Question about Home
The 8 inch handle of the frameless glass shower door is lose, wiggles and pops into the glass on the outside. The glassman just took off 2 little screws but said it it is rusted in place and wionf come off. Do I retro fit with rubber gaskets or get it off and replace????
  • 5 more comments
  • Mike Pliskin May 04, 2010
    but the glass expert said the material is rusted so wont work. I cant even find enough gap to allow the allen wrench and screws back in but mind u i have never used tools before. ru sure i shouldnt find a way to get the handle off and replace with new one and hardware. Isnt silicone like glue or caulk and can be a pain down the road????
    Your answer sounds doable if it is done very right. So far I have formated cotten and earplug pieces around the gaps for a temporary fix to calm down the slippage. I am thinking the right rubber gaskets ( washers) that are made to fit around an installation like a handcuff, that r the exact thickness and diameter and material needed would be a fair fix.
    Please remember I am a novice, but if the muscular window guy couldnt get it off, I dont want someonelse trying and busting the glass saying oh well.
    waiting for my fixit expert
    please see previous information
  • Mike Pliskin May 06, 2010
    SCREWS ARE OU REAL LITTLE ONES .... HANDLE WILL NOT BUDGE OFF. wHERE CAN zi GET RUBBER WASHER OR GASLET THAT WILL BE IN HALF FOR INSERTING THEN BACK TOGETHER-LIKE HANDCUFFS i QUESS
    SEE MY REPLY
  • Mike Pliskin May 07, 2010
    yes but how do i get the screws back in and why as thehandles are wobbly but nit comimg off at all.
    UR HOSTILE AND ABUSIVE 2 BOTH MYSELF AND THE REPAIR MAN. I CAN'T SEE HOW THEY LET U WORK THIS SITE
    Brigadier General:
  • 4,090 Answers
Much better to get it off, use brass screws and apply either a rubber gasket or use silicone around the edges of the handle to prevent water entering between it and the glass.. Screws can be drilled out if careful , without breaking the glass, just don't press too hard, or get someone to support the other side whilst you drill the heads out
Thanks for using FIXYA
Posted on May 04, 2010
  • 1 more comment
  • dennis bullard May 06, 2010
    hello again.
    Muscle usage on trhis task are not required and have no bearing on skill and ability to assess it for the most simple approach. Gentelness is the key to success here.
    You need a battery driven drill, or an AC power drill that has speed control. A fine drill bit that will match the screw size you want to drill out. Drill the heads of the screws to destroy them. That should allow the handle to remove itself , then if any residue if the screws is left, use a oair of pliers to rotate the shank of the screw to remove it, if it sheers off use the drill to remake the hole .
    Packing it out between the glass and the handle base is OK as is the use of silicon, Silicon scrapes off glass and there are removers to deal with silicon when needed. There is a waterproof variety by SELLEYS that is best to use in showers etc. Howevere replacement is the better approach and finish
    The job you need done is a straight foreward one and almost any handy man could do this. You dont need and expensive muscular musclehead to do this well.
    Cheers
  • dennis bullard May 07, 2010
    You must appreciate that i have no picture of this item to work from, thus to provide the answers to all your quiestions is nigh on impossible. I can only guess that the screws go either into a receiving plate that is on the other side(inside of the screen) or that they terminate in some type of pre drilled and threaded hole if some type.
    I understand by your description that the screws are loose and therefore there is some slack to allow the handle to move around. By cutting or drilling off the head of the screws, this will allow the main part of the faceplate and handle to be removed from one side. The other side should now drop off or require a tap to allow the shank of the screw ( now minus the head) to be also be separated from the screen.
    If the remaining screws have rusted to the base them replace the base or take it to a garage and ask for the mechanoic to see if his "Easy Out" tool can remove the rusted screws, left in the backplate. Pre spraying with rust remover will help to loosen the corrosion and make them easier to be removed.
    Beyond this advise, I am unable to assist as it's like flying blind to try and cover the subject accurately without seeing it But let me say this, It is not impossible to fix or remove rusted screws. perhaps you should call a real repair person in your area, not just someone who is over muscled and too dim to know how to remove rusted screws as part of his trade training.
    Sorry if it sounded hostile, I was trying to convey to you that you were being misled by this repair person. For any handyman this would be a straight forward job with the right tools. I have out lined the tools t5hat would or could be used. I could even add a hacksaw blade ( not in the saw, but just using the blade) inserting it between the glass and the handle and working it back and forward till it cut through the screws.
    Remember we are trying to see what you are and often that is difficult, when in replying to your explanation you do not understand what we are trying to convey to you. I still suggest that you approach another handyman or shower fixer to address this situation as it is not unfixable, but does require the tools and the patience to remove it
    As for being allowed to work here? I don't! We are all tradespeople who volunteer our time The only paid people are the owners of this site. We are here because we like to help those in difficulty save themselves from the often overpriced repair companies who fail to offer alternatives other than total replacements of reather than do dimple repairs.
  • 2,427 Answers
Well I would try to save the money,,
  • get new screws same size!!
  • get 4 o ring rubbers (same size of the handle)
  • get 1 tube clear silicon.
  • I guess you see where this is going..
  • stick the o rings to the base on the handle on eighter side..using the silicon (as less as possible)]
  • screw them back up..
  • 1 more comment
  • Rishi Roshan Ali May 04, 2010
    the orings is rubber seals that will take up the slack space.. buy them from any auto shop..
  • Rishi Roshan Ali May 07, 2010
    any auto part store will have o rings.. or rubber seals.. but remember that this will make it a bit thicker so you will need longer screws..
    its still held in place by something.. eighter a stuck seal or a screw....
Can you please give me the e mail address to contact Niagara as you suggest in your answer to my question as I can't find one but assume there is one as you recommended it. Thanks.
Hello Irene
You need to make this request in the original post under Tom's reply to you. You will see the word COMMENT, click on that and Tom will get a notification that you require further help. Fixya gets 9 million posts a year so the chances of someone seeing it as slim to none.
I am thinking one of these links will help you though.
Meynell Niagara (Niagara) shower spares and parts ' Meynell Niagara ...
https://www.showerspares.com/meynell_shower_spares/.../meynell_niagara_niagara/
  1. Cached
  2. Similar
Buy Meynell Niagara shower spares online. All shower spare parts for the Meynell Niagara in stock with same day despatch from the UK's #1 shower spares ...
Meynell Niagara 2 (Niagara 2) shower spares and parts ' Meynell ...
https://www.showerspares.com/...shower_spares/...all/meynell_niagara_2_niagara_2/
  1. Cached
... Niagara 2 shower spares online. All shower spare parts for the Meynell Niagara 2 in stock with same day despatch from the UK's #1 shower spares retailer.
Glass Inc,Niagara Falls,Glass,Showers Stalls,Shower Doors,Home
www.glassinc.ca/
  1. Cached
  2. Similar
Niagara Falls, Ontario, frameless shower enclosures, frameless shower doors, shower stalls, mirror, backsplashes, back painted glass, St. Catharines, Home.
Shower doors, bath screens - Niagara System Ltd.
www.niagara-wellness.com/productcategory/shower.../shower-doors-bath-screens/
  1. Cached
  2. Similar
Home/Shower enclosures/Shower doors, bath screens. Showing all 6 results. Default sorting, Sort by popularity, Sort by average rating, Sort by newness, Sort by ...
Here is the link to your post.
My Niagara bifold shower door fixtures are broken Is the Niagara company...
Oct 30, 2016 | Computers & Internet
How to tighten shower door handles
On my glass shower door handles, one inside and one outside there are button like screws hold the shower handles on. If you look closely you will see a small hole in the edge of the button. This hole is used to turn the button screw. This is not an Allen set screw, but rather how you turn the button screw. Insert a small Allen wrench into the side hole and rotate the button screw (not the wrench which acts as a tightening bar) clockwise to tighten or counterclockwise to loosen.
Feb 11, 2012 | Home
How do i remove the plastic handle on my delta shower. no set screw just a screw in the middle of the handle?
They sell a handle puller and it leverages your handle. There are other ways but it depends on the material of the handle. For example wd-40 can work, but if you have clear handles it weakens the plastic. The reason your handle won't come off is because of the hard water build up (calcium) and the handle needs to be wiggled out little by little. What I usually do is lubricate it then gently hit it with a rubber mallet till I get some play and then gently wiggle it out. Hope this helps!
Dec 01, 2010 | Delta & Single Handle Shower Faucet
I have just had the Sterling Plumbing Finesse Frameless Bypass shower doors installed in my new bathroom, model 5425-59S-G05. I do not like the clear doors and want to replace them with Lake Mist which is...
Home Depot will likely only sell the whole kit, not the individual doors off the floor. You may be able to special order just the doors through Home Depot or you may have to contact Sterling directly and order the doors through them. The doors hang on rollers from the top track and will come off simply by lifting them up off the track and out. Make sure to wear a good pair of rubber coated gloves as the doors can be quite slippery.
Jun 29, 2010 | Sterling Home
I have frameless shower doors, the bottom sill is tile, with grout lines. Water leaks under the shower door through the grout lines, how to correct this.
if the glass actually contacts the tile you can go to the homedepot or similar place and buy some glass silicone sealer and just run a nice bead of caulk along the line, make sure you get clear silicone and let it thooroughly dry before you get it wet
Sep 14, 2009 | Dmm Vigo Frameless Shower Enclosure with...
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
I have a new frameless glass shower and every time I open or close the door in iether direction there is a loud ''clicking'' noise that sounds like a spring is breaking. Any Ideas?
It sounds like you have something caught up in the hinges, or in between the door and the opening. I would have whoever installed it come back and fix it. As a general contractor I would not be happy with myself if I had installed it and would like the opportunity to redeem myself if it was not done correctly.
Jul 30, 2009 | Home
Frameless shower door sticking to the opposite wall when closing
you can fix this problem by loostening the clamp screw and putting locktite sealer(you can purchase locktite from hd or lowes locktite is not the only product you can call a glass supplier and as for recommendation) Be sure to read the directions on the tube I use it to seal joints on refrigeration threaded parts. Make sure it will adhere to glass and metal also review the clean up solvent when you do this place a wood wedge at the bottom of the glass dooor and the threashold to support he weight until the sealer driese
Steps
1 Place wood wedge/block under door where non hinged side meets wall
2 losten top hinge(inspect bottom hinge to make sure it is snug and the glass dor is all the way into the hinge
3 You may have to remove the top hinge completely to get enough of the locktite on the metal and glass place the locktite on the hinge flat plate and the glass
4 recheck gap where door meets wall( I sometimes use paint stirs(wood) as shims to keep space between door and wall consistent
5 tighten top inge screws( you can put locktite on the screw threas also
6 Clean excess locktite and wait suggested time by instructions on tube
Good Luck!
Dec 31, 2008 | Home
Home Logo
171 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
