Question about Jack Lalanne Power Juicer 250 Watts
My bad. I put the blades on with out the pulp
My bad. I have a power juicer elite and screwed the blades on with out the filter in place. Now I can't unscrew it because there is nothing to hold on to. according to the manual I left out step 3. Help! How can I get the blades off?
  • livelife10 May 04, 2010
    I left out step three. The basket is not on the juicer. The solution I was given does not apply as I can't hold on to the basket. How do I remove the blades when I can't hold on to the basket?
  • livelife10 May 05, 2010
    It's to bad that both of you don't understand the question.
  • 3,083 Answers
This is not going to be easy. The only way you're going to be able to get the blades off is by "locking" the blade shaft, or trying to hold it some creative way (unless you can take it apart, which may be your only option). Read the manual to see if there's a way to lock the blade shaft- that would be the easiest option. I've never experienced this problem, so I can't really give any details, just things I think will help. Good luck, and don't forget the filter next time (I'm sure you won't!).
Posted on May 05, 2010
  • c2095 Sep 17, 2010
    did you ever get the blade off the juicer.? I just did the same thing....put the blade on before the basket....Please let me know how and if you got it off. Thanks
  • 2,926 Answers
Use the crescent tool to
remove the blade.This tool is included with the juicer Place the
two pegs at either end of the
crescent tool into the two
holes on the blade. Press
down and turn counterclockwise
Remove blade
carefully.
Posted on May 04, 2010
    President:
  • 3,278 Answers
Hello.
I found this article in eHow:
http://www.ehow.com/how_6046424_remove-jack-lalanne-power-juicer.html
Hopefully, this will provide what you need.
  • NinaE May 05, 2010
    Sorry .. I'm trying to picture exactly what happened. So, the tool provided doesn't help ? Is the blade locked ? Can you use a lubricant of some kind with a small wrench to move/remove the blades ?
Where is the safety Switch in the Jack Lalanne juicer express?
The safety switch is on the bottom base where the pulp collection bin goes. If you look on the pulp collection bin there is a small tab that when assembled right deactivates the safety switch. The main arm that holds the top container where you put the produce in is also a safety mechanism that when not in place the machine will not turn on.
Sep 08, 2013 | Jack Lalanne Power Juicer 250 Watts
Pulp is building up, not ejecting properly
When juicing with the champion juicer take it slow. You need to hold down the tamper for three to five seconds in-between reloading the chute. Otherwise it will begin to back up through the chute and the juicer will begin to heat up. Happy juicing! LivingaHealthyandHappyLife.com
Mar 07, 2012 | Champion G5NG853S 540 Watts Juicer
Was given Jack Lalanne power juicer elite model MT-1066 for Christmas just opened it now & there is no manual. It is in it's lock position & there is no power at all.Can you help me ??????
The Operating Manual for the Power Juicer Elite is available here:
http://www.powerjuicer.com/pdf/elite.pdf
Check to make sure machine, including pulp collector is properly assembled; check silver bar is in upright position; check that spout is in downward position; preset reset switch located on underside of the main base.
For Tips and to view How To videos visit the website at:
http://www.powerjuicer.com/power-juicer-how-to-videos.php
Mar 19, 2011 | Jack Lalanne Power Juicer (Stainless...
My jack Lalanne juicer just suddenly stopped working.
Mine stopped working after only a few uses. It turns out that the safety microswitch button wasn't being depressed. The little button on the bottom of the pulp collector had broken off. (Image #1) I put a 1/4 inch piece of a shishkabob skewer in the hole before putting the pulp collector on. (image #2) It works fine now. It's still safe. The motor will not start unless the pulp collector (receptacle) is in place and locked in. Be sure to unplug the machine before doing this. 3717db6c-91bc-41ee-b452-1ed06578f280.jpgjack-lalanne-juicer-just-rgzqoe2q2f3mnxiw25vk3yhi-4-2.jpg
Mar 07, 2011 | Jack Lalanne Power Juicer 250 Watts
Can't find the manual and have forgotten how to take it apart to clean it
Most juicers have a retention rod or side snaps that hold the top of the juicer in place. By loosening these, it will allow you to get underneath the juicer cap top. Once you have done this, you will have to remove the juice/ pulp wheel blade. Your juicer should have come with a two pin tool that facilitates this. Use the tool to loosen the juice /pulp wheel blade. Once you have done this, you should be able to remove the outer juice capture rim with that has the spout on one end. I hope this helps. Good luck and happy juicing.
Jul 18, 2010 | Juicers
How to clean the Jack LaLane Juicer?
the blade can be removed possibly with your hands, if you can manage to turn it, if not then find something that will fit into those little holes of the blade to turn it, and then take it apart, but remember in what order. to put it together: the grey thing with the spout attached goes on first, then the orange basket, then the blade, but don't turn it too tight, just look for the indicator marks and line them up with the arrows, then the black lid, and then the pulp basket.make sure that the black lid in the back, goes INTO the pulp collector, it is not very far, but if it is not done like this, then your machine will not work. then you raise and lock the bar into place and put the pusher into the feeding tube. hope that helps.
Jun 21, 2009 | Jack Lalanne Power Juicer 250 Watts
Acme juicer #6001, has a new blade, becomes unbalanced...
Hello, First, make sure the screw on clamp that holds the blade down is centering the blade correctly. Also make sure it tightens down firmly against the blade. Wiggle the blade to ensure it is mounted securely. If this doesn' fix it try your old blade again. If your old blade works you may have a bad, unbalance blade but I would suspect he screw on clamp knob may be somewhat worn and not securing the blade causing it to run "out of round" when a piece of vegetable pushes on it. If everything looks good with both blades and the blade securing knob it could be a worn bearing on the juicer. Try wiggling the motor shaft and see if there is any play in it. I have an ACME 6001 that is quite old so I wouldn't suspect the bearings are going. One other thing, does the bowl take 3 to 5 minutes to stop spinning when you shut off the motor? If it does then the shaft and bearing are probalby ok
Good luck with it...gary
Jan 05, 2009 | Acme 6001 Juice Extractor
Cant grt it apart to clean
Take off the top part of the juicer that has the chute. You will see the blade and basket. The blade appears to be attached to the basket with three small screws but is actually screwed onto the basket by a large screw that protrudes out of the basket underneath the blade. So the trick is to unscrew the blade, turning it to the left by using maybe a small screwdriver that you will have to put into one of the two small holes that are on the blade surface and pushing the blade to the left. This should loosen the blade and then you can just unscrew the blade off the basket. Once you get that blade off, the rest of the juicer comes apart. The newer models come with a little tool with a couple of arms that go down into those holes and loosen the top. Good luck.
Jul 22, 2008 | Jack Lalanne Power Juicer (Stainless...
Cutting Blade won't come off
I do not have a tool so I used two pen tops, turned the blade counterclockwise while ensuring the filter basket stayed put. It worked well
Apr 16, 2008 | Jack Lalanne Power Juicer 250 Watts
Pomegranate
Well ya can juice 'em but it's a bit labour intensive .. lol 'cause ya gotta skin 'em, and get ALL the "Seeds" out, they taste bad... then put the pulp in.. and juice away... yield is low also .. but tastes real nice in the end.. I usually do it in a plastic bag,and tip the pulp into the juicer. Ya can make great "leathers" too..
Aug 04, 2007 | Jack Lalanne Power Juicer 250 Watts
Jack Lalanne Power Juicer 250 Watts Logo
94 people viewed this question
Top Jack Lalanne Juicers Experts
Greg Cann
Greg Cann
Starnley Johnwells
Starnley Johnwells
Are you a Jack Lalanne Juicer Expert? Answer questions, earn points and help others
