Question about Brother CS6000i Computerized Sewing Machine
My bobbin thread is not drawing up on my brother sewing machine cs6000i, could it be y bobbin case
    New Friend:
  • 184 Answers
If the thread is being trapped in the bobbin area, yes, it could be the bobbin case. If the thread goes around the bobbin case and come back up then it is probably out of time and needs to be sent to a repair shop.
Posted on May 07, 2010
Why does my cs6000i the needle hits the bobbin case put nicks in case and then thread snags in the bad area
If you are talking about the bobbin case (housing), it may be inserted incorrectly. Remove it and put it in again, or the needle isn't seated correctly. Once the bobbin case is damaged, do not use it anymore or you will continue to have problems. If you mean the bobbin, change bobbins and see if you continue to have problems, as you might have the incorrect size.
Jun 27, 2014 | Brother CS-6000i CS6000i 60-Stitch...
I have a Brother cs600i sewing machine and the wheel is tight.
Did you also get the thread out of the spindle around the handwheel and out of the shuttle case?
Jan 24, 2014 | Brother CS6000i Computerized Sewing...
I keep getting error E6 on Brothers CS 6000i- I cleaned the thread several times and when I try to restart sewing it happens again. I've removed the bobbin and re-threaded and it keep jammin and beeping....
The motor locked up because the thread is tangled.
Solution:
Remove the tangled thread before continuing the operation.
Clean the bobbin case to remove the tangled thread.
After cleaning the bobbin case, insert the bobbin case properly.
If the needle is bent or broken, replace the needle.
Then, thread the upper thread properly, and continue the operation.
Dec 21, 2013 | Brother CS-6000i CS6000i 60-Stitch...
Machine is showingE6
The motor locked up because the thread is tangled. Remove the tangled thread before continuing the operation.Clean the bobbin case to remove the tangled thread. After cleaning the bobbin case, insert the bobbin case properly. If the needle is bent or broken, replace the needle.Then, thread the upper thread properly, and continue the operation.
Sep 22, 2012 | Brother CS6000i Computerized Sewing...
I keep getting the E6 (tangled thread) message on my Brother CS600 when I try to sew. I have check for tangled thread and cannot find any. Could it be that the bobbin case needs to be replaced? It seems...
is the bobbin case damaged in any way?
try turning off the machine & unplugging it & then replug it back up & turn it on & see if that clears the computer parts of the machine
if it still shows a E6, then you can replace the bobbin case or you might even consider having it serviced
Aug 29, 2011 | Brother CS6000i Computerized Sewing...
My bobbin thread is not drawing up on my brother sewing machine cs6000i, how do I adjust the tension for the Bobbin thread?
Yes its the tension, however it can be tricky, and you really should have some experience working on the mechines Give us a call we can help you out.
303 770 6321
AAAA TEVA
Jul 07, 2010 | Brother CS6000i Computerized Sewing...
Bobbin thread comes out in a mass of threads
ENSURE you have threaded the bobbin properly and at the right tension. Also, ensure that you have routed the bobbin thread properly in the bobbin case.
Apr 02, 2010 | Brother CS6000i Computerized Sewing...
Brother sewing machine cs6000i. Less than one year. The upper thread wraps around the bobbin caseing and jams.
check you tension on the top thread and see if you have it threaded the right way. Also see if the indent of your needle "the indent down by the hole on the needle" is facing the hook by your bobbin case that grabs the thread when it comes around.
Greg
Jun 13, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS6000i Computerized Sewing Machine Logo
315 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
