Question about Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How to connect electroic equiptment . Cable converted to tv
  • 111 Answers
This depends on whether you are using a high definition box or not. If you are then try to use hdmi cable. very easy to find open port on the back of the tv. but some cable boxes do not support hdmi, so that leaves you with component cables which are 5 cables in one(red,blue,green,red,white). just watch your color codes and plug them in from the box to the TV. keep in mind that there are 2 red ones. one for video and one for audio. but they are labeled.
Posted on May 04, 2010
I have a 42panasonic plasma tv model#th-42pwd7 it has no cable antenna terminal in the back of the tv but it has rgb terminals i have a converter box and x box360 how can i get a antenna tv signal
Its a Progressive Wide Plasma Display. It wont have a built in Turner. So you will not be able to connect antenna to the TV.You have to use a set top box or cable box and connect its output t the TV.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 12, 2016 | Televison & Video
No sound via philips soundbar hts8100 with philips 52pfl7403d tv
If you wish to get some details; check the site linked here. Pull up older posts......
Sep 09, 2016 | Philips Televison & Video
Can computer be connected to tv screen via usb to usb ..there is a usb port on tv
Its not possible to connect the PC trough usb. You have to use a VGA to rgb converter or Vga to Hdmi converter to connect your PC to TV.
Apr 21, 2016 | Televison & Video
What button do you push for the magnavox converter
It will depend on where did you connected the converter to TV. If it is connected to AV; select the input to TV as AV. Electro help
Oct 08, 2014 | Televison & Video
Denon AVR 1609 7.1 Channel Receiver turns on but i get no sound thru the optical to the tv. what could be wrong?
If you have your video equiptment hooked to your reciever input, then, out to TV, This isn't the best way to go. Of course it depends on what you have for input and output on your TV but, the ideal way to hook your system would be to hook all video equiptment to TV, ie:, cable/sat box, DVD player, etc., to TV via, HDMI, Composite, RCA, etc., then run your digital optical out from TV to reciever. You would use the TV's menu to choose what you watch and would only have one input(audio) to reciever. Some recievers are set up to transfer video, but, it uses more cables, creates more connections, and more room for error.
Jun 13, 2011 | Denon Audio Players & Recorders
I JUST BOUGHt a ps3. I am trying to connect it to my tv through a converter box. I have it all connected, but it does not play on my tv screen. What can I do to make it play?
What do you mean converter box? RF converter? The video audio cables (R,W,Y) should be connected to the matching colors on the RF converter and the RF cable (standard cable)should be connected from the RF conv. where it say "to TV" to the TV and the TV should be set to either Ch3 o Ch4 (you can usually choose on the RF conv.) the cable from the cable provider should be connected to where it says "in from antenna or cable in on the RF conv.
Oct 17, 2009 | Televison & Video
I have old tv with rf connection need to adapt to rca plugs
Simply insert the converter between the curent cable and the TV. The converter should have come with a short RF cable that you can use between teh converter and the TV. I have incluede a before and after line diagran below.
Dan
BEFORE: cable==> TV
AFTER: Cable==> converter ==>TV
Feb 25, 2009 | Insignia Digital-to-Analog Converter for...
How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Jan 01, 2009 | Televison & Video
What do I need to get for viewing HDTV
The TV you have will only process an HD via the component video connections. Your cable box needs to have component outputs and you will need to buy a component video cable to connect from the cable box component video outputs to the TV's component video inputs (should be 2 sets, #1 for up to 720p and #2 for up to 1080i...
Oct 28, 2008 | Samsung PCL5415R TV
LCD TV
HD ready does not mean it has a digital tuner.
don't know what TV model you have but any TV with a coaxial connector will receive the analog broadcast. However; if your TV is not equipted with a digital tuner, you will need a set top box when analog broadcasts stop transmitting in Feb.
Aug 21, 2008 | Televison & Video
Sony BRAVIA KDL-40S2000 40 in. LCD HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
