Question about Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer
What size of box in need Pioneer TS-W307D2 12
What size of box in need Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer in inches
  • 11,896 Answers
Length (L) = 31.9 cm = 12.6 inches (approximately 12 1/2 inches)
Width (W) = 51.5 cm = 20.3 inches (approximately 20 1/4 inches)
Depth (D) = 19.7 cm = 7.76 inches (approximately 7 3/4 inches)
Posted on May 04, 2010
What size of box in need Pioneer TS-W310D4
if its pioneer shop at walmart lol !!! try a speaker shop or read the manual it has that kind of info in it
Feb 25, 2013 | Pioneer Ts-w309d4 tsw309d4 1400w 12" Dual...
What size box should i build fro two pioneer 12inch speakers 1200watts each
For optimal performance there is really only one size for the box .Firstly, you get two different types of subwoofers, an open air, or closed air sub. If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long. If it is a 12 inch speaker, the box size will be 13 inches x 13 inches x 13 inches.
Mar 17, 2011 | Pioneer TS-W307D2 12" 1200 Watt Champion...
This isn't much of a problem as it is a qestion. Is there a was I can hook up my Pioneer car sprekers to a TV or an electric piano? If there is, can you describe materials I need and what I would need to...
You'd have to know what impedance the TV amp is (probably 8 or 16 ohms). Then you would have to match the impedance of the car speakers to that impedance. Tthe car speakers are likely 4 ohms, in which case you'd have to series 2 of them together (or 4 if the TV amp is 16 ohms) for each channel of the TV amp. You'd probably also prefer to mount them in an enclosure, since the power output on the TV is probably really low.
This assumes you're not trying to add a power source of some sort, but are intending to power the speakers off of the TV or piano.
Speaker wire/stripper, **** connectors, spade connectors to fit speaker terminals, crimper.
Nov 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Speaker works but smokes
need more info . what i know is this a subwoofer voice coil gets red hot in color its like the flame on a blowtorch when being played at high volume from the electrical current running through it . when the speaker is brand new you notice the smells like its on fire or burning up . this is normal it just breaking in the speaker . it goes aways few minutes later ...
give me more info into what is happening i can help you
Oct 14, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I don't get d true bass quality from my car system...
Firstly, If it is an open air sub ( hole with mesh in the center of the magnet) no ports are required, and the box should be sealed on the inside with silicone sealant. If it is a closed air sub ( no hole in the magnet) you need a 50mm port about 120mm long Box size will be 13 inches x 13 inches x 13 inches.
May 14, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Is my 1200 pioneer amp a good match for my 1200 watt pioneer sub
this is too close, your speaker wattage is alway's higher than your amplifier's wattage alway's to be safe because the hard pounding will make the speaker work harder, and this will cause your speaker burn out easily, though you can adjust your amplifier anyway's
May 08, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What amp should i buy for my pioneer ts-w2501d4 10" subwoofer???
great qweastion it all depends on how many speakers you want to run of it dont make the mistake of just amping your subb amp every speaker in the car thats why amps have gains (vol controls) you can send as much power to witch ever speaker you want and less to what ever you dont like fading and balancing and hey you have gotta get some tweeters they make the world of diffrence but each speaker needs a channel so if you have 4 speakers a 4 channel amp and so on good luck with it have fun
sonic boom electronics australia.
Apr 21, 2010 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What are specs for a ported subwoofer enclosure for a 12" pioneer champ series
TS-W307D2
Design and Specifications
12” Dual Voice Coil (DVC) Subwoofer for Enclosure applications 1,200 Watts Max. Power Handling 400 Watts Nominal Rating Qts = 0.44 Xmax = 8.7mm Fs = 33.9 Hz Vas = 42.2 litres Frequency Response : 18 ~ 500 Hz. Efficiency : 89 dB Impedance : 2 x 2 Ohm (Total 1 or 4 Ohms) Delivered with “jumper link”: ready for 4 Ohm use f0 (Lowest Resonant Frequency) : 33.9 Hz. Recommended Sealed Enclosure : 24 ~ 49.6 Litres RECOMMENDED sealed enclosure, not Ported. 24 Litres = 1464.569 cu. inches 49.6 Litres = 3026.777 cu. inches
Nov 23, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
What kind amp should be use for ts-w307d2 subwoofer speaker?
Nice sub, i have 2 308d4s in my car. Okay this sub is a dual coil 2 ohm. so to get best bang for your buck you'll want a 2 channel amp and bridge it. Your sub is 400 watts RMS, So you'll want an amp that has the same rating. I'd recommend the pioneer GM-5400t. Then wire your voice coils in parallel, and bridge your amp, you'll get 380 watts RMS, which is perfect for this sub. If you have questions on wiring or anything you can just ask. thanks, i hope this helps
Oct 20, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
I need instructions connecting my car subwoofers
Bridging your amplifier @ 4 ohm will yield the most power.... with the subwoofers you have.
You must wire them in Parallel.
Positive on both subwoofers to + on amplifier.
Negative on both subwoofers to - on amplifier.
The lowest impedence possible with 8 ohm woofers is 4 ohms.
Thank you for using FixYa - a FixYa rating is appreciated for taking the time to answer your FREE question.
Mar 28, 2009 | Pioneer TS-W307D2 12" 1200 Watt Champion...
Pioneer TS-W307D2 12" 1200 Watt Champion Series Subwoofer - 2Ohm Car Subwoofer Logo
1,489 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
