Question about Konica Minolta DiMAGE Z6 Digital Camera
My camera says unable to use card although it is an old memory card that worked in the past
    Brigadier General:
  • 11,967 Answers
Download any pics from the card using a card reader if necessary. Then, format the card in the camera.
Posted on May 04, 2010
I'm suddenly unable to download from my Nikon L22 Coolpix have had no trouble in the past
You didn't say if you are leaving the memory card in your camera and connecting it to the computer with a USB cable or if you remove the card from the camera and use a card reader. Eaither way should work, but if one dosn't, the other should. In either case, consider that from your computer's perspective, the memory card in your camera is no different then an external hard drive. You can access the folders on the memory card in exactly the same way you access any other folder on your computer (Mac or PC). Just copy and paste your pictures from the folder on the camera's memory to a new folder with an appropriate name on your computer. You do not need Nikon's or any other third-party software to do this.
Aug 26, 2013 | Nikon Coolpix L22 Digital Camera
Camera won't register that there is a memory card, always saving pics to internal memory
Did you use a high capacity memory card with an old camera? For example, did you use a SDHC card in a somewhat old camera?
Some cameras accept only SD card. Although SDHC card has the same shape, it won't be reconized by the camera.
Sep 23, 2011 | Cameras
Memory card problem
If you go to the support section of the Kodak web site, you may be able to download manuals to your computer.
Dec 08, 2009 | Kodak EasyShare C330 Digital Camera
Inserted new memory card error message:memory card error unable to access format under menu
I'm guessing that you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. Unfortunately your camera was designed before the SDHC format came out. Sorry, but a SDHC card will not work with your camera.
You'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Nov 07, 2009 | Canon PowerShot SD630 Digital ELPH / IXUS...
Cha flashing when new memory card inserted... have tried several to no avail... please can you help?
CH A error indicates that the camera can not communicate with the memory card. Most often this is caused by formatting a memory card in a computer and then putting it into the camera. (Especially on 4 + gb cards). Solution is 1. Reset the camera - then it should work with cards that it worked with in the past. 2. Take the bad memory card and reformat it in your computer to FAT not FAT 32.
It should now work - although it will show capacity to be only 2 gb...
I believe at that point, if you reformat it in camera it will work at the full 4 gb.
Oct 22, 2009 | Nikon D2X Digital Camera
Uploading pictures on PC
This one is easy. Buy a memory card reader and do not use the camera usb cord. A card reader will always be the easiest way to transfer photos from memory stick to PC.
Nov 12, 2008 | Cameras
Unable to select functions
Hello HUMAN,
If u r using a memory card please take out the memory card and then check if it is working fine.If it is then plz use a different card which is compatible with the camera.If its still not working then try resetting the camera.That is take out the batteries and put them back in.And after all this if its still not working then u will have to get the camera serviced.
Sep 07, 2008 | Canon PowerShot SD750 / IXUS 75 Digital...
Memory Card
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
May 06, 2008 | Samsung Digimax S630 Digital Camera
Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
You may fix the memory card error and recover your files by follow this memory card recovery guide which helped me last time:
Fix memory card error and recover data from memory card
good luck!
Nov 09, 2007 | Panasonic Lumix DMC-FX8 Digital Camera
Konica Minolta DiMAGE Z6 Digital Camera Logo
189 people viewed this question
Top Konica Minolta Cameras Experts
Steven Wander
Steven Wander
Computer Links
Are you a Konica Minolta Camera Expert? Answer questions, earn points and help others
