Question about Dell Dimension 8250 PC Desktop
Dimension 8250 won't boot up
I have just had this similair problem. Did you ever recieve an answer that got the computer back up and running?
  • Chris Fitz Mar 31, 2008
    Things to Check When No boot...
    1. Have you connected all the power cable?
    Yes.
    2. Do you see any display?(including the power lights glowing)
    Power button glows amber, dvd and cd rom drives run, floppy runs then nothing. No A,B,C,D lights on in back.
    3. Does the screen show you any blue screen error message?
    No error message, only that when I push a button on the screen it says move mouse or hit any key to continue.
    4. Do you hear any beep noises?
    No noises.
    5. Have you tried to install any third party hardware or software?
    I'm in Italy, and before I could say anything a tech, attempting to install the equivilant of a DSL line, plugged in the modem prior to installing the software. I don't know if that would do it or not.
    6. What do you think could have caused the issue?
    Could have been a surge, although I was using a surge protector, other than that the #5 issue could have done it. I've tried booting with everying running with just the video card up and I get the same result. I've even tried to boot from a cd and floppy, with no results.
    Motherboard or Power Supply Unit? If it could be another issue let me know what you think.
    Thanks
    New Friend:
Yes 12 volt transformer faulty even though the standby light glowed was not giving enough out put power to boot up. Changed transformer all ok now
Posted on May 25, 2013
  • 44 Answers
Kindly give a feed back to Improve my statistics and to see If it was helpful for you...
Thanks and Regards
Posted on Mar 28, 2008
My cd-rom on dell Dimension 8250 pc desktop computer will not show up on my computer. Am i missing cd-rom drivers.
hello,
1.first go to http://support.microsoft.com/mats/cd_dvd_drive_problems
click on the green button that has run now
Run the microsft fix it tool
if it works GREAT! if not go to #2
#2 go to this site http://www.techsupportall.com/fixed-solved-cd-drive-not-found-not-detect-remove-upper-and-lower-filter/
follow instructions
IF THAT WORKS GREAT! if not proceed to 3
#3 turn off computer unplug power cord.
open your computer case unplug the cables that connect to the back of the cd rom. plug computer back in power it up. shut it down once it loads. then once it is powered down open case again and plug the cables back in make sure they are connected well. close case and power up the computer.
hope that helps
Nov 25, 2012 | Dell Dimension 8250 PC Desktop
How do I restore a Dimension 8250 to original factory settings? It's running XP. Control F11, F8, and using the system restore feature does not seem to do the trick.
to restore to your pc as it was from the factory you will need the cd's that came with the computer. one of those will be the Operating System cd. Once you have located the correct cd, boot from that cd and follow the instructions to reinstall the operating system.
Aug 08, 2010 | Dell Dimension 8250 PC Desktop
Dell dimension 8250 A,B,C,D lights come on in back but pc won't boot up.
Those lights can be used to learn why your computer isn't starting. This service manual page explains how to interpret them. If the lights aren't all green, this information may help you figure out what to do next. If you're not sure how to proceed, please post a follow-up with your light information and I'll try to help further.
Feb 04, 2010 | Dell Dimension 8250 PC Desktop
Need ethenet controller for dell dimension 8250 PLEASE ANYONE
lets try a few things
open up device manager, right click on the other device, click properties, open up the drivers page, update driver, search my computer automatically next next next, does it find the driver? if not then go back Select driver manually - advanced, do you still have the files you downloaded? direct the manual search into the download folder / where you have extracted the files, might install that way.
Let me know how that goes.
Thanks
Ekse
Jun 03, 2009 | Dell Dimension 8250 PC Desktop
Possibility of using Dimension 8250 memory in a Dimension 8200
Probably not, but to confirm go to this link. When you're there plug in the info for both machines and compare the memory configurations.
May 25, 2009 | Dell Dimension 8250 PC Desktop
No sound no 3d grafphics
Ok first, I am sorry to tell you the Dimension 8250 is not VISTA compatible. Especially with that video card. Vista is a power hog and has high demands of your PC. You should really revert back to XP if you want things running normal.
May 11, 2009 | Computers & Internet
Dell Dimension 8250 won't boot-up IDE fail code 5
install your OS and then firstly run chkdsk..
Jan 21, 2009 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Dell Dimension 8250 PC Desktop Logo
216 people viewed this question
Alun Cox
