Question about Sony Playstation 3 (PS3) Console
Cant connect to internet
I go to network settings on my ps3 and then i go to internet connection settings. it asks for easy or custom method i choose easy, and it says attempt to obtain an IP address timed out. What do i do?
    President:
  • 1,382 Answers
If you are using a router, the problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it close to the PS3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem, press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually) If you are getting a connection then you are ready to go.
Posted on May 04, 2010
Where is the aoss button about on ps3 for wireless network i cant get wireless untill i press the aoss button
The PS3 does not have an AOSS button. AOSS (AirStation OneTouch Secure System) is used for wireless setup of devices for your network. Your router will have a button on it for this. If it does not then it more than likely does not have the ability to set devices up in this manner.
To use this set up for the PS3 go to Settings - Network Settings - Internet Connection Setting - (Method) Custom - (Select Connection Method) Wireless- (WLAN Setting) Auto - AOSS. At this point the PS3 will tell you to push the button on the router and that you have two minutes or else the attempt to connect will stop.
Read more: http://wiki.answers.com/Q/Where_is_the_aoss_button_located_on_ps3#ixzz18gdqKO2T
Dec 20, 2010 | Sony Playstation 3 (PS3) Console
Tip
How to connect a playstaion 3 to the internet
here are 2 ways to connect your PlayStation 3 to the Internet; using a wired (Ethernet) connection or through a wireless connection. <img src="ps3_connection.jpg" /> <br /> <span>1. Wired Connection</span> 1. Make sure that your PlayStation 3 is connected to a broadband-enabled network using an Ethernet cable.<br /> <br /> <img src="full_setting.jpg" /> 2. Click <b> Settings </b> in the Home menu, then <b>Network Settings</b>. <br /> <br /> <br /> 3. Click <b>Internet Connection Settings </b><img src="network_icon.jpg" />. Then press the <img src="cross.jpg" /> button. <br />4. A message will pop up saying that you will be disconnected from the Internet. Choose <b>Yes</b>. Then press the <img src="cross.jpg" /> button. <br /> <br /> <img src="ps31.jpg" /> 5. When you are given the choice of connection methods choose <b>Wired Connection</b>.<br /> <img src="ps35.jpg" /> 6. Choose <b>Easy</b> - the basic settings are automatically set. <br /> 7. Now click <b>Save</b>. <br /> 8. If you want to you can now test your wired connection by clicking <b>Test Connection</b>. Your PlayStation 3 will now try and connect to the Internet. If the connection isn't successful you should follow the instructions which will appear, to check your settings. <br /> <span>2. Wireless Connection</span> 1. Click <b> Settings </b>in the Home menu, then Network Settings. <br /> <img src="full_setting.jpg" /> 2. Click <b>Internet Connection Settings </b><img src="network_icon.jpg" />. Then press the <img src="cross.jpg" /> button. <br /> 3. A message will pop up saying that you will be disconnected from the Internet. Choose <b>Yes</b>. Then press the <img src="cross.jpg" /> button. <br /> <br /> <img src="ps31.jpg" /> 4. When you are given the choice of connection methods choose <b>Wireless Connection</b>. <br /> <img src="ps32.jpg" /> 5. Now choose <b>Scan</b>. Your PlayStation 3 will now search for any available access points and show these in a list. <br /> Note: Some PlayStation 3 models have an 'Automatic' option, which if followed will complete the required settings for you automatically. Simply click on <b>Automatic</b> if the access point you are using supports automatic setup. <br /> <img src="ps33.jpg" /> 6. From the list of access points choose one which you'd like to use. <br /> <img src="ps31.jpg" /> 7. Check the SSID for the access point, press the right button. If you don't know what the SSID is then you should contact the person who setup or runs the access point for more information. <br /> 8. Select the security method necessary, press the right button. <br /> <img src="ps34.jpg" /> <br /> <br /> 9. Enter the encryption key. This will be shown as a series of asterisks (*). If you don't know what the encryption key is you should contact the person who setup or runs the access point for more information. <br /> 10. Now press the <b>right</b> button. <br /> <img src="ps35.jpg" /> <br /> 11. Choose either <b>Easy</b> or <b>Custom </b>and adjust the settings. <br /> <ul> <ul> <li> <b>Easy</b> - the basic settings are automatically set. </li> <li> <b>Custom</b> - you will need to enter the settings manually. </li></ul></ul> 12. Now click <b>Save</b>. <br /> 13. If you want to you can now test your wireless connection by clicking <b>Test Connection</b>. If the connection isn't successful you should follow the instructions which will appear, to check your settings. <br />
on Mar 22, 2011 | Video Game Consoles & Games
Tip
Connect PS3 to the Internet
Wired Connectivity:
The network configuration and connection depends on the connection method and equipment you have.
Important: A router would be required if you want your PS3 and the computer to be connected to the internet at the same time.
The following are mandatory. You need:
  • An Internet connection
  • A cable modem
  • Ethernet cable. (Available with the PS3)
When you have a wired connection to the Internet, it is not necessary to adjust any of the default settings. (It is done automatically). If you aren't able to connect with the default settings, follow the instructions to adjust the settings.
  1. Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  2. Select "Internet Connection Settings", press the x_button.jpg button.
  3. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  4. Select "Wired Connection", press the x_button.jpg button.
  5. Select Easy or Custom and adjust the settings.
    • If you select Easy, then the basic settings are automatically set.
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your Internet service provider.
Back to top
Wireless Connectivity:
  • A cable modem and a router
  • Access point (Not necessary if using a wireless router with built-in wireless functionality)
  • Settings information for the access point (SSID, WEP key, WPA key)
When you try to connect wirelessly to the Internet, First adjust the network settings. These settings may change depending on the type of access point and the network environment you are in.
The following instructions apply most of the network configurations.
  4. Select "Wireless", press the x_button.jpg button.
  5. Select "Scan", press the x_button.jpg button.
    The system will search for access points within range and display them as a list.
  6. Select the access point that you want to use, press the x_button.jpg button. (An SSID is a code or a name that is assigned to the access point. If you have no clue which SSID to use or if the SSID is not displayed, contact the person who set up or maintains the access point.)
  7. Confirm the SSID for the access point, press the right button.
  8. Select the security settings as necessary, press the right button.
  9. Enter the encryption key, press the right button. (The encryption key field will display an asterisk (*) for each character you enter. If you do not know the key, contact the person who set up or maintains the access point).
  10. Select Easy or Custom and adjust the settings.
on Feb 20, 2010 | Video Game Consoles & Games
Can i hook up my ps3 to a wired internet
Wired Connectivity:
  • A cable modem
Sep 13, 2010 | Sony Playstation 3 (PS3) Console
Can not connect to internet Do I need to connect directly to the modem. i have wireless Interent in my home but th emodem is 3 rooms away. Should I get a second modem?
here try this and remember to leave a testimonial.
Wired Connectivity:
  • A cable modem
  • Ethernet cable. (Available with the PS32_bing.gif)
  • When you have a wired connection to the Internet2_bing.gif, it is not necessaryto adjust any of the default settings. (It is done automatically). Ifyou aren't able to connect with the default settings, follow theinstructions to adjust the settings.
  • Select "Network Settings" under "Settings" in the home menu, press the x_button.jpg button.
  1. Select "Internet Connection Settings", press the x_button.jpg button.
  2. You will be popped with a message stating the Internet connection will be terminated, select Yes, press the x_button.jpg button.
  3. Select "Wired Connection", press the x_button.jpg button.
  4. Select Easy or Custom and adjust the settings.
    • Wireless Connectivity:
When you try to connect wirelessly to the Internet, First adjust thenetwork settings. These settings may change depending on the type ofaccess point and the network environment you are in.
Apr 09, 2010 | Sony Playstation 3 (PS3) Console
I cant connect to the internet
Playstation 3: How to setup your Internet connection This article helps you in setting up the Internet connection for Playstation 3 To enjoy the online capability of Playstation 3, you need to connect it to the internet. You can do it in two ways:
  1. Wired Connectivity.
  2. Wireless Connectivity.
Wired Connectivity:
  • A cable modem
Back to top
    • If you select Custom, then you need to enter the settings. Refer the settings supplied by your provider
Apr 08, 2010 | Sony Playstation 3 (PS3) Console
Cant find aoss button on ps3
Directly from: http://wiki.answers.com/Q/Where_is_the_aoss_button_located_on_ps3
Apr 06, 2010 | Sony Playstation 3 (PS3) Console
Can u please help me connect my ps3 to play games online i have usb modem connected to laptop, with ethernet cable connected to ps3 from laptop......... i live in australia
Wired Connectivity:
  • A cable modem
Back to top
Feb 20, 2010 | Sony Playstation 3 (PS3) Console
Cant connect to wireless network on my ps3
First off you have a wireless router hooked up to your ISP correct.
anually set a static IP for your wireless connection (When going through the network setup in Network Settings --> Internet Connection Settings (wireless), choose Custom instead of Easy when the page asking for either appears).
Set the IP address to something outside your DHCP range. e.g. 192.168.0.5 (for dlink router) or 192.168.1.5 (Linksys router)Default gateway should be the IP of your router. For dlink, this should be 192.168.0.1 and Linksys should be 192.168.1.1DNS Server can be the same as your default gateway, mentioned above.
Subnet Mask should be 255.255.255.0.If you're using some sort of encryption (WEP, WAP, etc), set it in there as well when it asks to do so.
And that should get you going. I actually haven't done this on the ps3, but its my info from experience with regular pc to pc networking.
Also If you haven't tried this already, change the wireless channel from 6, to 1 or 11 in your router and wireless consoles.
If all else fails, try this http://www.clanbluntforce.com/forum/index.php?topic=864.0
Nov 21, 2009 | Video Game Consoles & Games
Cant find out how to get my ps3 with internet
if you have wireless you can hook it up that way.
if you have wired or DSL network you can hook it up that way too.
in addition you need a playstation network user account.
to hook up your ps3 to the net go to settings, network connection and choose custom network connection then it will show you wireless or wired then choose whatever you have. then just go through and dont change any settings until it runs the connection test then it should work
REMEMBER TO GET PLAYSTATION NETWORK ACCOUNT IN THE PLAYSTATION STORE AFTER YOU SET IT UP!!!!!
Jul 11, 2009 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
