Question about Sharp Notevision PG-M20S Multimedia Projector
Power light flashes red on Sharp PG-M20S
Projector is eight years old, but only about 1,000 hours on lamp.
First problem with the unit, no sign of lamp being powered.
Lamp indicator does not light.
Sinista
  • 6 Answers
SOURCE: Tech support for Sharp PG-B10S
Reset The Lamp Timer.
While simultaneously holding down (+ . >) and AUTO SYNC on the projector, Press ( I ) ON and ( - . < ) on the projector.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
NOTE..... Make sure only to reset the lamp timer only when replacing the lamp. If you reset the lamp timer and continue to use the same lamp, this may cause the lamp tp become damaged or explode...
Sinista
Posted on Jul 10, 2008
SOURCE: Lamp timer on Sharp XV-Z2000 will not reset
I unplug my cord, waited for 5 minutes, then reconnect cord holding the power button at same time, released, then proceded with input, left arrow, enter, right arrow and depress power button again holding for 15 seconds, then released. projector warmed up showing the  "0000H" on the bottom left of screen...that's how mine worked today.
Posted on Jan 10, 2009
SOURCE: Sharp Notevision PG A10X
check the power supply heard issues with this system like that but was all related to the power supply
Posted on Jan 24, 2009
projdoc
  • 2237 Answers
SOURCE: Sharp XR-1S Projector, no picture, lamp light flashing..... help!
if it's under 1 year old, it's still under warranty, so send it in and get it fixed for free.
Posted on Jul 23, 2009
  • 3 Answers
SOURCE: Cannot remove lamp assembly from Sharp XR-10X projector
Carefully try using a flat head screw driver on the middle plastic piece. make sure it is off...
Or try coming at it from the other side after taking the top of the machine off you can unscrew 3 screws and loosen whatever might be blocking it
Posted on Sep 08, 2009
The "lamp" light keeps blinking red. Does this
The lamp life becomes 0%, when used
for approximately 4,000 hours with "Eco
Mode" or when used for approximately
2,000 hours with "Standard Mode" (see
page 43).
When the remaining lamp life becomes
5% or less, " " (yellow) will be displayed
on the screen. When the percentage becomes
0%, " " will change to " " (red),
the lamp will automatically turn off and
then the projector will automatically enter
the standby mode. At this time, the
lamp indicator will illuminate in red.
If you try to turn on the projector a fourth
time without replacing the lamp, the projector
will not turn on.
If you require the manual to help with changing the bulb, send me an email to LBrown18062@hotmail.com Put SHARP PG-B10S in the subject line. I will send it to you right away. Lawrence Brown
Oct 26, 2011 | Sharp Notevision PG-B10S Multimedia...
Hello, i have a sharpe PG-M20S, and just replaced the bulb. I accidently threw the power cable away; I found another in a drawer; i plugged that in; I power the projecter on, and it stays on for 1 second...
There is no problem with the cable as the voltage ident on it is the maximum safe voltage that may pass through it without risk of electric shock.
I would imagine that you have to find your instructions and reset the lamp life now.
Hope that helps.
Feb 17, 2011 | Sharp Notevision PG-M20S Multimedia...
Sharp PG-M20X digital projector runs 2-5 minutes then shuts off
the Fan has the problem , I had the same of yours. I noticed some particle was inserted in the center of the fan and removed it , worked perfectly. If old one produce little particles.
Good luck.
Dec 03, 2009 | Sharp Notevision PG-M20X Multimedia...
I got a free sharp notevision PG-m20x. I plug it
if you don't hear a high-pitched whir, the colorwheel needs replacing. if you do hear it, the lamp may need replacing. if the lamp is new, there is a power supply problem.
Sep 04, 2009 | Sharp Notevision PG-M20X Multimedia...
Projector wont turn on
reset the lamp hour counter by (after you plug it in) holding down the enter, down, and menu buttons then press the power button. if it comes on, replace the lamp, it's old. if not, make sure the lamp door is closed completely and there's nothing blocking the fans.
Jul 08, 2009 | Sharp PG-MP66X DLP Projector
Aug 21, 2008 | Sharp Notevision PG-A10X Multimedia...
MULTIMEDIA PROJECTOR
This sounds like a faulty Mainboard
Apr 08, 2008 | Sharp Notevision PG-M20S Multimedia...
Lamp
Hello, Pls check theair filters and the condition of the lamp unit after extracting the lamp out of unit.
Jan 20, 2008 | Sharp Notevision PG-M20S Multimedia...
Sharp Notevision PG-M20S Multimedia Projector Logo
87 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
