Question about Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Broken glass wont drain after cleaning
    President:
  • 1,382 Answers
A clog in the drain line or air gap (if there is one) is the usual reason that a dishwasher won't drain. Often the problem is at the point where the drain line attaches to the garbage disposer or household drain line. If you remove this line, you can clear any debris from the hose or hose connection. Be sure to reattach the hose before starting the dishwasher again.
Posted on May 04, 2010
Water not draining
Hello Jerry;
My name is Peter. I am a retired field service appliance technician.
You did not provide a model number so I can only advise in general terms.
If your hose has blown, then your pump is working. I suspect your drain hose is plugged up with soap film, broken glass .....
Clean your drain. Use gloves. You may have broken glass in the drain. If you have a filter clean that. Remove your drain hose and flush it.
If you have a dish washer that requires a special detergent, and you are using a less expensive brand, you are looking for trouble.
After you have completed the above, purchase a dishwasher cleaner and run that.
Dec 22, 2014 | Miele Dishwashers
Will not drain
Hello Keith, thank you for allowing me to assist you!
Often when a dishwasher does not drain, it is because the drain hose may be clogged or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of the unit designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and lift it out. Once you empty the filter, you may wash it with warm soapy water and allow it dry. Then place filter back. However, if you continue to have water left in the sump and the dishwasher is making a grinding noise, then it is recommended that the drain motor be diagnosed. You can locate a certified technician directly through the manufacturer website or in your local directory.
Jan 09, 2014 | Frigidaire Dishwashers
Dishwasher will not drain
Good Morning Gord, thank you for your post!
If your dishwasher is not draining, it could possibly have a clogged drain hose or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of your dishwasher designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and then lifting it out. Place filter back in its location and run a complete cycle. If you continue to have water left in the sump and your dishwasher is making a grinding noise, then it is recommended to reach out to a professional to diagnose the drain motor. You can often locate a certified technician directly through the manufacturer website or in your local directory.
Best regards!
Nov 24, 2013 | Frigidaire FPHD2491KF Dishwasher
Frigidair dishwasher model fphd2491kfo wont drain does every thing else
Good Afternoon Tyler, thank you for your question! Often when a dishwasher does not drain, it is because the drain hose may be clogged or you have a faulty drain pump. First, I recommend cleaning the glass trap that is located in the center of the unit designed to collect pieces of broken straws, bones, glass, etc. The filter can be removed for cleaning by simply grasping the handle and then lifting it out. However, if you continue to have water left in the sump and the dishwasher is making a grinding noise, then there is a possibility that the drain motor may need replacing after a proper diagnosis from an expert. You can locate a certified technician directly through the manufacturer website or in your local directory.
Aug 28, 2013 | Frigidaire FGHD2433KF Builtin Dishwasher
Dishwasher wont pump
Hi - Two things to consider...when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, bones and pits. Simply grasp handle, lift out, empty and place it back. Is the unit making a grinding noise? If so, contact a professional because you may possibly have a defective drain motor.
Oct 12, 2012 | Frigidaire GLD4050RHS Builtin Dishwasher
Dishwasher wont drain, its a 2005 fridgadaire, drain line appears to be fine???
You may need to take the drain pump off and look to see if there is anything like broken glass or other object stopping the impellar wheel.
you can use a wet dry shop vac to remove any water left in the machine.If you do not find any thing in there you may need to replace the drain pump
Dec 12, 2010 | Dishwashers
Onstart up noisy grinding
Most likely broken glass or some other solid debris in the drain pump.Check owners manual to find out how to clean sump ,watch out for shards of glass.
Jun 01, 2010 | Samsung DMR57LFS Stainless Steel Builtin...
Water doesn't drain out of bottom.
Broken glass is caught in the pump. a take apart cleaning of the pump and drain hose is in order.
Mar 13, 2010 | Maytag MDB9600A Jetclean II Built-in...
Dishwasher wont drain all the way
try cleaning out the drain, mine was full of broken glass, food particle, etc. Just pull off the "jet blade", then you can remove the screen filter, then you will surely find a clog under the screen.
Feb 19, 2010 | Dishwashers
Horbart dishwaser wont dran
Its a hobart correct?The data plate is on the bottom right front or on the door when opened on the left.If you dont see it then its been removed.Regardless does the display show a wash then rinse cycle?If so and it doesnt drain you either have a clogged drain hose or the drain valve is bad or stuck.If you use this just to wash glasses your model is probably a lxigc.If glasses are broken in the dishwasher which they probably are the glass has gotten into the drain body and is obstructing the valve from opening and closing.I work for hobart and services dishwashers alot.let me know.
Feb 21, 2008 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Open Questions:
See all Frigidaire 24 in. FDB1050REC Stainless Steel Questions
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher Logo
79 people viewed this question
Top Frigidaire Dishwashers Experts
Mike
Garth Jackson
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
