I have an Element FLX-3710 that has a blank screen. Once the TV is turned on, (no on screen menus) it will not allow you to use the remote or front panel buttons. It appears that the backlite is on. I have replaced the T-con board and power supply without any luck. The inverter board is making a loud humming noise, when I disconnect the plug from the power supply to the inverter it stops humming. Is my problem with the inverter, or is it the control board located in the same metal box as the power supply?
  • 12,061 Answers
Http://www.retrevo.com/support/Element-FLX-3710-TVs-manual/id/21399ci070/t/2/
http://www.avsforum.com/avs-vb/archive/index.php/t-622573-p-2.html
If the Inverter board is making a LOUD humming noise that indicates that it is being overloaded, you need to check, the "Other" side of the Power Supply, and find the cause of the Overload, quite possibly, you will have something that's getting HOT drawing too much current. Hi, well I applaud you for wanting to have a go and try to repair you set. But PLEASE, start in the right place, otherwise you will simply waste your time and money, You see, you MUST start, in the right place, The power supply, FIRST, as, if, that isn't right, nothing else can be. But you simply cannot do anything without a Service Manual. In this it has everything one needs to repair the set. OK if it is shutting down, after that amount of time, of working and then faulting, then it is most definitely a "Thermal" problem, the way we "Find" problems such as this is "Freeze Spray" you use this on each component that is suspected of being the "Culprit" and you will soon,find that errant component. Now, also not every fault is a Capacitor, I see many, many people that think, that Capacitors are always the "Culprit" and replace them, because someone else had done so and it worked, well that maybe sometimes true, but most Symptoms, can, and do have many, many different "Causes" & also, now while that may be true in a few cases, a faulty Electrolytic Cap, or even, ordinary, Cap goes faulty, this is only a SYMPTOM, something has damaged those caps causing them to "Fail". One MUST always find the root "Cause", otherwise if you just treat, the SYMPTOM, the "Cause" will just make the "Symptom" come back, in short order, as the prime cause still, hasn't been fixed., Now Capacitors hate AC ripple, or Over Voltage. Thats it. Oh.. and Heat, if these Capacitors, are too close to a Heat Source, then thats a prime cause of failure. Resistors, hardly ever go faulty,and if they do, it is generally obvious. However it doesn't hurt to check values with our Multimeter. Remember though resistors are made, with up to 20% tolerance from stated value, as such, are not too critical, unless in Timing circuits etc. Always check, the Values, of resistors, as with any other component, with the power OFF. Now Diodes especially "Zener Diode", are another thing to check, those and ordinary "Signal Diode" should always be suspect. next we have Transistors and IC's. The Transistors MUST ALL be checked to see if they have a good, "Junction" this is done, with our meter set to "Diode Test" and usually are about 0.6 to 0.7. With IC's you must check, voltage levels, or Logic Levels, going in and out, have a look at the circuit diagram, and it will tell you what they should be. It is a good idea to always measure the Power Supply voltages, see if a "Rail" is Low, that will be because some component has gone somewhat or all short circuit, to Earth, now, if the "Rail" is Higher, suspect an "Open Circuit" component, like a Diode, or Transistor. The voltages expressed in the manual are spot on, ANY variation MUST be investigated. I have been doing all this for over 30 years now, and I do indeed wish, we could have a set of "Symptoms" and be ables to say.. "Oh that;s the so-in-so and replace this" however unfortunately this although does happen, most "Symptoms" can have literally tens, of "Causes" all often "Interlinked" One simply has to do a methodical troubleshooting procedure, and always think, "are my Voltages Correct" as this is how, you Fix the problem, by making them so. Keep up the good work. If that link above doesn't furnish a Service manual, it is imperative you get one, even if you must pay for it. It will pay for itself in about 2 mins.
http://www.docstoc.com/docs/13628035/7581727-Sanyo-TV-LCD-Training-Manual/
http://www.scribd.com/doc/22277758/Toshiba-TV-LCD-Training-32wl36p
have a look at these two manuals above, these will give you good insight into what you are dealing with.
http://www.my.electronicshelponline.com/uploads/Polaroid_FLM-Series-26-32-37-Service_Manual_Final_NA_20070418.zip
Posted on May 04, 2010
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
Since you have no on screen display I would suspect the control or main board that processes all signal including the OSD.
Let me know what you find and as you have by now learned with sets of this type is replace and see what happens.
SD TECH
How to turn on element flx 3710 without remote
Operate the power switch on the front panel
May 18, 2017 | Element Televison & Video
Connecting computer to Element flx-3211b via HDMI not working
I had the same issue with this TV in my hotel room. I set the FLX3211B TV up as an extension of my laptop, but had to change the refresh rate from the default 58p Hz to 60p Hz for the digital TV display. Once I did this, it came right up.
Feb 26, 2013 | Element Electronics FLX-3211B 32 in. LCD...
I had sound but no picture on my Element Electronic FLX 3211B LCD Television Set. I replaced two capacitors, and now I have lit screen by turning on the tv on the side panel. Remote does not control the tv...
You might have bad capacitors still that you cannot see. The only way to be sure is with an ESR meter. Check all the connections on the boards again to be sure that the sensor for the remote did not come off.
Sep 08, 2012 | Element Electronics FLX-3211B 32 in. LCD...
To program a Ge rc24991-c to operate a element 3710 tv
I doubt the Ge will even program for that set---Google both the model number of the remote and the set to locate the available information.
May 13, 2012 | Element Electronics FLX3210 32 in. LCD TV
I have an element flx 3710 flat screen tv. It does not have a power button and I lost the remote, how do i turn it on
Look along the bottom of the front of the set. The buttons are marked located there.
VOL- VOL+ CHAN v CHAN ^ MENU INPUT power/on
You can also get the user's manual from;
http://www.retrevo.com
by entering the necessary information.
Mar 26, 2011 | Televison & Video
I have a Element tv model #FLX-3710 and when I turn it on I only get a blue screen.
checked first the signal from ur cable/antenna it seems you haven't a signal from there that's why u got only a blue screen....
Dec 26, 2010 | Televison & Video
I have an element 37in. flx-3710 tv. lately whwn i turn it on the screen stays blacks and flickers for a few minutes untileventually the picture appears.however the picture is either washed out or so dark,...
ldq781, I think you or electronics technician should investigate the units internal "switch-mode-power-supply/cold cathode-fluorescent lamp electronic ballast circuit(inverter) for "failed" "swollen" electrolytic filter capacitors and or "poor quality" soldering of the electronic components to the copper foil traces of the printed circuit board(power supply board) The first thing to do is visit YOUTUBE for video clips of lcd monitors being repaired for these typical types of "failures" which are most common to both types (monitors and lcd tv's) After you do your research then return here and leave additional reply if you still need help. 12fixlouie
Sep 24, 2010 | Element Electronics FLX3210 32 in. LCD TV
Televison & Video Logo
70 people viewed this question
Top Televison & Video Experts
Electro Med Services...
