Question about Philips 42PFL5332D 42 in. LCD Television
Converter for myTV
I have a 42'' Philips LCD (Model No.42PFL7422D/37). I want to use this TV in India. Wiil it work there or do I need to use a converter. If I need to use it can you suggest one that is compatable with my Tv. Thanks, Ramana.
  • 111 Answers
This all depends on what you want to do. watch TV, play games , watch dvd's... there is no region code associated with the TV, but you might want to check if your TV supports pal and ntsc.
Posted on May 04, 2010
Tip
42PFL7422D/37 Flat Panel LCD TV no picture no sound
I HAVE A 42 INCH PHILIPS MODEL 42PFL7422D/37 TV.
MY PROBLEM IS THAT IT HAS NO PICTURE AND NO SOUND.
THERE IS A GLOWING BACKLIGHTING.
THERE IS A BLUE LIGHT WHEN I TURN POWER ON THE TV. NO CLICKING RELAY SOUND.
MY PROBLEM WAS IN THE SLAVE INVERTER BOARD.
THE IC CHIP WAS BLOWN - SEE PICTURE. THERE IS A BURNED, DARK BROWN MARK ON ONE OF THE CONTACT LEADS ON THE CHIP.
THERE ARE $20 FIX IT KITS THAT YOU CAN BUY ON EBAY TO REPLACE THIS TINY LITTLE CHIP BUT IT'S RECOMMENDED THAT YOU SOLDER VERY CAREFULLY. I TRIED, AND DAMAGED THE BOARD SO I BOUGHT A USED ONE.
REMOVING THE IC CHIP IS PROBABLY BEST DONE WITH A HOT AIR SOLDER GUN. THEY COST ABOUT 50-200 DOLLARS.
AFTER INSTALLATION IT FIRED RIGHT UP.
IN ADDITION TO THE JUST BUYING ANOTHER INVERTER BOARD, I ALSO TESTED THE MASTER INVERTER TRANSFORMERS. ON THE POWER SUPPLY BOARD, I TESTED THE DIODES, AND RESISTORS, AND CHECKED THE FUSE.
AFTER ALL OF THE ABOVE, I UPDATED THE FIRMWARE BY GOING TO THE PHILIPS WEBSITE.
LUCKY FOR MY SITUATION IT WAS NOT THE MASTER INVERTER, MAIN , TCON, POWERSUPPLY, OR DAMAGED BONDING ON THE LCD PANEL ITSELF.
TOTAL COST $50.
GOOD LUCK!!!
on Dec 23, 2011 | Philips Televison & Video
I have a Philips 42PFL7422D/37 42-Inch that went out a few weeks ago. After some research i figured it was the power supply board, not it. I knew it had fried some caps somewhere, replaced the master and...
Good day Richard!!!
Actually sir there's no way of figuring out the screen whether it is good or bad unless you try to test it in actual..
You said your unit is working fine now but the screen have cracked right?so you need for that TV from ebay is the screen only?. if that so,it should be the same brand and model for your old one..
If the brand and model is the same..just swap all board such as T-con,main,powers supply and inverter board from the old TV to new from ebay that's it..
The only thing you can visually check if there is a crack..But don't worry LCD screen is not like plasma that burnt gone bad even there is no crack on it..LCD screen is not gone bad unless it broke or have crack inside like yours..
Hope my suggestion will help you..
If you have more queries or clarification just reply to this tread...
Thanks for using fixya..
Feb 28, 2012 | Philips 42PFL7422D 42 in. LCD TV
Philips 42PFL7422D/37 42-Inch 1080p LCD HDTV Picture went out but still have sound. Any tips on how to fix it?
If the backlight of the LCD-panel does not function, (no picture) then Master and/or Slave inverter are defective. Inverter boards are screwed to both sides of the LCD display, if they have revision 1.2 boards then they will need replaced with revision 1.3 boards.
Feb 16, 2011 | Philips 42PFL7422D 42 in. LCD TV
My Philips LCD TV just changes channels by itself
it could be one of the buttons to change channels is jammed
Jul 13, 2010 | Philips 42PFL7422D 42 in. LCD TV
Philips 42PFL5332D 42 in. LCD Television Logo
107 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
