Question about Whirlpool WED8500S Electric Dryer
No heat all works but no heat blows cold air what can i do and find the problem is it the heat element and how do i fix this take apart steps the remove and replace steps
  • 784 Answers
Yes it is is a heater element problem. YOu have to access from the back panel. There are screws need to be removed. Once the panel is off, you can see the Blower and the heating element assembly. Take off the housing so you can replace the heater.
Posted on May 04, 2010
Heater is running but cold air is blowing out. Is this a fuse, or the heating element? Can I fix it myself?
I would suspect the heating element. Unless you're comfortable working with high voltage, I'd suggest getting a service call.
Mar 05, 2015 | Heating & Cooling
Blowing cold air
This model dryer has two heating elements, one for the top and one for the bottom, I suspect that the bottom element is burned out. If you want to attempt it yourself then I can send you a service manual that will walk you step by step through the whole dryer.
Dec 11, 2013 | Maytag Neptune MCE8000AY Electric Dryer
Heater works fine but cold air
thermal fuse is usually the first to go check it for continuety
Nov 16, 2013 | Lasko 755320 Ceramic Electric Utility...
Belling xou178 ss not heating up? fan blowing cold air, digital display working. is it the element and how do i fix it?
Yes most likely it is the element if the fan is still working.
First switch off the power to the cooker. You have to remove the back panel fom the back of the cooker which will give you access to the heating element, disconnect the wires and undo the retaining screws.
Remove the old element and fit the new, reconnect and it should be fixed.
Dec 30, 2009 | Belling Ovens
My dryer is blowing cold air. I replaced the
if you hooked up yhe wires on the heating element check the thermostat it will be a oval shapef unit on housing of element and has wires going to it it may be bad.
Dec 28, 2009 | Washing Machines
The tumble dryer is work but is only blowing cold air
sounds like a heating element. not to hard. remove the back and its is right there.
Jun 07, 2009 | Zanussi TC7102W Electric Dryer
LG DLE2532W NO HEAT
Sounds like the heater element is bad that is the main cause for them not to heat up . Their should be a cover on the back that comes off and you can get to the heater element after removing it .
Feb 23, 2009 | LG DLE2532W Electric Dryer
Whirlpool Dryer blows cold air when starting no heat
Did the fuse blow out? If so then the heating element is shorted out. This happens frequently when they fail. If the fuse is blown check the condition of or change out the heating element.
Dec 29, 2008 | Weather King 12AJA4801AH Air Conditioner
Oven doesnt heat up
remove back panel inside oven and element will be exposed. this element is probably faulty and you can often see the damage
to replace, take the outer rear panel off and element fixings are in view - easy job usually
Sep 09, 2008 | Ovens
Heater blowing out cold air
Yes you could have a bad overload on the heater element which is fairly simple to fix. To test for this pull the heater out and get an ohmeter set it to continuity and check the continuity first through the entire heater element then if there is none pin point the overloads and check to see which one has no continuity.
Nov 05, 2007 | Amana PTH153B35AE Air Conditioner
Whirlpool WED8500S Electric Dryer Logo
78 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
