Question about Siemens Washing Machines
Washing machine not working; washing cycle - Siemens Washing Machines
  • 1 more comment
  • sheilademesa May 04, 2010
    Siemens WFXD8400UC Front Load Washer
    The washing cycle is not working ... it's dispensing the soap but when it's in the washing cycle the machine was not spinning. We checked the belt and it looks okay.
  • sheilademesa May 05, 2010
    Hi we did as you explained but no message was diplayed on the panel ... it only went from READY-> DISPENSING DETERGENT-> WASHING -> READY ... in the WASHING cycle the tub didn't move we checked at the back and the drum and belt is not moving as welll tried to move the belt manually but it was smooth ... it was moving ... tried to go to SPIN CYCLE and the same thing it just drain water.
    no restriction the drum and the pulley run smoothly when turned manually. sorry misunderstood you =)
  • Siemens Master
  • 8,220 Answers
I have never seen one of these washers or worked on one but I can almost bet you somebody is putting too much detergent in the washer.
Over-sudsing is the number one problem on these newer washers.
You must use "HE" (High Efficiency-Low Suds) type detergent--and use the correct amount.
Nearly all brands of "HE" detergent have incorrect instructions.
The correct amount is as follows:
HE: (2) Tablespoons Per Wash load
HE 2X (double concentrated) : (1) Tablespoon
HE 3X (triple concentrated): (1) Teaspoon
Posted on May 05, 2010
    President:
  • 1,554 Answers
Troubleshooting of the problem can be more easily if more information is provided including the make and exact model number of the washer. It will enable us provide you a more specific and acuurate advice.
Posted on May 04, 2010
  • Jahn27
    Jahn27 May 05, 2010
    Turn the drum manually by hand and check if turning freely; if not remove the drive belt and turn the drum and the motor pulleys to determine where the restriction is coming from. Please indicate any message displayed on the display panel. Check also the drain hose for siphoning.
  • Jahn27
    Jahn27 May 05, 2010
    Turning the drum and the motor pulleys to
    determine the source of the restriction is not intended to make the washer display the error code, if there's any, but merely to find what might be causing the drum not to tumble or spin. Please indicate if there's any restriction within the drum pulley or the motor pulley.
Ariston a1435
Does it work before? Try reset the machine... 1.0 Turn off the machine. 2.0 remove the power supply from the main supply. Leave the machine without any connection for about 15 minutes. try again?
Sep 14, 2007 | Washing Machines
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Why my washing machine will start the wash cycle but will not spin or rinse?
the drain pump is probably blocked or overheating, when it starts beeping which lights are flashing reading from right to left e.g. 1,3,5 also what is the model number?
Aug 17, 2014 | Fisher and Paykel Washing Machines
Wash Cycle doesn't start
Unplug the machine for about fifteen minutes. When your fuse blown it caught in the middle of the cycle. By unpluging it will reset the machine.
Dec 07, 2009 | Washing Machines
Kenmore washing machine didn't spin @ end of cycle
If you tried a different cycle and it worked this means that the timer is probably bad on the main cycle that you use. If the machine does not spin on all cycles, then please check out the LID SWITCH.
Nov 12, 2009 | Washing Machines
The wash cycle doesn't work, but spin cycle works!
Did you ever find out what was wrong with your washer?
Mar 23, 2009 | Whirlpool Washing Machines
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
70 people viewed this question
Top Siemens Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Siemens Washing Machine Expert? Answer questions, earn points and help others
