Question about Gateway FPD2275W LCD Monitor
Monitor to tower hook up problems
I keep having a problem with my monitor it's connected to my tower but it screen keeps saying that I need to check signal cable. Why?
  • Anonymous Apr 08, 2008
    Monitor says No cable..then screen just goes black, was working fine before that..
    Everything is hooked up the same as it previously was. Has worked great for 2 months.
  • Anonymous Sep 01, 2008
    I keep getting cant find signal cable
  • 151 Answers
Open your monitor's cover and plug out vga cable and check continuity of wirs this way-monitor to tower hook  up problems - d314a67.jpg
Posted on Mar 26, 2008
    Brigadier General:
  • 6,966 Answers
Often the problem is not really the monitor but the PC. There is not video output from the video card and the monitor in sensing this assumes that the cable is unplug.
The sure way of determining which is at fault is to try and use a different monitor to your PC (as well as the cable). Should problem persist, then it is the PC that would need to be checked.
Should you have verified that it is the PC, suspect would either be the video card and/or the memory sticks. In some instances cleaning with a pencil eraser the little gold pins of either the video card and/or the memory sticks helps.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
SOURCE:
My scepter flat screen computer moniter keeps flashing on and off. It is hooked in correctly, however, even when the tower is off the screen flashes on, then to standby and then to just off. The whole time...
try to use the menu buttons of the display/screen to reset it to factory defaults and use the auto-adjust option if available. this often resolves common issues specific to the screen itself. it can help help to remove the power cord from the monitor then hold its power button for about 10 seconds to drain any power and test it again using another video cable. you may also want to observe if it flashes when not connected to the video cable and when plugged in to a different power outlet and cord.
Jul 18, 2013 | Computers & Internet
My Desktop computer is dead
it means that the monitor is not receiving any signal from the cpu, check the cable that goes from the tower (cpu) to the monitor
Jun 06, 2011 | Dell Dimension 2400 PC Desktop
Screen went black and a window came accross the screen saying attention entering sleep mode......and then it said no video input...
It sounds like the problem is in your computer, hook a spare monitor to verify, if you have the same problem, it is your tower that needs to be checked out.
Mar 25, 2011 | Philips Computers & Internet
The monitor keeps saying no signal
Turn power off to the tower and the monitor before making any connection changes.Make sure that the Blue connector from your monitor is connected to the Blue connector on the back of the computer tower. If this doesn't work you should try the monitor with another computer, just to check that the monitor is working. If the monitor works on another computer you may need to buy a Graphics Card. Next, try another monitor with your tower- If the problem still exists it is likely you need a Graphics Card.
Mar 19, 2011 | Acer Aspire X1300 (PV.SCC0X.002) PC...
My monitor, keeps saying it is going to sleep. VGA says no input signal, as well as DVI. And I know nothing about computers
If there is no output on the screen, check all you cables and connections and ensure they are snug and secure. If there is still a problem, it is possible your video card is to blame. As a diagnostic step, try hooking the monitor up to a different computer. Or hooking up another monitor to your computer. This will help eliminate bad cables and connections. If a different computer works on your monitor, then you most likely have a bad video card. If you monitor still will not work on any computer, then you most likely have a bad monitor.
Feb 28, 2011 | HP w1907 LCD Monitor
Monitor shuts off while in use
possibly the video card needs to be reseated or the power to the card is intermittent. Also always check for loose connections at monitor and computer.
Apr 13, 2010 | Gateway FPD1975W 19" LCD Monitor
Monitor keeps saying no signal.Tried a new cord from monitor to tower but that did not help.The light is on the monitor to show that it is on.Help please.
connect another working Monitor to the tower, if this solve the problem send in the monitor to the monitor's authorised repair center. If the problem is not solved, replace the Vedio card on the tower
Dec 28, 2009 | E-Machines eMachines Monitor E15T4
Contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Dec 07, 2008 | Dell Dimension 2400 PC Desktop
I have an HP pavillion elite model m9250f. when I turn it on, the 19 inch monitor will show a screen that says no dvi input and then show a screen saying that the monitor is going to sleep.
have you checked the plugin in the back of the tower. check that all the prongs are their and attached. thier could be a number of things wrong. 1). could be the monitor itself, try it on a diffrent system. then we know if it's the monitor or the video card. 2). try hooking up a diffrent monitor to you tower and see if it will work that way, if not then you'll need to replace your video card. 3). check your drivers, kinda hard to do with no screen i know.
Aug 10, 2008 | HP Computers & Internet
How to hook this monitor onto my computer
You would have got a CD with this moniter..
we ahve install that cd..
and its better to check the cables first which would be the
VGA CORD that is blue in colour which connects your moniter with the tower.
We can check the connections with the moniter for the Tower and then install the cd.
Feb 06, 2008 | Computers & Internet
Gateway FPD2275W LCD Monitor Logo
157 people viewed this question
Top Gateway Computers & Internet Experts
Ekse
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
