Question about Sony FD Trinitron WEGA KV-36FV300 36" TV
My sony kv-36FV300 will not respond. won't turn off .....or turn stations. The picture is snow...and has a "7" in the upper right hand corner. ....and has "no signal" in lower left corner.
Just wondering if thesmiths860 found a solution to their issue w/ their Sony TV. My tv is doing the same thing i.e. snow, won't change channels and says "NO SIGNAL".
Does anyone have a solution? I don't have the original remote so I can't do a factory reset.
Posted on May 13, 2010
Remove other picture
With the Sony Remote (brand indicated here) select the PIP button to turn that feature off.
Mar 28, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Green numeral in upper right hand corner will not
There should be a button marked i,press this and it should disappear
Dec 08, 2009 | Sony FD Trinitron WEGA KV-27FS120 27" TV
37 inch sony xbr with tru surround tube tv
can you turn on the tv manually? or with the original sony remote control
are you using the channel 3 or any video input to display the tv picture.
thanks
Aug 06, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Arched picture on Sony KV-34XBR800
Your TV has problem in Pin-Out area. I know its technical term but I have no other words to explain it. TV needs qualified technician to fix it.
Jun 11, 2008 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
No signal
Check is RF Antena/ Cable connected? If yes, go to TV Menu and select Auto-Program. TV will start tuning and search all available channels on cable/ on-air. If there is no channel reception, TV has defective Tuner. If you know basic electronics knowledge, replace the Tuner or contact nearest Sony repair shop.
Jun 04, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
SONY TV Model KV-36FV300 Problems
plz contect me we repair lcd plasma and projection tvs
Yogesh-9811440932
Jan 30, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Blank screen
These tvs are known for bad power supply capacitors. Try power cycling the tv several times (8-10) to see if it finally comes up. Four flashes indicates a power supply problem or a deflection problem, usually it is the first. Take the set into a shop if you are not an electronics technician, as these are dangerous areas to work on. Otherwise, use a capacitor checker to test the caps, starting with the main supply caps which are usually 200v. I've found these to be low by 200uf. Also, check the 1000uf and 2200 uf caps. These will be low by 100 - 200uf.
It could be a flyback or deflection problem, but check those caps first.
Jan 22, 2008 | Sony FD Trinitron WEGA KV-36FV300 36" TV
Sony kv-32s42 needs help.Tuner problems?
Hi Grasshoppa, I would venture a guess that your tuner is not at fault but most probably the logic circuits controlling it since as you posted, you can tune > get a good picture but "channel numbers in the upper right hand corner ...." If your intention is to use the VCR and thereafter change channel using the VCR, you may use the Audio/Video input. With an RCA 3 cable connector, connect the (Yellow) Video out, (Red/White) L/R Audio out of the VCR to the Video in &L/R Audio in of the TV. You don't need to set the TV to Ch 3 but rather select Video 1 or 2 or A/V. Hope this be of some help/idea to you. Post back how things are or should you need further information. Good luck and kind regards
Jul 27, 2007 | Sony KV-32S42 32" TV
Sony FD Trinitron WEGA KV-36FV300 36" TV Logo
179 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
