the audio and video cables are going to the same section (Some tv's may have multiple audio / video in's
Nov 17, 2014 | Haier LE55B1381 55 Class LED HDTV - 1080p,...
Do I connect my Mdl LHT854 to the tv or to the cable box? When to directly to the Sony TV I get sound but no picture!!
You may need to use an optical cable between the tv and the stereo. (TV out/Optical in)
Jun 03, 2014 | LG LHT854 Theater System
Connect roku to switch box to surround system
there must be red and white rca outputs, those are audio lines(stereo) get rca cables connect from the tv and into the AUX in the stereo amp, select aux on the amp front panel and you will get the quality sound you want,
Jan 15, 2014 | Yamaha HTR-6130 Receiver
On my Zenith z50p3 plasma tv, I have picture , but the sound is scratchy, I have to raise the volume to 40 before I hear something,and then it is very irratic. Some say it's the sound amplifier. D
First check all your wiring with it turned on wiggle the connections and you mite find you have a dodgey plug somewhere or a break in the wiring
Dec 14, 2017 | Zenith Z50P3 50 in. Plasma TV
Stereo Sound on new LCD Samsung Series 5 TV
It appears you may be using a cable type which isnt compatible with stereo. The Coaxial output on a lot of the old VCRs dont always support stereo so that may be your problem right there. i suggest you try connecting the cable box directly to your TV using a scart cable. Scart definately supports stereo audio so if this doesnt give you stereo sound the problem lies within the cable box's audio settings which you should be able to access with your remote.
ope this helps you solve your problem :)
Good Luck.
Jun 15, 2008 | Samsung HCJ655W TV
42" Sharp Aquous audio; Mono vs. Stereo
no. that is not true. the person you spoke to obviously didn't know what they were talking about. you mean to tell me that everyone that has a cable or satellite box with a stereo or hd tv is not going to receive stereo sound? really,think about it. you only need a cable box( for now ) if you have premium channels (hbo,showtime etc). you can connect the cable line right into the tv if you only have basic cable. look at the back of your cable box. if you have a red, white, & yellow audio/video output, then the box is stereo.connect these outputs to your tv. this connection however is not hd.you will need a hd box with a hdmi cable for hd .To put the tv on stereo mode, there should be a way via the menu and/or the audio button on the remote to get it off mono and put it on stereo. your manual should at least show you around the settings of your tv.
wg
Apr 06, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
How to connect surround sound system, at the moment its connected through cable, each time we use the dvd player we have take them out of the cable box then into the dvd player, we have a LG 42PC55 tv.
In order of picture and sound quality -- from best to worst:
1. The best way to connect, assuming your TV and A/V Receiver and/or Cable Box have the jacks, is to use a HDMI cable ( this cable is for both sound and video).
2. Use Component Video out to input (3 RCA plugs, Red, Blue & Green) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
3. Use S-Video out to input (1 din plug) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
4. Use Video out to input (1 RCA plug, yellow) along with RCA Audio out to input (2 RCA plugs for stereo - 1 for mono).
Be sure to select the correct inputs on your TV and Audio/Video receiver when you are watching TV. For example if you have connected your TV to HDMI 1 and DVD to HDMI 2, you will not see or hear anything if you don't select the correct input on your TV and A/V receiver for the input you want to see and hear.
Detailed connection instructions will be found in your owners' manuals.
Hope this helped you. :)
Mar 30, 2008 | Televison & Video
Sound problem with Sharp LC-32D4U
I got the sound on my LC32D6U fixed for free. Even though the TV is out of warranty, Sharp considers it under warranty for the sound problem. The number i 800-237-4277.
Mar 23, 2008 | Sharp Aquos LC-32GD4U 32 in. LCD HDTV
Sound is ridiculously low
if it is a stereo tv, there should be rca jacks on the back of the tv [red,white yellow] try connecting the rca outputs to a stereo system and see if the volume is any different.there might be a loose connection to the tv speakers inside.if you have a cable box hooked up to your tv, check the connections in back. you can also try bypassing the cable box by connecting the cable wire directly into the tv to see if it's the tv. if it is the cable box try unplugging it for a minute then hook it up again.i had the same problem with my cable box. hooking it up to a stereo system sounds like a pain, but at least you will have sound.
good luck
wg
Jan 30, 2008 | Toshiba 32AF44 32" TV
GoVideo VR3840 DVD Recorder/VCR Logo
Top GoVideo Televison & Video Experts
Demonic-2011
Demonic-2011
Computer Repairing
Computer Repairing
Are you a GoVideo Televison and Video Expert? Answer questions, earn points and help others
