Question about Husqvarna Designer I
The light on my Viking Design I won't turn on. The light bulb has been changed and still nothing. I have taken my machine to my local repair man and he can't find the problem.
    New Friend:
  • 194 Answers
There are two lights on the machine, 1 over the needle and one in the center of the arm. If either light is bad the other will not work so make sure you have 2 good bulbs.
Posted on May 07, 2010
Where will I find a new circuit board in the UK, for my 30yrs+ machine & a specialist repair man. Tried A1 sewing machines but they haven't got one.
Have your authorized Viking dealer procure a replacement board from Viking or perhaps get a board from a used machine that another dealer might have. Failing both options above, purchase a newer Viking sewing machine.
Jul 07, 2014 | Husqvarna Viking 1
I change light bulb in husqvarna classica 100?
if you don't have the accessory that looks like a short piece of rubber hose used to remove and reinstall the bulb, take the machine to an authorized Viking repair dealer and ask them to install a new bulb.
Jun 21, 2014 | Husqvarna Scandinavia 100 Sewing Machine
How do you change a lightbulb in a Simplicity American Quilter Sewing machine?
You can usually find a manual to your model on-line or through your local dealer/repair man. Most commonly the light bulb is under a cover held on by a screw at the front of the machine. I took the bulb with me to the store to find the exact replacement if you don't have a manual that tells you what the replacement is.
Apr 12, 2014 | Simplicity American Quilter SA2400L...
Repair service manual for Viking model 610 electronic sewing machine
ask your authorized Viking repair to locate a new or used part
Apr 10, 2014 | Husqvarna Sewing Machines
Have Viking 990 and feed dogs not working. Local repair man kept for over a month and then said it was the circuit board and that Viking no longer making circuit board for 990-- or, that machine can't be...
Is it that the feed dogs won't go up and down, or that you can't adjust the stitch length? If the feed dogs won't go up and down after you have released the feed dog button and cycled the handwheel one revolution, than there is a mechanical adjustment needed. I the stitch length can't be ajdusted, that It's either a circuit board of a step motor problem. The repair shop should be able to tell you that they swaped the feed motor with the zig zag motor to test this issue.
Apr 14, 2011 | Husqvarna Viking 1
\i have a viking 190 sewing machine..it was put
throw the machine away I had a riccar machine I had to throw away for the same reason I bought it used in 1983 and could not get it parts it needed
Dec 13, 2009 | Husqvarna Sewing Machines
Huskystar C20 lights up but doesn't work
sounds like circuit board has gone bad. If you are the original owner and purchased from an authorized Husqvarna Viking dealer it may still be under warranty. There is a 1 year warranty from date of purchase. Contact your local authorized Husqvarna Viking dealer for service or have them send it to Husqvarna Viking (SVP) Technical Service Department for repair. You can find authorized dealers near you from the Husqvarna Viking website - http://www.husqvarnaviking.com/us
Good luck.
Aug 31, 2009 | Husqvarna Viking 1
Viking sewing machine programmable card
Programable cards do eventually pack up. Test it with your reader writter.
Jun 17, 2008 | Husqvarna Viking 1
Husqvarna Viking #1 blown fuse
You will most likely find that ALL of the "better" manufacturers; Bernina, Husqvarna, Pfaff, will not sell proprietary parts to non-brand dealers. Ultimately, this protects the customer.
With that being said, chances are the problem you are having is NOT a bad circuit board, but a bad power supply. But, since you don't trust your local dealers, find a dealer that is not so local. A two hour car ride is going be a lot cheaper that replacing the wrong part, and NO dealer will return your money on a part that the customer diagnosed as being faulty. I assure you, a Viking dealer somewhere will help you with your problem. You might want to try a Pfaff dealer. They can sometimes obtain Viking parts.
I would try replacing the power supply first. Its a cheaper priced part, and more likely your problem. Its also easier for DIY'ers, but extreme caution must be taken to ground yourself to the machine. Static is always a concern with electronic sewing machines, and even more so this time of year. Proper grounding equipment should be worn while performing any internal repair or adjustment in any electronic machine.
As far as replacing the circuit board yourself, if necessary, also be very careful when disconnecting and reconnecting wires. The connectors are very small and bend easily. Also, care should be taken when tightening screws. Overtightening can cause faults within the circuit board by cracking the solder paths or just plain break the board.
Dec 02, 2007 | Husqvarna Viking 1
Sewing Machines Logo
253 people viewed this question
Top Husqvarna Sewing Machines Experts
Douglas Plant
Douglas Plant
Tally Girl
Tally Girl
Wayne Fellows
Wayne Fellows
Are you a Husqvarna Sewing Machine Expert? Answer questions, earn points and help others
