Question about Philips CDR796 2-Disc CD Recorder
Phillips CDR 570
Hi there,My Phillips CDR 570 will not un finallize anymore and just now, when I record on it, it will not update the last track. What can i do?Cheers,Barry
    Brigadier General:
  • 8,546 Answers
Let's start with an assumption... you're using ReWriteable discs.
What specific message do you get when you try to unfinalize it?
When finishing a recording, what does it display instead of "update" when you stop?
Posted on May 04, 2010
To Determine CD recording problem: Track1 records and plays back O.K. Upon completing track2, display window flashes continously "Now PMA" (Updating disc contents) NO playback or sound on track 2.
It is possible that until you finalize the disc, the only track that will play is the first one. Unfortunately, once you finalize the disc, you cannot record additional tracks to it. You can verify this by finalizing after recording the second track and seeing if they then both play. If that works, you can safely burn additional discs with confidence that they are burning correctly even if you cannot play each back after burning and must wait until finalization to test full burn.
Sep 26, 2016 | Denon CDR-W1500 2-Disc CD Recorder
I consistantly get an update message after trying to record disc to disc as little as one track why?
That is best discussed with the Philips support people as there could be a reset procedure. I have never heard of this but you may have caused the unit to enter a different mode by doing an overburn attempt.
Dec 19, 2012 | Philips CDR775 2-Disc CD Recorder
I just bougth a marantz cdr 300 cd recorder,everything seems to be working fine, but I'm not able to listen what I just recordered on any other cd player.Marantz cd 72 mr 2020.Thanks
It sounds like you haven't followed the last step to the burning procedure. All you need to do once you've completed burning your disc is to Finalize the disc. Read below why you need to finalize as well as the steps to follow in order to finalize the disc.
Hope this helps ;)
How to Finalize Finalizing is writing the TOC (table of contents) on a disc so a CD player can recognize the number of tracks, the total time for each track, and their location on the disc. A recorded disc must be finalized to playback on a standard CD player. Once finalized a CD-R disc can be played on CD players that support CD-R playback. CD-RW discs can only be played on CD players that support CD-RW playback. Consult your CD player owner's manual to confirm supported formats. Finalizing is necessary to: • be able to play a recorded CD-R or CD-RW disc on a CD player • prevent further recording on a disc • avoid erasing tracks on a CD-RW disc • record text information onto a disc you record Notes: • A finalized CD-R disc can never be recorded onto again. • A finalized CD-RW disc can be unfinalized for more recording. • The CDR300 can play back unfinalized CD-R or CD-RW discs. • SYNC REC+FINAL mode automatically finalizes.
Here are the steps in order to Finalize your disk
1 Push Stop. The display shows the number of tracks and their total playing time. 2 Push FINALIZE. FINALIZE is displayed for about 3 seconds.
Jul 27, 2011 | Audio Players & Recorders
Phillips cdr 200 recorder, just recorded 13 tracks with time left over on sony brand recordable cds for music. i switched from analog to digital to finalize and it took 4 mins however RECORDABLE still...
It sounds like it didn't truly finalize. Try finalizing it again since the 'recordable' status implies it still qualifies. You have to press RECORD immediately after FINALIZE.
The Philips directory lists a few CDR200 models but the documentation contains directiosn for CDR765.
http://www.p4c.philips.com/files/c/
for example...
http://www.p4c.philips.com/files/c/cdr200bk/cdr200bk_dfu_aen.pdf
If for some reason you ever want or need to extract music from a non-finalized CDR or CDR-W, try loading it into a standard DVD player. Without a TOC the player won't be able to display track info or navigate to individual tracks but it MAY play it straight through anyway and you could digitally capture all or part of the output on another CDR. Just be aware that if the original is rewriteable and has old data beyond the new data you will crash into it without warning at the end of the new data, so be ready to pause your copy at the appropriate time.
Apr 07, 2011 | Philips Audio Players & Recorders
Hi , My cdr 830 stopped recording at maximum fidelity, and most recently all data disappears upon finalization, the prompt reading "new disc" after recording a whole 70 plus cd. Frustrating...
I can't speak to the hardware issues that might be at play here but I would advise you to retain the 'bad' recordings. I've copied unfinalized CD's from an old DVD player. It will read the CD but you won't be able to manuever around the tracks. As I recall, the track marks will still be there.
I don't know what you mean by 'maximum fidelity'. The CDR records at the CD standard of 44.1kHz. Digital is all ones and nones. Just data. If it is written correctly or with tolerable errors the ADC of the player (ANY player) turns it all into music.
Mar 02, 2011 | HHB BurnIt CDR830 CD Recorder
I have a Phillips CDR 775 2 -disc cd recorder and my track time is automatically set to 20 seconds. How do I increase this time per track? Also, I cannot seem to get the auto track to work when...
It's all in the manual...
20 seconds is the amount of digital 'silence' the machine will let pass during recording before it marks a new track. t will Pause and wait one minute for a digital signal to resume. (Page 21)
On digital copying it will automatically increment track numbers as the source advances.
For analog sources you should switch Auto Track to OFF and manually press Track as applicable. (Page 28)
Jan 21, 2011 | Philips CDR775 2-Disc CD Recorder
Phillips cdr775/00 how do i record from laptop headphone socket into recorder i n=have tried my usual lead jack to two phonos it says start source when i do no signal comes into recorder analogue in
MANUAL RECORDING FROM COMPUTER HEADPHONE SOCKET.. FIRST RIGHT LEAD REQUIRED YOU NEED STEREO 3.5mm stero jack plug to lef right phono male leads... prepare for manual record place jack in computer headphone socket. check correct socket play track on computer their should be no sound. if sound present in wrong socket... if ok place phono left right into analogue aux inputs on cdr recorder.next make shure you have blank scratch free cd .next press ext(ernal) source repeatedly until the required input is selected i.e digital analogue optical etc..when auto track is on the disk will number automatically.with auto track on it their needs to be 2.7 second gap to rec number change. with the recorder stopped press rec type five times to enter in the manual record standby mode. manual start s to flash and the display shows REC EXT MAN followed by WAIT.after a few seconds press record . play the source track ie on your computer to set record level on cd recorder.. adjust audio card settings or volume control on pc etc .rotate easy jog/enter key until on the record /play level bar all the blue led are alight but not the red( clipping) display shows xx decibel eg 3bd. stop the source material (track on computer get ready to record ii.e to start track again..to start recording set you track going wilst pressing RECORD on the cd recorder, and immediatley the source material playing. the track number and recording time left appear in display . if check input message is displayed check the connections are correct etc .to stop recording press stop on cd recorder . update lights up and arrow goes out. after recording display will show UPDATE FOR SEVERAL SECONDS WRITTING TOC.. IF YOU WANT TO PLAY THIS DISC ON NORMAL CD PLAYERS YOU NEED TO FINALIZE THE TRACK . HOPE THIS HELPS..yammandan.
Aug 19, 2010 | Philips CDR775 2-Disc CD Recorder
Problem with Finalizing Disc
When you insert the disc what does the recorder display after it examines it (Reading TOC)? - CDR, TOC, CDR-W, NO TOC?
It should know the disc is not finalized and let you either record more on it or finalize it.
If not, and you need to recover the 4 tracks try loading the disc on a DVD player. My old Pioneer will read unfinalized CDR-A's so I can digitally copy what's on them back to another CDR-A.
Apr 13, 2010 | Tascam CC-222mkIII CD Player / Recorder
Need user manual
I have the CDR-200 and did not have the manual either. However, I did discover the same problem and found the solution. There is a "confirm" button on the front of the unit under the display area. After you press the record button "Record" will begin to flash in the display area and then you press "Confirm". It should start recording. Note however the following:
BURNING FROM EXTERNAL CASSETTE OR PHONO
Before starting this procedure make sure you have an AUDIO recording CD in the RECORDER tray of the CDR-200. A regular CD-R type of disc for computers is not going to work and may cause an annoying message on the display which does not go away until you put the right type of recording CD in the unit. It must be either an AUDIO CD-R or an AUDIO CD/RW.
1. When copying from an external cassette deck, you should set the source (press source button) until the setting is "Analog".
2. The "Dual" button should not be in effect. In the lower right portion of the screen you should only see a small number "1" with a circle around it. This indicates the CDs currently being used by the burner. In "dual" mode you can copy from the Playback CD of the CDR-200 to the Recorder CD. In dual mode you see "1" and "2" with circles around them. The active CD tray will flash on the display.
3. When copying from an external cassette unit, you use the "Record" button to start the recording. At the end of the cassette track you MUST press the STOP button by the CD Recorder tray. After you press STOP the unit will say "Update" which indicates it is closing out the track on the CD-R. You can continue to write tracks by pressing RECORD again, then CONFIRM when the tape is positioned at the right PLAYBACK track. It is usually helpful to have a few seconds of blank tape at the start of the PLAYBACK track before pressing RECORD. Press play on the cassette deck, then RECORD followed by CONFIRM on the CD burner.
4. When the track has finished burning you must press STOP to close the track on the CD-R. After you press STOP, the unit will display "Update" to indicate it is updating or closing the track. When the process completes, the unit will display the tracks it has written to the CD-R and will be ready for you to copy another track or FINALIZE the CD-R. When the unit is waiting after the STOP, you can change the cassette tape, reposition to a playback track and ready the playback tape for more recording. When the PLAYBACK tape is ready repeat STEP 3. Repeat steps 3 and 4 until you have about 14 or 15 tracks on the CD-R.
5. When you have finished recording about 14 or 15 tracks onto the CD-R, you will want to finalize the CD-R. Press the FINALIZE button, and then press the CONFIRM button. You will see the the unit start to display the progress of the finalize by advancing the level meters of the left and right channels in the display. When the unit is finished finalizing it will return to the number of tracks display for the CD-R. After finalizing the CD-R you can play it back to make sure the burn was successful. Be sure to wait for the tracks display before removing or playing the CD-R after the finalize is done. Removing before the finalize is done may damage the unit and may render the CD-R bad.
BURNING FROM THE PLAYBACK CD
1. Set the unit to "Dual" mode. As described above, you will see "1" and "2" with small circles in the lower right portion of the display.
2. Make sure the "Source" mode is set to "Analog" by repeatedly pressing the SOURCE button until it shows "Analog".
3. When copying from the PLAYBACK CD tray you will not use the RECORD button by the CD Burner tray. You will use the 'DUB" button just to the right of the display.
4. Put an audio CD in the PLAYBACK CD tray and press the skip track button ">>" until you arrive at the track you wish to record from. If the track you want to start at is track 1, then you don't need to skip tracks.
5. When positioned at the correct playback track, press the DUB button. The unit will show "CDR" and then "DUB" on the display. When it says "DUB" press the CONFIRM button. The unit will start recording. You can adjust the record level during the first few seconds to make sure you don't have the recording volume level set too high.
6. When the track is finished, you should see the unit indicate on the display "Update". This indicates it is closing the track and it should do this automatically. If it does not do this you may have to press STOP near the RECORDER Tray to force closing of the track. Usually the unit indicates "AUTO" in the display area and I believe that is what controls the automatic track numbering feature. I am not sure how the AUTO feature is turned on. I noticed on the CDR-200 it is on by default.
7. After the UPDATE is complete, the unit will display the number of tracks it has written to the CD-R. You can at this point change the PLAYBACK CD to another one or advance to another track for continued recording. When at the correct track simply go back to step 5 and continue.
8. When you are all done copying tracks from one or more CDs, and you wish to finalize the CD press FINALIZE and then press CONFIRM to start the finalize process. I noticed on the CDR-200 if you wait too long after recording a track the unit may start the finalize process automatically. This happened after at least 5 minutes. It is best to try and stay with the copy process to monitor what is happening. The finalize can also start if you have written to many tracks to the CD-R and it runs out of space. Typically, your safe if you burn about 14 to 15 tracks to a CD-R at a time. You might be able to fit more if the tracks are very short (2-3 minutes each).
One last note about the connections on the back of the unit. Read the labels of the connections on the back very carefully. The CDR-200 and probably the 201 have separate outputs for the PLAYBACK CD (CD) and BURNER CD (CDR). You will want to connect these to seperate inputs on your audio amplifier. Or you might also wish to merge them using adapters into one input on your audio amplifier. If you keep them separate you will need to change sources on the audio amplifier to hear each tray. For example, you might need to switch to "CD/TAPE" for the CD, and "AUX" for the CDR. It is probably easier to merge the two using audio adapters which can be readily obtained from RadioShack.
I hope this helps!
May 08, 2008 | Classic Electronics CDR201 CD Recorder
RECORD DROP OUT
Just bought this CDR 570 and not use yet.
Reading the instruction manual - yes, life experience has taught me some really useful stuff! -
Under 'Discs for recording' on page 7 it says at end of section
IMPORTANT:
To ensure proper working of the set we recommend the use of PHILIPS audio CDR and audio CDRW discs only'
Roughly translated I read this to me - 'don't blame us if the set don't work using other (non-compatible) discs' !!
Oct 02, 2007 | Philips CDR570 CD Recorder
Philips CDR796 2-Disc CD Recorder Logo
192 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
