Question about Remington Electric Pole Saw
When there is pressure is add to the saw acts like it's not gettin any electric to it and i have to bounce it back and forth to make it start
    Brigadier General:
  • 4,088 Answers
Are the chain and bar being oiled properly? Make sure the chain is correctly sharpened and adjusted. Hope this helps!
Posted on May 04, 2010
1992 caravan tachometer doesn't work, speedometer bounces back and forth, acts like it is running out of gas when driving on the highway
the cluster and the low power issue are un related. check your engine computer at a parts store. if there is an EGR code, it may be the problem.
Nov 15, 2013 | Dodge Caravan Cars & Trucks
My Dremel max won't start
Check and replace brushes as necessary. Also, check that the actual electrical switch is functional. I had to add a drop of crazy glue on the tip of the interior plastic handle housing that supports/puts pressure on the electrical switch to keep it in position. The off/on thumb slider actually extends well into the housing and activates the electric switch by moving back and forth. Over time, the plastic wears and does not plunge the on off switch button. A drop of glue on the tip of the plastic post extends it & causes enough pressure to make the electric switch to function again. Brushes (filed to fit) and glue = good as new Dremel :o)
Dec 08, 2012 | Dremel Multi Max Kit
Is it normal for the vacuum tester to bounce back and forth when testing on my 1977 Mercedes 300d
Hi Robert, I know that on the older models of the Benz a vacuum pump was fitted into the trunk for operating various units on the vehicle inclusive of the central locking system. The vacuum pump which operates on the braking system creates a much higher low pressure area than that used for other units. I believe if you fitted your gauge directly onto the brake booster pump you may have damaged your gauge. Regards John
Sep 09, 2012 | Cars & Trucks
1999 suburban 5.7L - Oil pressure gauge bounces back and forth between 40 and 50 pounds very rapidly
Replace the oil pressure sensor located near the oil filter. When this part starts to fail you will see your oil pressure gauge bounce all around
Jun 28, 2011 | 1999 GMC Suburban
Just bought wg303.1 plugged in would not start no instruction manual must add chain to start?
Most electric saws will have a saftey cut out micro switch for the chain brake, pull the hand guard fully back toward the rear of the saw to make sure the brake is completly off, now try again.
Feb 13, 2011 | Worx (16") 3.5 HP Electric Chain Saw -...
My truck just turned 200,000 miles, the fuel gauge all of a sudden started vibrating or bouncing back and forth, it is so fast and the bounce is such a short distance its almost hard to notice. shortly...
I think that the pump and the sending unit for the gas tank which includes the fuel level sending unit will be needed to be replaced to rectify the problem.
Of course, the wiring should be checked out as well for wear of insulation before it goes into the tank. This is a common problem for older GM cars.
Good luck on this repair.
Oct 09, 2010 | Chevrolet 1500 Cars & Trucks
Oil pressure gauge erratic reading full pressure then no pressure. it is bouncing back and forth while driving. Where is the sending unit?
Pretty common problem with these. Here's a guide to learn how to fix GM instrument clusters yourself, I used it to fix mine and it worked great.How to guide for Silverado instrument cluster repair
Sep 06, 2010 | 2006 Chevrolet Silverado 2500HD 2WD
It starts and dies
if it starts then its gettin fuel,but it might not be gettin enough.or it might be gettin too much. after it starts and dies remove spark plug, if its wet then the saw is flooding out, try cleaning the plug and airfilter,u can also add some seafoam to the gas,it will help clean any dirt out of carb. if that dont help check the carbs diaphram
Apr 02, 2010 | RTO Spur Sprocket For Stihl 017, 021...
Oil gauge on tahoo moves back and forth
Is it the factory oil guage? Is it an electronic or mechanical guage? if it is mechanical that means you actually have a small diameter tube from the engine to the dash area, which may have a kink or bend in it. If it is electronic then your dealing with a wire which can have a slight short in it or a bad connection. REMEMBER!!!!!!!!!
An oil guage that works properly will have up and down readings. When the RPM's increase, so should the oil pressure guage. when you are not running the engine( idleing) the guage will read lower and sometimes bounce back and forth around 5 PSI. sometimes more depending on the grade of oil, how hot the engine is and how old is the oil.
Sep 19, 2009 | Innova te Motorsports G2 Oil Pressure...
Remington Electric Pole Saw Logo
41 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
